Hello folks. I'm using the ardustim project to generate the signal pattern of a specific phonic wheel. The code is the base code of the ardustim project. I only need to change the RPM of the wheel (the speed at which the pattern is generated) and change between two different wheel patterns. So i have 3 buttons and one selector: up, down and unit (if the units, tens, houndreds or thousands are changed) and the "selector" sets wheel 1 or wheel 2. Everything works fine but, SOMETIMES, when i change from one wheel to another, the pattern gets crazy and it starts generating a random signal. To recover the normal state the Arduino has to be restarted. Anyone knows what could be the issue?
Here is the first pattern, SOMETIMES when changing to the second wheel pattern the signal starts doing this random:
// Create button instances
#include <Bounce2.h>
Bounce button1 = Bounce();
Bounce button2 = Bounce();
Bounce button3 = Bounce();
Bounce button4 = Bounce();
#define BUTTON_PIN1 2
#define BUTTON_PIN2 3
#define BUTTON_PIN3 4
#define BUTTON_PIN4 5
int n_button2 = 0;
typedef enum {
UNITS,
TENS,
HUNDREDS,
THOUSANDS
} State;
State currentState = UNITS;
// Create display instance and configuration
#include <Adafruit_SSD1306.h>
#include <Adafruit_GFX.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
int delta = 1;
int line = 92; // starting line
uint8_t cursor; // cursor position
char buf[80]; // buffer data for the string name of the wheels
uint8_t px_tot = 105; // Alignement of RPM to the 105th pixel in X-axis
uint16_t w;
#include "defines.h"
#include "ardustim.h"
#include "enums.h"
#include "comms.h"
#include "storage.h"
#include "user_defaults.h"
#include "wheel_defs.h"
#include <avr/pgmspace.h>
#include <EEPROM.h>
/* Sensistive stuff used in ISR's */
// volatile uint8_t fraction = 0;
volatile bool reset_prescaler = false;
volatile bool normal = true;
volatile bool sweep_reset_prescaler = true; /* Force sweep to reset prescaler value */
volatile bool sweep_lock = false;
volatile uint8_t output_invert_mask = 0x00; /* Don't invert anything */
// volatile uint8_t sweep_direction = ASCENDING;
volatile byte total_sweep_stages = 0;
volatile uint8_t sweep_stage = 0;
volatile uint8_t prescaler_bits = 0;
volatile uint8_t last_prescaler_bits = 0;
volatile uint8_t mode = 0;
volatile uint16_t new_OCR1A = 1000; // sane default
volatile uint16_t edge_counter = 0;
/* Less sensitive globals */
uint8_t bitshift = 0;
//uint16_t sweep_low_rpm = 250;
//uint16_t sweep_high_rpm = 4000;
//uint16_t sweep_rate = 1;
sweep_step *SweepSteps; /* Global pointer for the sweep steps */
wheels Wheels[MAX_WHEELS] = {
/* Pointer to friendly name string, pointer to edge array, RPM Scaler, Number of edges in the array, whether the number of edges covers 360 or 720 degrees */
{ dizzy_four_cylinder_friendly_name, dizzy_four_cylinder, 0.25, 20, 90 },
{ dizzy_six_cylinder_friendly_name, dizzy_six_cylinder, 0.1666, 16, 360 },
/* Initialization */
serialSetup();
loadConfig();
// Configure input of the button (2-> LEFT, 3, -> RIGHT, 4-> INCREASE, 5-> SWITCH)
DDRD = 0; // Reset values of port D data direction register
DDRD &= ~(1 << DDD2) & ~(1 << DDD3) & ~(1 << DDD4) & ~( 1 << DDD5); // Set port 2, 3, 4, 5 as input
// Pullup resistor
PORTD = 0; // Reset values of port D data register
PORTD |= (1 << PORTD2) | (1 << PORTD3) | (1 << PORTD4) | (1 << PORTD5); // Enable pull-up resistor
button1.attach(BUTTON_PIN1);
button2.attach(BUTTON_PIN2);
button3.attach(BUTTON_PIN3);
button4.attach(BUTTON_PIN4);
button1.interval(50); // interval in ms
button2.interval(50); // interval in ms
button3.interval(50);
button4.interval(50);
// -------- display---------------------
if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3c)) {
//if(!display.begin(SSD1306_SWITCHCAPVCC, 0x7A)) {
Serial.println(F("SSD1306 allocation failed"));
for(;;);
display.setTextColor(WHITE);
display.setTextSize(2);
display.clearDisplay();
delay(2000);
show_wheel_name(); // Show name of the wheel
show_RPM(); // Show RPM
config_timer1();
} // End setup
/* Pumps the pattern out of flash to the port
