ElBerto
1
Hi guys, I would get signal from my old car ignition coil, here example waveform:
https://www.triumphexp.com/phile/8/227705/TEK0000.JPG
I was taking a look to similar topics:
https://europe1.discourse-cdn.com/arduino/original/4X/d/d/5/dd57d8ca064d832ab1addf6399d5adb98bf0aa9b.jpeg
but this circuit will change my coil waveform due to D4 diode (I don't understand why it's placed before D5, maybe should it placed behind....
I presume D4 is placed there to prevent inductive kick from the ignition coil.
jim-p
3
Isn't L1 a coil you wrap around the high tension lead for inductive pick-up.
There is no direct connection to the coil.
ElBerto
4
..but changing coil waveform I'll change behaviour of ignition. I don't want this.
I don't see issues about circuit simulation removing D4.
Original waveform:
D4 inserted:
system
Closed
6
