Currently I have few 74HC595 registers, but they cannot source enough current for 8 LEDs (~20mA for each). I know I could use transistors, but I want to use as little amount of parts as possible. So is there any shift register which can do that? Hopefully well known, because at the place where I live not many parts are available and then I have to order them from other cities/eBay.
cd74ac164
Thanks! Any other ones? In case this one isn't available when I go looking for it.
Why not use a proper LED controller? eg. TLC5916?
PS: A 74HC595 can source 17.5mA on four pins and simultaneously sink 17.5mA on the remaining 4. If you arrange your LEDs nicely that's pretty close to 20mA per pin. ![]()
TLC parts only sink current, they do not source.
If you can get by with sinking current, look got TPIC6B595.
Also 6A595, 6C595, 6D595.
Thanks for the responses! I really need to source current, but in other cases sinking will also work. (this is for common cathode RGB LEDs, so I need to source, not to sink)
