Sim900 At commands send
Hello guys, i cant write the correct code about Receiving At commands via sms.
Can someone help me?
I need to receive sms from my Sim900 with signal check command
do you have the SIM900 responding to AT commands
what Arduino board are you using?
Arduino Uno with sim900
have you managed to get AT commands to work?
I no longer use UNOs for anything that uses serial - I find SoftwareSerial unreliable evey at low baudrates
for the SIM900 I use a Arduino Mega which has hardware serial ports pin 18 (link to pin 8) and pin 19 (link to pin 7)
e.g. using AT commands
AT
OK
AT+CGMI
SIMCOM_Ltd
OK
AT+CGMM
SIMCOM_SIM900
OK
AT commands works at serial monitor...
but i cant write the right command to send me the message with the values.
eg AT+CSQ
i need to know via sms the signal check.
Can you understand what i need?
check signal level and unread message
AT+CSQ
+CSQ: 10,0
OK
+CMTI: "SM",24
AT+CMGL="REC UNREAD"
+CMGL: 24,"REC UNREAD","O2(uk)","","22/04/04,13:44:11+04"
 call 4444 free.
To stop these offers, call 2220.
I can understand your answers.
if you wish to read the signal quality and then send an SMS text with the value
  1. send AT+CSQ
  2. read the response, e.g. +CSQ: 10,0
  3. send command AT+CMGS=”+TTTTT” when TTTTT is the phone number
  4. when you receive > send response from 2, e.g. +CSQ: 10,0
  5. send CTRL/Z to close the text
