SIM800L EVB + Arduino MEGA2560
Hello there, I keep having a problem with my SIM800L EVB, everything seems to work, I can make call from it and recive SMS, but I can't send an SMS from it.
In the serial monitor everything seems to be fine, I recive the respons "OK" to every request that I give, I just don't get the message on my phone. I did not hat this problem while using an Arduino UNO.
For the RX pin I use pin 10, and for TX pin I use pin 11 on the Arduino Mega.
I have removed the number from the code, but I checked it with the call function and it worked, so the number entered is valid.
#include <SoftwareSerial.h>
SoftwareSerial sim(11, 10);
int _timeout;
String _buffer;
String number = "";
  _buffer.reserve(50);
  Serial.println("System Started...");
  sim.begin(9600);
  Serial.println("Type s to send an SMS, r to receive an SMS, and c to make a call");
  if (Serial.available() > 0) {
    switch (Serial.read()) {
      case 's':
        SendMessage();
      case 'r':
        RecieveMessage();
      case 'c':
        callNumber();
      case 'd':
        ClearMessages();
  if (sim.available() > 0) {
    Serial.write(sim.read());
void SendMessage() {
  sim.println("AT+CMGF=1");    // Sets the GSM Module in Text Mode
  delay(200);
  sim.println("AT+CMGS=\"" + number + "\"\r"); // Mobile phone number to send message
  delay(200);
  String SMS = "Hello, how are you?";
  sim.println(SMS);
  delay(100);
  sim.println((char)26); // ASCII code of CTRL+Z
  delay(200);
  _buffer = _readSerial();
void RecieveMessage() {
  Serial.println("SIM800L Read an SMS");
  delay(200);
  sim.println("AT+CNMI=1,2,0,0,0"); // AT Command to receive a live SMS
  delay(200);
  Serial.write("Unread Message done");
String _readSerial() {
  _timeout = 0;
  while (!sim.available() && _timeout < 12000 ) {
    delay(13);
    _timeout++;
  if (sim.available()) {
    return sim.readString();
void callNumber() {
  sim.print(F("ATD"));
  sim.print(number);
  sim.print(F(";\r\n"));
  Serial.println(_buffer);
void ClearMessages() {
  // Clear all SMS messages (both read and unread)
  sim.println("AT+CMGD=1,4");
  delay(5000);
I do not think there is any problem with your code or setup. You can check this thread. [resolved] SIM800L GSM Module on arduino, AT>OK, Receive SMS but don't send
If you have a Raspberry Pi, you can cross-check your module with this code:
Interactive Voice Response System With Raspberry Pi 4 & SIM800L - The Engineering Projects