* The rate at which this runs is dependent on what OCR1A is set to
* the sweeper in timer2 alters this on the fly to alow changing of RPM
* in a very nice way
ISR(TIMER1_COMPA_vect){
/* This is VERY simple, just walk the array and wrap when we hit the limit */
PORTB = output_invert_mask ^ pgm_read_byte(&Wheels[selected_wheel].edge_states_ptr[edge_counter]); /* Write it to the port */
/* Normal direction overflow handling */
if (normal){
edge_counter++;
if (edge_counter == Wheels[selected_wheel].wheel_max_edges){
edge_counter = 0;
/* The tables are in flash so we need pgm_read_byte() */
/* Reset Prescaler only if flag is set */
if (reset_prescaler){
TCCR1B &= ~((1 << CS10) | (1 << CS11) | (1 << CS12)); /* Clear CS10, CS11 and CS12 */
TCCR1B |= prescaler_bits;
/* Reset next compare value for RPM changes */
OCR1A = new_OCR1A; /* Apply new "RPM" from Timer2 ISR, i.e. speed up/down the virtual "wheel" */
uint16_t tmp_rpm = 0;
button1.update();
button2.update();
button3.update();
button4.update();
// Change wheel pattern
if (button4.fell()){
if (selected_wheel == 1){
selected_wheel = 0;
}else{
selected_wheel = 1;
config_timer1();
setRPM(wanted_rpm);
// INCREASE BUTTON
if (button2.fell()){
wanted_rpm += delta;
if (wanted_rpm >= 4000 || wanted_rpm<= 50){
wanted_rpm = 4000;
setRPM(wanted_rpm);
// DECREASE BUTTON
if (button1.fell()){
wanted_rpm -= delta;
if (wanted_rpm < 50 || wanted_rpm >= 4000){
wanted_rpm = 50;
setRPM(wanted_rpm);
// Change UNITS
if (button3.fell()){
currentState = (currentState == THOUSANDS) ? UNITS : (State)((int)currentState + 1);
switch(currentState){
case UNITS:
delta = 1;
line = 92;
case TENS:
delta = 10;
line = 80;
case HUNDREDS:
delta = 100;
line = 68;
case THOUSANDS:
delta = 1000;
line = 56;
void config_timer1(){
cli(); // stop interrupts
// Configure pin 8 and 9 as outputs
DDRB = 0;
DDRB |= (1 << DDB0) && (1 << DDB1);
PORTB = 0;
/* Configuring TIMER1 (pattern generator) */
// Set timer1 to generate pulses
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = 0;
// Set compare register to sane default
OCR1A = 1000; /* 8000 RPM (60-2) */
// Turn on CTC mode
TCCR1B |= (1 << WGM12); // Normal mode (not PWM)
// Set prescaler to 1
TCCR1B |= (1 << CS10); /* Prescaler of 1 */
// Enable output compare interrupt for timer channel 1 (16 bit)
TIMSK1 |= (1 << OCIE1A);
// Turn on CTC mode
sei(); // Enable interrupts
reset_new_OCR1A(wanted_rpm);
void show_wheel_name(){
display.setCursor(0, 0);
strcpy_P(buf, Wheels[selected_wheel].decoder_name);
display.print(buf);
uint8_t get_txt_rpm_width(uint8_t wanted_rpm){
int16_t x, y;
uint16_t h;
display.getTextBounds(String(wanted_rpm), 0, 0, &x, &y, &w, &h);
return w;
void show_RPM(){
// Print "RPM:"
display.setCursor(9, 47);
display.print("RPM:");
// Print rpm numerical value
display.print(wanted_rpm);
px_tot = get_txt_rpm_width(wanted_rpm);
display.setCursor(px_tot - w, 47);
display.drawLine(line, 63, line + 12, 63, SSD1306_WHITE);
display.display();
void reset_new_OCR1A(uint32_t new_rpm){
uint32_t tmp;
uint8_t bitshift;
uint8_t tmp_prescaler_bits;
tmp = (uint32_t)(8000000.0/(Wheels[selected_wheel].rpm_scaler * (float)(new_rpm < 10 ? 10:new_rpm)));
get_prescaler_bits(&tmp, &tmp_prescaler_bits, &bitshift);
new_OCR1A = (uint16_t)(tmp >> bitshift);
prescaler_bits = tmp_prescaler_bits;
uint8_t get_bitshift_from_prescaler(uint8_t *prescaler_bits){
switch (*prescaler_bits){
case PRESCALE_1024:
return 10;
case PRESCALE_256:
return 8;
case PRESCALE_64:
return 6;
case PRESCALE_8:
return 3;
case PRESCALE_1:
return 0;
return 0;
//! Gets prescaler enum and bitshift based on OC value
void get_prescaler_bits(uint32_t *potential_oc_value, uint8_t *prescaler, uint8_t *bitshift){
if (*potential_oc_value >= 16777216){
*prescaler = PRESCALE_1024;
*bitshift = 10;
else if (*potential_oc_value >= 4194304){
*prescaler = PRESCALE_256;
*bitshift = 8;
else if (*potential_oc_value >= 524288){
*prescaler = PRESCALE_64;
*bitshift = 6;
else if (*potential_oc_value >= 65536){
*prescaler = PRESCALE_8;
*bitshift = 3;
else{
*prescaler = PRESCALE_1;
*bitshift = 0;
