SIM800L sending SMS issue
Hi I'm new to the forum, and this is my school project. It is involved a SIM800L comm. module. I'm using an Arduino Mini Pro 5V 16Mhz as my microcontroller. I followed the guide from YT and had the SIM800L connected accordingly. I was testing the SIM800L with an examples code and testing the AT commands on the serial monitor. I got it send out all calls, but it could not send out text messages. I attached my code and the result I received. After the AT+CMGS="+1832#######", it did not respond back with anything. Any help or guidance will be appreciated.
my code:
#include <SoftwareSerial.h>
SoftwareSerial mySerial(5, 4); // RX, TX
mySerial.begin(9600);
if (mySerial.available()) {
Serial.write(mySerial.read());
if (Serial.available()) {
mySerial.write(Serial.read());
The result I got back:
AT
OK
AT+CPIN?
+CPIN: READY
OK
ATD+ +1832#######
OK
AT+CMGF=1
OK
AT+CMGS="1832#######"
/> Hi
I was expecting a response such as +CMGS:# , but nothing showed.
It might be worth reading the AT command reference, or using a pre tested SMS library.
It looks like you’ve missed the last part of sending a text message.
+CMGS… wait for prompt… send text… terminate the message, then you’ll get the OK/ERROR responses
You have to terminate the message with a CNTL-Z character. Problem is you can't send this character from the Serial Monitor.
Use the following, and terminate your message with "*". This code will substitute with CNTL-Z before sending to the SIM800.
Instead of
Replace with...
if (Serial.available() > 0)
  char c = Serial.read();
  if c == '*'
   mySerial.write(0x1A);  // Replace with CNTL-Z
    mySerial.write(c);
Thank you so much, this works, but I had to change
if c == '*'
to
if (c == '*')
to compile successfully
Yep... typo on my part.
