Hello Everyone,
I have a sim7000G lilygo module by espresiff that has nothing connected. It only has power and a simcard used by hologram. It receives data via espnow from a esp32 nearby and is supposed to send to the server. About 2 months ago everything was perfect, except now I cannot post the data on the server. Server has been tested to make sure it’s running using CURL commands, etc. I am 100% sure the server is good. I checked security groups, ports (all traffic) etc. I was able to send data from my terminal to the server database so no problems there. I just keep getting an error below:
00:10:00.588 -> Setting network to automatic LTE/NB-IoT/GSM...
00:10:01.595 -> Waiting for network... ✅ Network connected
00:10:12.971 -> Connecting to APN: hologram
00:10:15.430 -> ✅ GPRS connected
00:10:15.430 -> Modem IP: 10.247.105.179
00:10:15.430 -> Network type: 2
00:10:15.467 -> Operator: T-Mobile Hologram
00:10:15.467 -> Signal quality: 20
00:10:15.539 -> ✅ ESP-NOW ready
00:11:40.728 -> 📡 ESP-NOW packet received and queued
00:11:40.728 -> Posting JSON: {"id":1,"x_avg":0.00,"y_avg":0.00,"z_avg":0.00,"temp_f":72.95,"time_str":"01:10:39"}
00:11:41.697 -> Signal quality: 99
00:11:41.697 -> Connecting to server 3.138.117.223:80
00:11:56.221 -> 📡 ESP-NOW packet received and queued
00:12:59.695 -> ❌ TCP connection failed, retrying...
00:13:02.726 -> Connecting to server 3.138.117.223:80
00:14:20.699 -> ❌ TCP connection failed, retrying...
00:14:23.713 -> Connecting to server 3.138.117.223:80
00:15:41.716 -> ❌ TCP connection failed, retrying...
00:15:44.734 -> ❌ Could not connect after 3 attempts → will try again next loop
00:15:49.737 -> Posting JSON: {"id":1,"x_avg":0.00,"y_avg":0.00,"z_avg":0.00,"temp_f":72.95,"time_str":"01:10:39"}
00:15:50.705 -> Signal quality: 99
00:15:50.705 -> Connecting to server 3.138.117.223:80
Here is the code:
#define TINY_GSM_MODEM_SIM7000
#include <TinyGsmClient.h>
#include <HardwareSerial.h>
#include <esp_now.h>
#include <WiFi.h>
// SERIAL SETTINGS
#define SerialMon Serial
#define SerialAT Serial1
#define UART_BAUD 115200
#define PWR_PIN 4
#define PIN_TX 27
#define PIN_RX 26
// GSM SETTINGS
const char apn[] = "hologram";
const char serverIP[] = "3.138.117.223"; // Your EC2 public IP
const uint16_t serverPort = 80;
const char serverResource[] = "/upload.php"; // Your PHP endpoint
// GSM OBJECTS
TinyGsm modem(SerialAT);
TinyGsmClient client(modem);
// DATA STRUCT
typedef struct {
int id;
float x_avg;
float y_avg;
float z_avg;
float temp_f;
char time_str[9]; // "HH:MM:SS"
} SensorData;
// Queue for storing received packets (max 10 packets in memory)
#define MAX_QUEUE 10
SensorData packetQueue[MAX_QUEUE];
volatile int queueHead = 0;
volatile int queueTail = 0;
// ESP-NOW CALLBACK
void OnDataRecv(const esp_now_recv_info_t *info, const uint8_t *incomingData, int len) {
if (len == sizeof(SensorData)) {
int nextTail = (queueTail + 1) % MAX_QUEUE;
if (nextTail != queueHead) { // Queue not full
memcpy(&packetQueue[queueTail], incomingData, sizeof(SensorData));
queueTail = nextTail;
SerialMon.println("📡 ESP-NOW packet received and queued");
SerialMon.println("⚠️ Queue full, packet dropped");
// SETUP
SerialMon.begin(115200);
delay(100);
// Init GSM
pinMode(PWR_PIN, OUTPUT);
digitalWrite(PWR_PIN, HIGH);
delay(300);
digitalWrite(PWR_PIN, LOW);
SerialAT.begin(UART_BAUD, SERIAL_8N1, PIN_RX, PIN_TX);
SerialMon.println("----- Initializing GSM -----");
if (!modem.init()) {
SerialMon.println("❌ Modem init failed!");
while (true);
SerialMon.println("✅ Modem initialized");
// Automatic network selection
SerialMon.println("Setting network to automatic LTE/NB-IoT/GSM...");
modem.sendAT("+CNMP=2"); // Automatic network mode (GSM/LTE auto)
modem.sendAT("+CMNB=2"); // Automatic NB-IoT/LTE-M selection
SerialMon.print("Waiting for network...");
