Showing temperature on an lcd
I'm doing a project and I'm stuck. I need to display the temperature on an LCD screen and I mixed 2 codes to start but I can't find or understand anything on the internet. My code is below and if anyone could help me I would really appreciate it.
    File........... Thermistor_Demo_Code
    Purpose........ Thermistor demonstration code
    Author......... Joseph Corleto
    E-mail......... corleto.joseph@gmail.com
    Started........ 7/25/2016
    Finished....... 7/25/2016
    Updated........ --/--/----
   Notes
  Updates
//  Header Files
//  Constants
//Thermistor related:
/* Here we have a few constants that make editing the code easier. I will go
   through them one by one.
   A reading from the ADC might give one value at one sample and then a little
   different the next time around. To eliminate noisy readings, we can sample
   the ADC pin a few times and then average the samples to get something more
   solid. This constant is utilized in the readThermistor function.
const int    SAMPLE_NUMBER      = 10;
/* In order to use the Beta equation, we must know our other resistor
   within our resistor divider. If you are using something with large tolerance,
   like at 5% or even 1%, measure it and place your result here in ohms. */
const double BALANCE_RESISTOR   = 9710.0;
// This helps calculate the thermistor's resistance (check article for details).
const double MAX_ADC            = 1023.0;
/* This is thermistor dependent and it should be in the datasheet, or refer to the
   article for how to calculate it using the Beta equation.
   I had to do this, but I would try to get a thermistor with a known
   beta if you want to avoid empirical calculations. */
const double BETA               = 3974.0;
/* This is also needed for the conversion equation as "typical" room temperature
   is needed as an input. */
const double ROOM_TEMP          = 298.15;   // room temperature in Kelvin
/* Thermistors will have a typical resistance at room temperature so write this
   down here. Again, needed for conversion equations. */
const double RESISTOR_ROOM_TEMP = 100000.0;
//  Variables
// Here is where we will save the current temperature
double currentTemperature = 0;
//  Pin Declarations
//Inputs:
int thermistorPin = 0;  // Where the ADC samples the resistor divider's output
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
//Outputs:
//  Initialization
  // Set the port speed for serial window messages
   // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // Print a message to the LCD.
  lcd.print("Hello, World!");
//  Main
  /* The main loop is pretty simple, it prints what the temperature is in the
     serial window. The heart of the program is within the readThermistor
     function. */
  currentTemperature = readThermistor();
  delay(1500);
   // set the cursor to column 0, line 1
  // (note: line 1 is the second row, since counting begins with 0):
  lcd.setCursor(0, 1);
  // print the number of seconds since reset:
  lcd.print(millis() / 1000);
  /* Here is how you can act upon a temperature that is too hot,
  too cold or just right. */
  if (currentTemperature > 21.0 && currentTemperature < 24.0)
    Serial.print("It is ");
    Serial.print(currentTemperature);
    Serial.println("C. Ahhh, very nice temperature.");
  else if (currentTemperature >= 24.0)
    Serial.println("C. I feel like a hot tamale!");
    Serial.println("C. Brrrrrr, it's COLD!");
//  Functions
////// readThermistor ///////
This function reads the analog pin as shown below. Converts voltage signal
to a digital representation with analog to digital conversion. However, this is
done multiple times so that we can average it to eliminate measurement errors.
This averaged number is then used to calculate the resistance of the thermistor.
After this, the resistance is used to calculate the temperature of the
thermistor. Finally, the temperature is converted to celsius. Please refer to
the allaboutcircuits.com article for the specifics and general theory of this
process.
Quick Schematic in case you are too lazy to look at the site :P
          (Ground) ----\/\/\/-------|-------\/\/\/---- V_supply
                     R_balance      |     R_thermistor
                               Analog Pin
double readThermistor()
  // variables that live in this function
  double rThermistor = 0;            // Holds thermistor resistance value
  double tKelvin     = 0;            // Holds calculated temperature
  double tCelsius    = 0;            // Hold temperature in celsius
  double adcAverage  = 0;            // Holds the average voltage measurement
  int    adcSamples[SAMPLE_NUMBER];  // Array to hold each voltage measurement
  /* Calculate thermistor's average resistance:
     As mentioned in the top of the code, we will sample the ADC pin a few times
     to get a bunch of samples. A slight delay is added to properly have the
     analogRead function sample properly */
  for (int i = 0; i < SAMPLE_NUMBER; i++)
    adcSamples[i] = analogRead(thermistorPin);  // read from pin and store
    delay(10);        // wait 10 milliseconds
  /* Then, we will simply average all of those samples up for a "stiffer"
     measurement. */
    adcAverage += adcSamples[i];      // add all samples up . . .
  adcAverage /= SAMPLE_NUMBER;        // . . . average it w/ divide
  /* Here we calculate the thermistor’s resistance using the equation
     discussed in the article. */
  rThermistor = BALANCE_RESISTOR * ( (MAX_ADC / adcAverage) - 1);
  /* Here is where the Beta equation is used, but it is different
     from what the article describes. Don't worry! It has been rearranged
     algebraically to give a "better" looking formula. I encourage you
     to try to manipulate the equation from the article yourself to get
     better at algebra. And if not, just use what is shown here and take it
     for granted or input the formula directly from the article, exactly
     as it is shown. Either way will work! */
  tKelvin = (BETA * ROOM_TEMP) /
            (BETA + (ROOM_TEMP * log(rThermistor / RESISTOR_ROOM_TEMP)));
  /* I will use the units of Celsius to indicate temperature. I did this
     just so I can see the typical room temperature, which is 25 degrees
     Celsius, when I first try the program out. I prefer Fahrenheit, but
     I leave it up to you to either change this function, or create
     another function which converts between the two units. */
  tCelsius = tKelvin - 273.15;  // convert kelvin to celsius
  return tCelsius;    // Return the temperature in Celsius
You said nothing about what is wrong. Why is all your code double spaced?
Ho ya oups, the problem is that my temperature is not showing on my lcd but I have it on my serial monitor, so if someone knows how to show the serial monitor on my lcd it could be nice and I don’t know why my code is double spaced and I’m still starting in this
Have you tried running LCD library example sketches to verify the display hardware?
Edit:
However, it looks like you simply don't bother to write anything useful to the screen, in your code. Does the other text show up on the display, like the results of
Yes if I understand my lcd work
then you can
    lcd.print("It is ");
    lcd.print(currentTemperature);
Ok so if I do this
It’s gonna work?
Have you tried moving the cursor to the location you want to begin printing?
I actually made it work I didn't do it right.
