SIM800L Sending SMS to Multiple Numbers
let's try to get the GPS working first by testing this code, I haven't tested it though
#include <TinyGPS++.h>
#define neo Serial
TinyGPSPlus gps;
String lati = " ";
String longi = " ";
neo.begin(9600);
  if (neo.available())  {
    while (neo.available() > 0) {
      gps.encode(neo.read());
      if (gps.location.isUpdated()) {
       lati = String(gps.location.lat(), 8);
       longi = String(gps.location.lng(), 6);
  static uint32_t prev = 0;
  if ( millis() - prev >= 500 ) {
   prev = millis();
   Serial.println("lati: "+lati);
   Serial.println("longi: "+longi);
lati and longi are in the serial monitor but no coordinates. Just to verify that the GPS is working, I uploaded the old code and tested it and it worked that way. But then it only sends to me. So should I have the GPS modules TX and RX pins plugged into the Arduino Nano's RX and TX pins?
@KASSIMSAMJI YOU GOT IT WORKING!!! Thanks a bunch! I moved the GPS module closer to a window and BAM! It worked. Thank you and everyone else who helped me with this issue. I marked the solution box up in the prior code you sent. Thank you again.
Just in case anyone is interested, here is the final code. I had to put all the GSM Listening functions back in, as well as move the pins from the RX and TX back to pins 8 & 9 on the Arduino. But the way @KASSIMSAMJI and @mfusco setup the code was perfect. Thanks again to everyone, and enjoy this project.
CODE
#include <SoftwareSerial.h>
SoftwareSerial GSM(11, 10);
SoftwareSerial neo(8, 9);
String textMessage;
String lampState;
String lati = "";
String longi = "";
#define redLed    3
#define greenLed  5
#define blueLed   6
const int relay = 12;
TinyGPSPlus gps;
  pinMode(redLed, OUTPUT);
  pinMode(greenLed, OUTPUT);
  pinMode(blueLed, OUTPUT);
  pinMode(relay, OUTPUT);
  digitalWrite(redLed, HIGH);
  delay(85);
  digitalWrite(redLed, LOW);
    digitalWrite(greenLed, HIGH);
  delay(85);
  digitalWrite(greenLed, LOW);
    digitalWrite(blueLed, HIGH);
  delay(85);
  digitalWrite(blueLed, LOW);
  // digitalWrite(relay, HIGH);
  GSM.begin(9600);
  neo.begin(9600);
  GSM.listen();
  delay(5000);
  Serial.print("GSM ready...\r\n");
  GSM.print("AT+CMGF=1\r\n");
  GSM.print("AT+CNMI=2,2,0,0,0\r\n");
  GSM.listen();
  delay(2);
  while (GSM.available() > 0) {
    textMessage = GSM.readString();
    Serial.print(textMessage);
    delay(10);
  neo.listen();
   if (textMessage.indexOf("GETLOC") >= 0) {
    smartDelay(1000);
    String array_string[20];
    string_splitting(textMessage,array_string,'\"'); // split it at "
    String NUMBER = array_string[1];   // we have the phone number here
    Serial.println("GPS data Recived\r\n");
    textMessage = "";
    GSM.println("AT+CMGS=\"" + NUMBER + "\"\r");
    String pesan = "https://maps.google.com/?q=" + lati + "," + longi;
    GSM.print(pesan);
    GSM.write(0x1a);
    GSM.println("AT+CMGD=1,4");
static void smartDelay(unsigned long ms) {
  unsigned long start = millis();
  do {
    neo.listen();
    delay(2);
    while (neo.available())
  } while (millis() - start < ms);
  Serial.println(lati);
  Serial.println(longi);
void string_splitting(String splitMsg, String bb[], char delimiter) {
  int counter = 0 ;
  for ( int i = 0 ; i < splitMsg.length() ; i ++ ) {
    if ( splitMsg.charAt(i) == delimiter ) {
      counter++;
    else {
      bb[counter] +=  splitMsg.charAt(i) ;
SCHEMATIC