if (!modem.waitForNetwork()) {
SerialMon.println(" ❌ Failed to connect to network");
while (true);
SerialMon.println(" ✅ Network connected");
SerialMon.print("Connecting to APN: "); SerialMon.println(apn);
if (!modem.gprsConnect(apn, "", "")) {
SerialMon.println("❌ GPRS connection failed");
while (true);
SerialMon.println("✅ GPRS connected");
SerialMon.print("Modem IP: "); SerialMon.println(modem.getLocalIP());
// Show current network info
SerialMon.print("Network type: "); SerialMon.println(modem.getNetworkMode());
SerialMon.print("Operator: "); SerialMon.println(modem.getOperator());
SerialMon.print("Signal quality: "); SerialMon.println(modem.getSignalQuality());
// Init ESP-NOW
WiFi.mode(WIFI_STA);
if (esp_now_init() != ESP_OK) {
SerialMon.println("❌ ESP-NOW init failed!");
while (true);
esp_now_register_recv_cb(OnDataRecv);
SerialMon.println("✅ ESP-NOW ready");
// LOOP
// Check if there are queued packets
if (queueHead != queueTail) {
SensorData data = packetQueue[queueHead];
queueHead = (queueHead + 1) % MAX_QUEUE;
// Build JSON string
String json = "{";
json += "\"id\":" + String(data.id) + ",";
json += "\"x_avg\":" + String(data.x_avg, 2) + ",";
json += "\"y_avg\":" + String(data.y_avg, 2) + ",";
json += "\"z_avg\":" + String(data.z_avg, 2) + ",";
json += "\"temp_f\":" + String(data.temp_f, 2) + ",";
json += "\"time_str\":\"" + String(data.time_str) + "\"";
json += "}";
SerialMon.println("Posting JSON: " + json);
// Check signal quality first
int rssi = modem.getSignalQuality();
SerialMon.print("Signal quality: "); SerialMon.println(rssi);
if (rssi < 10) {
SerialMon.println("❌ Weak signal, will retry later");
// Put packet back in queue
queueHead = (queueHead - 1 + MAX_QUEUE) % MAX_QUEUE;
delay(5000);
return;
// Connect to server with retry (3 attempts)
bool connected = false;
for (int i = 0; i < 3; i++) {
SerialMon.print("Connecting to server "); SerialMon.print(serverIP); SerialMon.print(":"); SerialMon.println(serverPort);
if (client.connect(serverIP, serverPort)) {
connected = true;
SerialMon.println("❌ TCP connection failed, retrying...");
delay(3000);
if (!connected) {
SerialMon.println("❌ Could not connect after 3 attempts → will try again next loop");
delay(5000);
return;
SerialMon.println("✅ TCP connection established");
// Build HTTP POST request
String httpRequest = String("POST ") + serverResource + " HTTP/1.1\r\n";
httpRequest += "Host: " + String(serverIP) + "\r\n";
httpRequest += "Content-Type: application/json\r\n";
httpRequest += "Content-Length: " + String(json.length()) + "\r\n";
httpRequest += "Connection: close\r\n\r\n";
httpRequest += json;
// Send HTTP POST
client.print(httpRequest);
SerialMon.println("HTTP POST sent. Waiting for response...");
// Wait for server response (30s timeout)
long timeout = millis() + 30000;
bool received = false;
while (client.connected() && millis() < timeout) {
while (client.available()) {
char c = client.read();
SerialMon.print(c); // Prints raw server response
received = true;
if (!received) {
SerialMon.println("\n❌ No response received → check server/firewall");
delay(5000);
SerialMon.println("\n✅ Response received → server got the request");
client.stop();
SerialMon.println("TCP connection closed\n");
Any suggestions would be great. The code that worked perfectly before with ATT is below, but even it started producing a watchdog error as soon as it received the data and tried to send it out:
#include <WiFi.h>
#include <SD.h>
#include <SPI.h>
#include <esp_task_wdt.h>
#include <Preferences.h>
#define TINY_GSM_RX_BUFFER 1024
#define DUMP_AT_COMMANDS
#define TINY_GSM_DEBUG SerialMon
#define GSM_AUTOBAUD_MIN 9600
#define GSM_AUTOBAUD_MAX 115200
#define TINY_GSM_USE_GPRS true
#define TINY_GSM_USE_WIFI false
#define GSM_PIN ""
// SD card pins
#define SD_MISO 2
#define SD_MOSI 15
#define SD_SCLK 14
#define SD_CS 13
