Hello,
I'm dipping my toes back in electronics after almost a decade and bought an Arduino Uno R4 Minima, mainly doing simple stuff.
However, I've started to work on a small project: Among other functions (which are outside the scope of this post), the system must:
- Record sound (ADC acquisition) when present on pin, for at least 30 seconds.
- Play the recorded sound (using the DAC) once the source goes quiet or maximum record time is reached.
- Acquired sound is only played once, it can be discarded. It does not need to be "CD quality".
- All of the audio I/O, level shifters and other hardware considerations are outside the scope of this post and already taken care of.
I've been mulling solutions on how to acquire and store the sound, and this is what I've thought of:
The Arduino will use an external "big" (8 Mbit) SRAM memory (I've decided against Flash because it will wear out). It will acquire 8-bit samples at 24 ksamples/s (or any other sample rate), store them in the external SRAM then will read back what is stored in the external SRAM. The sound quality should be okay-ish and should cover almost a full minute of recording (which is more than enough).
While I don't see any fatal flaws in this solution, I wonder if I'm missing a more elegant or optimized solution ?
Thanks in advance.
