I have a SHT-85 sensor connected to my Arduino Uno with the following wiring:
1 SCL - A5 analog in
2 VDD - 3.3V
3 VSS - GND
4 SDA - A4 analog in
I installed the arduino-sht library to Arduino IDE and uploaded the following code:
#include <SHTSensor.h>
#include <Wire.h>
SHTSensor sht;
// To use a specific sensor instead of probing the bus use this command:
// SHTSensor sht(SHTSensor::SHT3X);
Wire.begin();
delay(1000); // let serial console settle
if (sht.init()) {
Serial.println("init(): success\n");
Serial.println("init(): failed\n");
sht.setAccuracy(SHTSensor::SHT_ACCURACY_MEDIUM); // only supported by SHT3x
if (sht.readSample()) {
Serial.println("SHT:\n");
Serial.println(" RH: ");
Serial.println(sht.getHumidity(), 2);
Serial.println("\n");
Serial.println(" T: ");
Serial.println(sht.getTemperature(), 2);
Serial.println("Error in readSample()\n");
delay(2000);
Now, this results in the Serial Monitor returning exactly nothing.
So something is wrong either in the wiring or in the code. I have already tried the following:
Switch the SCL and SDA. This results in the "init(): failed" and "error in readSample()" at every attempt at reading.
Use 5V instead. No change
Downgrade to earlier versions of the sht library. No change.
Somebody who has experienced the same problem? Any help is greatly appreciated!