#include <ArduinoHttpClient.h>
#ifdef DUMP_AT_COMMANDS
#include <StreamDebugger.h>
StreamDebugger debugger(SerialAT, SerialMon);
TinyGsm modem(debugger);
#else
#endif
#define PIN_DTR 25
#define PIN_TX 27
#define PIN_RX 26
#define PWR_PIN 4
HttpClient http(client, "3.148.106.137", 80); // Replace with your server IP or domain
// --- Customize these ---
//213x.m2m.com.attz
//hologram
const char gprsUser[] = "";
const char gprsPass[] = "";
// Struct to match transmitter
typedef struct {
int id;
float x_avg;
float y_avg;
float z_avg;
float temp_f;
} SensorData;
File dataFile;
// Function declarations
void initGSM();
void connectAPN();
bool sendDataToServer(SensorData data);
void savePacket(const SensorData &data, const char* status);
void setupSD();
void initESPNow();
// ESP-NOW Receive Callback
SensorData data;
memcpy(&data, incomingData, sizeof(data));
Serial.println("📡 Received Data:");
Serial.printf("Node ID: %d\n", data.id);
Serial.printf("Time: %s\n", data.time_str);
Serial.printf("X Peak Freq: %.2f Hz\n", data.x_avg);
Serial.printf("Y Peak Freq: %.2f Hz\n", data.y_avg);
Serial.printf("Z Peak Freq: %.2f Hz\n", data.z_avg);
Serial.printf("Temp (°F): %.2f\n", data.temp_f);
Serial.println("------------------------");
if (sendDataToServer(data)) {
Serial.println("✅ Data sent successfully!");
savePacket(data, "SENT");
Serial.println("❌ Sending failed.");
savePacket(data, "FAILED");
delay(100);
initGSM();
connectAPN();
setupSD();
initESPNow();
// Optional: Retry sending failed data from SD card here
// GSM Setup
void initGSM() {
Serial.println("📶 Initializing GSM...");
delay(300);
Serial.println("❌ Modem init failed!");
ESP.restart();
Serial.println("✅ Modem ready.");
Serial.println("Modem Name: " + modem.getModemName());
Serial.println("Modem Info: " + modem.getModemInfo());
if (GSM_PIN && modem.getSimStatus() != 3) {
modem.simUnlock(GSM_PIN);
modem.sendAT("+CFUN=1");
modem.waitResponse();
if (!modem.setNetworkMode(2)) {
Serial.println("❌ Failed to set network mode.");
if (!modem.setPreferredMode(3)) {
Serial.println("❌ Failed to set preferred mode.");
Serial.println("📱 GSM module ready.");
void connectAPN() {
Serial.print("🌐 Connecting to APN: ");
Serial.println(apn);
Serial.println("❌ No network.");
ESP.restart();
if (!modem.gprsConnect(apn, gprsUser, gprsPass)) {
Serial.println("❌ GPRS connection failed.");
ESP.restart();
Serial.println("✅ Connected to cellular network.");
// HTTP Upload
bool sendDataToServer(SensorData data) {
String json = "{";
json += "}";
Serial.println("🌐 Posting data: " + json);
http.beginRequest();
http.post(serverResource);
http.sendHeader("Content-Type", "application/json");
http.sendHeader("Content-Length", json.length());
http.beginBody();
http.print(json);
http.endRequest();
int statusCode = http.responseStatusCode();
String response = http.responseBody();
Serial.print("📡 Status code: ");
Serial.println(statusCode);
Serial.print("Response: ");
Serial.println(response);
return (statusCode == 200);
// SD Card Handling
void setupSD() {
SPI.begin(SD_SCLK, SD_MISO, SD_MOSI, SD_CS);
if (!SD.begin(SD_CS)) {
Serial.println("❌ SD card init failed.");
Serial.println("✅ SD card ready.");
void savePacket(const SensorData &data, const char* status) {
dataFile = SD.open("/data.txt", FILE_APPEND);
if (dataFile) {
dataFile.print(data.id);
dataFile.print(",");
dataFile.print(data.time_str);
dataFile.print(data.x_avg, 2);
dataFile.print(data.y_avg, 2);
dataFile.print(data.z_avg, 2);
dataFile.print(data.temp_f, 2);
dataFile.println(status);
dataFile.close();
Serial.printf("💾 Data saved to SD with status: %s\n", status);
Serial.println("❌ Failed to write to SD card.");
// ESP-NOW Setup
void initESPNow() {
Serial.println("❌ ESP-NOW init failed!");
ESP.restart();
Serial.println("✅ ESP-NOW ready.");
Any help would be 1000000000% helpful please
