You are very talented, that worked perfectly. Now when Temp goes below freezing, then goes above freezing, the flag is reset allowing for a subsequent SMS.
One minor Issue, I'm attempting to include the temperature at the point at which the bool flag is triggered for cold, but I cant seem to figure it out. When I create another SMS variable with
const char * text_messageF = tempBuff; I can only send either tempBuff, or "FREEZING!", but not both. I tried doing if (!fona.sendSMS(phone_number, text_message2, text_messageF)) which didn't work, I also tried const char * text_messageF = tempBuff + "FREEZING!"; which resulted in no joy and finally if (!fona.sendSMS(phone_number, text_message2, text_messageF)). Do you have any advice for this? I tried doing something with sprintf but erased it.
tempC = sensors.getTempCByIndex(0);
tempF = (tempC * 1.8) + 32;
dtostrf(tempF,1, 2, tempBuff);
// For SIM7000 cellular shield
#include "Adafruit_FONA.h" // https://github.com/botletics/SIM7000-LTE-Shield/tree/master/Code
#include <SoftwareSerial.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#define ONE_WIRE_BUS 4
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
DeviceAddress insideThermometer;
// For SIM7000 shield
#define FONA_PWRKEY 6
#define FONA_RST 7
#define FONA_TX 10 // Microcontroller RX
#define FONA_RX 11 // Microcontroller TX
#define LED 13
// Using SoftwareSerial
SoftwareSerial fonaSS = SoftwareSerial(FONA_TX, FONA_RX);
SoftwareSerial *fonaSerial = &fonaSS;
Adafruit_FONA_LTE fona = Adafruit_FONA_LTE();
uint8_t readline(char *buff, uint8_t maxbuff, uint16_t timeout = 0);
char imei[16] = {0}; // Use this for device ID
char replybuffer[255]; // Large buffer for replies
uint8_t type;
uint8_t counter = 0;
bool opened = false;
bool cold = false;
char tempBuff[12];
char URL[100]; // Make sure this is long enough for your request URL
//char body[100]; // Only need this is you're doing an HTTP POST request
//const int FLOWSWITCH = 2; // Use pin 2 to wake up the Uno/Mega
const int buttonPin = 3;
int buttonState = 0; // current state of the button
int lastButtonState = 0; // previous state of the button
//int buttonState4 = 0; // current state of the button
//int lastButtonState4 = 0; // previous state of the button
const char * phone_number = "+18000000006"; // Include country code, only numbers
const char * text_message1 = "FULL!"; // Change to suit your needs
const char * text_message2 = "FREEZING!"; // Change to suit your needs
int flowPin = 2; //This is the input pin on the Arduino
double flowRate; //This is the value we intend to calculate.
unsigned int flowMilliLitres;
unsigned long totalMilliLitres;
volatile int count; //This integer needs to be set as volatile to ensure it updates correctly during the interrupt process.
float tempC;
float tempF;
float tLimit = 45.0;
// while (!Serial) delay(1); // Wait for serial, for debug
Serial.println(F("*** Burgalert 7000 ***"));
pinMode(flowPin, INPUT); //Sets the pin as an input
attachInterrupt(0, Flow, RISING); //Configures interrupt 0 (pin 2 on the Arduino Uno) to run the function "Flow"
flowRate = 0.0;
totalMilliLitres = 0;
//pinMode(BUTTON, INPUT); // For the interrupt wake-up to work
pinMode(FONA_RST, OUTPUT);
digitalWrite(FONA_RST, HIGH); // Default state
pinMode(FONA_PWRKEY, OUTPUT);
pinMode(buttonPin, INPUT);
powerOn(true); // Power on the module
moduleSetup(); // Establish first-time serial comm and print IMEI
fona.setNetworkSettings(F("hologram")); // For Hologram SIM card, change appropriately
Serial.print("Locating devices...");
sensors.begin();
Serial.print("Found ");
Serial.print(sensors.getDeviceCount(), DEC);
Serial.println(" devices.");
// report parasite power requirements
// Serial.print("Parasite power is: ");
// if (sensors.isParasitePowerMode()) Serial.println("ON");
// else Serial.println("OFF");
if (!sensors.getAddress(insideThermometer, 0)) Serial.println("Unable to find address for Device 0");
//if (!oneWire.search(insideThermometer)) Serial.println("Unable to find address for insideThermometer");
// show the addresses we found on the bus
Serial.print("Device 0 Address: ");
printAddress(insideThermometer);
// set the resolution to 9 bit (Each Dallas/Maxim device is capable of several different resolutions)
sensors.setResolution(insideThermometer, 9);
Serial.print("Device 0 Resolution: ");
Serial.print(sensors.getResolution(insideThermometer), DEC);
Serial.print("Requesting temperatures...");
sensors.requestTemperatures(); // Send the command to get temperatures
