I need your help
Hello friends, I have a project in mind and I don't know how to do it. I am new to Ardunio. I want to design a toy tablet. When I press the button, I want it to play the sound you have specified, but I want it to play the things I have said before, not the song. How can I do this? I have an Arduni Uno. I would be glad if you could help me.
Welcome to the forum
Your topic has been moved to the Project Guidance category of the forum
You want to record some sounds and play those sounds depending on user input?
How will you make the recordings?
Yes, exactly like that, the sounds I recorded will be played on the buttons pressed by the user. Can I do this with Arduino?
Originally ISD now Nuvoton ISD it sounds like you are looking for a "chip Corder". Today they come in all sizes (record durations) and are inexpensive. Try a simple Google of chip corder modules or chip corder boards and you will get a dozen hits, Like This One.
You can run boards like this stand alone or under control of an Arduino or about any uC like an Arduino.
Ron
I suggest to take a look at esp boards. Those have sufficient memory to hold a few minutes of music.
Uno will run out of progmem really fast (a blib and a blob would work fine...).
You can try this method: https://www.youtube.com/watch?v=m1HEwgHSBrs&t=22s
You can use the DFPlayerMini using buttons and without Arduino...
thank you friend for your help :slight_smile:
Like @xfpd, I too would recommend the DFR Player. Either on its own with a few resistors, or with the Arduino connected for more flexibility.
I assume you will record your tracks onto the mini-SD card with an appropriate tool, like Audacity, GoldWave, etc.
