Title
SIM7600 works for several days, then stops responding or loses network registration until power-cycled
Hi everyone,
I'm maintaining a remote computer vision system that has been deployed in the field. The system generally works well, but after running continuously for several days, the GSM/LTE modem occasionally stops functioning and the device can no longer communicate over the cellular network.
Hardware
Jetson Nano
SIM7600-series LTE/GSM module connected via USB serial
Solar-powered system with battery backup
Outdoor installation
Software
Python application
HTTP and SMS communication using AT commands
The software periodically checks:
SIM status
Network registration (
AT+CREG?/AT+CEREG?) -
Signal quality (
AT+CSQ) -
PDP context before starting communication
When communication fails, the modem may exhibit one or more of the following behaviors:
Stops responding to AT commands.
Loses network registration and never reconnects.
Communication times out indefinitely.
Recovers only after the modem is completely power-cycled.
I've already implemented software recovery methods, including:
Reinitializing the serial connection
AT+CFUN=0 -
AT+CFUN=1 -
Re-running the network registration sequence
These sometimes help temporarily, but eventually the same problem returns. A complete power disconnect is the only recovery method that appears to be consistently reliable.
My questions
For those who have deployed SIM7600 modules in unattended systems, what are the most common root causes of this type of long-term failure?
I'm particularly interested in whether the issue is more likely to be related to:
Power supply instability during LTE transmit bursts
Battery voltage drops under load
Thermal effects inside an outdoor enclosure
USB/serial interface lockups on Linux
SIM7600 firmware hangs or known firmware bugs
Network registration problems in weak-signal areas
Mobile operator or cellular network behavior
Long-running memory/resource issues
I'd also appreciate advice on:
The best diagnostic steps to determine the actual cause
Whether logging additional AT commands would help identify the failure
Whether a hardware watchdog or dedicated modem power switch is considered standard practice for reliable field deployments
Best practices for designing an automatic recovery strategy for an unattended device
If it would help with troubleshooting, I can provide:
AT command logs before and after the failure
dmesglogs from the Jetson -
Power supply specifications and measurements
Antenna type and installation details
Signal quality history
Temperature/environmental conditions
The Python recovery code currently in use
I'd appreciate any suggestions from people who have experienced similar long-term reliability issues with the SIM7600 or similar LTE modules in production deployments.
