Simple Sailing Start sequencer Countdown timer
I have a program for a 3 minute countdown timer. It was working great, but I wanted to add in 5 horn blasts to the program, which I did. It worked well, but I noted that when testing it out that it countdown was actually 3 seconds out of sequence and thus inaccurate. I made the appropriate changes to get it back in line.
When I tried to upload the program, the original sparkfun Redboard uno did not show up on the port. I then switched to a new Uno R3 and uploaded the program.
When tested, all I get is a long 10 second duration horn.
here is my program. For the life of me I can't see what stupid alteration I made to make this happen:
Sailing Starter is set to run a 3 minute start sequence for High School sailing. There is a 5 blast warning sequence
// before the the start of the 3 minutes. This program is for an Arduino Uno with a 12 volt megamoto motor shield. The shield supplies the 12v to the horn.
int motor = 11;
void setup(){
pinMode(motor,OUTPUT);
void loop(){
Minwarn();
wait(10.00);
Min3();
wait(56.25);
Min2();
wait(27.5);
Min1Half();
wait(26.75);
Min1();
wait(28.75);
Sec30();
wait(7.75);
Sec20();
wait(8.5);
Sec10();
wait(4.25);
Sec5To1();
Sec0();
while(true){
int secToMilliSec(int seconds){ //converts Seconds into milliseconds
return (seconds * 1000);
void wait(int Time){// wait
delay(secToMilliSec(Time));
void onOff(int on, int off){
analogWrite(motor,255);
wait(on);
analogWrite(motor,0);
wait(off);
void Minwarn(){
onOff(1.5,.25);
onOff(1.5,.25);
onOff(1.5,.25);
onOff(1.5,.25);
onOff(1.5,.25);
onOff(1.5,.25);
void Min3(){
onOff(1,.25);
onOff(1,.25);
onOff(1,.25);
void Min2(){
onOff(1,.25);
onOff(1,.25);
void Min1Half(){
onOff(1,.25);
onOff(.5,.25);
onOff(.5,.25);
onOff(.5,.25);
void Min1(){
onOff(1,.25);
void Sec30(){
onOff(.5,.25);
onOff(.5,.25);
onOff(.5,.25);
void Sec20(){
onOff(.5,.25);
onOff(.5,.25);
void Sec10(){
onOff(.5,.25);
void Sec5To1(){
onOff(.5,.5);
onOff(.5,.5);
onOff(.5,.5);
onOff(.5,.5);
onOff(.5,.5);
void Sec0(){
onOff(1.5,50);
(deleted)
You are passing float (floating point) parameters into functions which expect int (integer), so the floats are truncated.
eg.:
onOff(.5,.25) becomes onOff(0, 0)
onOff(1.5,.25) becomes onOff(1, 0)
You should also know than on an Uno an int variable can hold a value between -32,768 to 32,767.
