SIM900a Modem IMEI 0, Help with TX RX Pins
Hello
I have Simcom SIM900a GSM (SIM900 (SIM900A) Mini DEV Board v3.9.2) and I am interfacing it with Arduino UNO.
I have no idea how to connect SIM900a to Arduino UNO.
What I did now is:
I connect the following Pin from above Image to:
5 to: GND (Digital GND near Pin 13)
6 to: 5V of Arduio
2 to: GND of Arduino near 5V
3 to: Digital Pin 0 of Arduino (RX)
4 to: Digital Pin 1 of Arduino (TX)
1 to: (No idea)
From Picture option 7, 8, 9 are not connected to anything.
Can you please guide me am I doing right?
I am getting hard time to find out what is TX and RX in my SIM900a module as it is not written there.
My SIM900a looks like this:
http://upsats.com/Content/Product/img/Product/Large/SIM900V4-G36-37C.jpg (Schematics given)
SIM900 (SIM900A) Mini DEV Board - ElectroDragon
When I upload sketch of:
Example > GSM > TestModem:
I got this output from Serial Monitor:
Starting modem test...ERROR, no modem answer.
Checking IMEI...Modem's IMEI: 0
Reseting Modem... Modem is functioning properly: IMEI: 0
Hi
If you look to the datasheet (http://www.datasheetcafe.com/sim900a-datasheet-pdf/) you can find that the RX/TX pins are pin10/pin9 in the modem, so it should be trivial to follow the trace and find out what pin is in the header connector.
You may need to swap the pins RX to TX of arduino and vice-versa.
6 to: 5V of Arduio
Pay attention that SIM900 need more current than your arduino 5V rail can supply.YOu should get an external 5V power supply that can supply a current about 2 A during modem current peaks.