Serial.println("DONE");
printTemperature(insideThermometer); // Use a simple function to print out the data
count = 0; // Reset the counter so we start counting from 0 again
//interrupts(); //Enables interrupts on the Arduino
delay (1000); //Wait 1 second
// noInterrupts(); //Disable the interrupts on the Arduino
// Only send SMS if the switch was closed
//Start the math
flowRate = (count * 2.25); //Take counted pulses in the last second and multiply by 2.25mL
flowRate = flowRate * 60; //Convert seconds to minutes, giving you mL / Minute
flowRate = flowRate / 1000; //Convert mL to Liters, giving you Liters / Minute
totalMilliLitres += flowRate;
buttonState = digitalRead(buttonPin);
Serial.println(flowRate); //Print the variable flowRate to Serial
Serial.println(totalMilliLitres);
if (buttonState == HIGH && lastButtonState == LOW || totalMilliLitres > 300 && totalMilliLitres - flowRate <= 300) {
opened = false;
lastButtonState = buttonState;
FullSMS ();
if (tempF < tLimit && cold == false) {
ColdSMS ();
cold = true;
else if (tempF > tLimit+2.0 && cold == true) {
cold = false;
// Power on/off the module
void powerOn(bool state) {
if (state) {
Serial.println(F("Turning on SIM7000..."));
digitalWrite(FONA_PWRKEY, LOW);
delay(100); // Turn on module
digitalWrite(FONA_PWRKEY, HIGH);
delay(4500); // Give enough time for the module to boot up before communicating with it
else {
Serial.println(F("Turning off SIM7000..."));
fona.powerDown(); // Turn off module
void moduleSetup() {
fonaSS.begin(115200); // Default SIM7000 shield baud rate
Serial.println(F("Configuring to 9600 baud"));
fonaSS.println("AT+IPR=9600"); // Set baud rate
delay(100); // Short pause to let the command run
fonaSS.begin(9600);
if (! fona.begin(fonaSS)) {
Serial.println(F("Couldn't find FONA"));
while (1); // Don't proceed if it couldn't find the device
type = fona.type();
Serial.println(F("FONA is OK"));
Serial.print(F("Found "));
switch (type) {
case SIM7000A:
Serial.println(F("SIM7000A (American)")); break;
case SIM7000C:
Serial.println(F("SIM7000C (Chinese)")); break;
case SIM7000E:
Serial.println(F("SIM7000E (European)")); break;
case SIM7000G:
Serial.println(F("SIM7000G (Global)")); break;
default:
Serial.println(F("???")); break;
// Print module IMEI number.
uint8_t imeiLen = fona.getIMEI(imei);
if (imeiLen > 0) {
Serial.print("Module IMEI: "); Serial.println(imei);
bool netStatus() {
int n = fona.getNetworkStatus();
Serial.print(F("Network status ")); Serial.print(n); Serial.print(F(": "));
if (n == 0) Serial.println(F("Not registered"));
if (n == 1) Serial.println(F("Registered (home)"));
if (n == 2) Serial.println(F("Not registered (searching)"));
if (n == 3) Serial.println(F("Denied"));
if (n == 4) Serial.println(F("Unknown"));
if (n == 5) Serial.println(F("Registered roaming"));
if (!(n == 1 || n == 5)) return false;
else return true;
void Flow()
count++; //Every time this function is called, increment "count" by 1
void FullSMS () {
while (!netStatus()) {
Serial.println(F("Failed to connect to cell network, retrying..."));
delay(2000); // Retry every 2s
Serial.println(F("Connected to cell network!"));
// Send a text to your phone!
if (!fona.sendSMS(phone_number, text_message1)) {
Serial.println(F("Failed to send text!"));
else {
Serial.println(F("Sent text alert!"));
void ColdSMS () {
if (!fona.sendSMS(phone_number, text_messageF)) {
else {
void printTemperature(DeviceAddress deviceAddress)
// method 1 - slower
//Serial.print("Temp C: ");
//Serial.print(sensors.getTempC(deviceAddress));
//Serial.print(" Temp F: ");
//Serial.print(sensors.getTempF(deviceAddress)); // Makes a second call to getTempC and then converts to Fahrenheit
// method 2 - faster
float tempC = sensors.getTempC(deviceAddress);
if (tempC == DEVICE_DISCONNECTED_C)
Serial.println("Error: Could not read temperature data");
return;
Serial.print(tempC);
Serial.println(DallasTemperature::toFahrenheit(tempC)); // Converts tempC to Fahrenheit
// function to print a device address
void printAddress(DeviceAddress deviceAddress)
for (uint8_t i = 0; i < 8; i++)
if (deviceAddress[i] < 16) Serial.print("0");
Serial.print(deviceAddress[i], HEX);
Edit: also tried const char * Text3[] = {text_messageF, text_message2};
and then if (!fona.sendSMS(phone_number, Text3))
but gave me an error saying error: no matching function for call to 'Adafruit_FONA_LTE::sendSMS(const char*&, const char* [2])'
which I take makes sense in regards to my attempt because Text3 is has an array of two values, text_messageF and text_message2
