shiftout
So this example code:
const int latchPin = 8;
const int clockPin = 12;
const int dataPin = 11;
  //set pins to output because they are addressed in the main loop
  pinMode(latchPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  // iterate over the 16 outputs of the two shift registers
  for (int thisLed = 0; thisLed < 16; thisLed++) {
    // write data to the shift registers:
    registerWrite(thisLed, LOW);
    // if this is not the first LED, turn off the previous LED:
    if (thisLed >= 0) {
      registerWrite(thisLed - 1, HIGH);
    // if this is  the first LED, turn off the highest LED:
    else {
      registerWrite(15, HIGH);
    // pause between LEDs:
    delay(130);
    for (int thisLed = 16; thisLed > 0; thisLed--) {
    if (thisLed >= 0) {
    else {
    delay(130);
// This method sends bits to the shift registers:
void registerWrite(int whichPin, int whichState) {
  // the bits you want to send. Use an unsigned int,
  // so you can use all 16 bits:
  unsigned int bitsToSend = 0;
  // turn off the output so the pins don't light up
  // while you're shifting bits:
  digitalWrite(latchPin, LOW);
  // turn on the next highest bit in bitsToSend:
  bitWrite(bitsToSend, whichPin, whichState);
  // break the bits into two bytes, one for
  // the first register and one for the second:
  byte registerOne = highByte(bitsToSend);
  byte registerTwo = lowByte(bitsToSend);
  // shift the bytes out:
  shiftOut(dataPin, clockPin, MSBFIRST, registerTwo);
  shiftOut(dataPin, clockPin, MSBFIRST, registerOne);
  // turn on the output so the LEDs can light up:
  digitalWrite(latchPin, HIGH);
let me shift out the code to 2 registers. I tried using
byte registerThree = highByte(bitsToSend);
under
so it can shift out a third bit but it doesn't work. I am trying to shift out the code the a third register. which part should i modify??
thanks
add
shiftOut(dataPin, clockPin, MSBFIRST, registerThree);
before the shiftout for registerTwo
Do you want to change the middle variable to middleByte(bitsToSend) so the 2nd ^& 3rd displays aren't the same all the time?
Probably need to change your approach here also
so that you have 24 bits to play with.
thisLed needs to be type long vs int.
CrossRoads:
Yes.
I tried
byte registeThree = highByte(bitsToSend);
but the 2nd and 3rd are still running the same..
You misunderstand.
Your function does this
There is nothing there to make the 3rd shift register/LED do anything.
That's why I said you needed to expand things to be 24 bits.
CrossRoads:
You misunderstand.
what should i put in for this right here, since i can't do byte registerThree highByte or lowByte (bitsToSend);
If you want the 3 shiftouts to have 3 different values, then you have to reorganize.
Look here -everything is set for 16 bits int type variables:
Go thru and understand what is doing wiht 16 bits, then change things to long and unsigned long so you have a 32bit variablee to work with, and use 24 bits of it.
