i am wondering how to create an aurdino code where an led blinks every half second forever, while another led blinks 5 times every seconds, then stops. how can i do these simultaneously?
School assignment?
If you have an Arduino UNO/NANO/MEGA board, you can accomplish the task using the millis() function.
You have to write code which is doing the blinking on one LED while blinking the other LED in a different interval.
Start with the Example from the IDE "Blink Without Delay"
Hello anonymous_232665
Welcome to the world's best Arduino forum ever.
Consider this example for your own sketch design studies.
//https://forum.arduino.cc/t/simultaneously-led-blinking/1214713
//https://europe1.discourse-cdn.com/arduino/original/4X/7/e/0/7e0ee1e51f1df32e30893550c85f0dd33244fb0e.jpeg
#define ProjectName "Simultaneously led blinking"
#define NotesOnRelease "Arduino MEGA tested"
enum TimerControl {Halt, Run};
enum Timer {One, Two};
enum OnOff {Off, On};
// make variables
constexpr uint8_t LedPins[] {9, 12};
constexpr uint8_t NumberOfBlinks {7};
constexpr uint32_t Interval[] {1000, 1000};
constexpr uint32_t SwitchedOnTime[] {50, 50};
// make structures
struct LEDBLINKS
uint8_t name;
uint8_t pin;
uint32_t interval[2];
uint8_t control;
uint32_t now;
void run(uint32_t currentMillis)
if (currentMillis - now >= interval[digitalRead(pin)] and control)
now = currentMillis;
digitalWrite(pin, digitalRead(pin) ? LOW : HIGH);
if (name == One) control--;
LEDBLINKS ledBlinks[]
{One, LedPins[One], Interval[One] - SwitchedOnTime[One], SwitchedOnTime[One] , NumberOfBlinks * 2, 0},
{Two, LedPins[Two], Interval[Two] - SwitchedOnTime[Two], SwitchedOnTime[Two] , Run, 0},
// make support
void heartBeat(const uint8_t LedPin, uint32_t currentMillis)
static bool setUp = false;
if (setUp == false) pinMode (LedPin, OUTPUT), setUp = true;
digitalWrite(LedPin, (currentMillis / 500) % 2);
// make application
Serial.print("Source: "), Serial.println(__FILE__);
Serial.print(ProjectName), Serial.print(" - "), Serial.println(NotesOnRelease);
Serial.print("led test");
for (auto LedPin : LedPins)
Serial.print(" . ");
pinMode(LedPin, OUTPUT);
digitalWrite(LedPin, HIGH);
digitalWrite(LedPin, LOW);
Serial.println("done\n");
Serial.println(" =-> and off we go\n");
uint32_t currentMillis = millis();
heartBeat(LED_BUILTIN, currentMillis);
for (auto &ledBlink : ledBlinks) ledBlink.run(currentMillis);
Sketch:
unsigned long present1Millis = millis(); //record current time
unsigned long present2Millis = millis(); //record current time
#define LED1 13
#define LED2 10
byte blinkCounter = 0;
bool flag = false;
int led1State = LOW;
int led2State = LOW;
pinMode(LED1, OUTPUT);
pinMode(LED2, OUTPUT);
digitalWrite(LED1, led1State); //LED1 is off
digitalWrite(LED2, led2State);
if (millis() - present1Millis >= 250) //testing
led1State = !led1State;
if (flag == false)
if (millis() - present2Millis >= 100) //testing
led2State = !led2State;
blinkCounter++;
if (blinkCounter == 10)
blinkCounter = 0;
flag = true;
Did you compile your sketch -- I have some errors?
It´s fine for me.
Which Arduino you have used?
Arduino MEGA tested
Sketch uses 3508 bytes (1%) of program storage space. Maximum is 253952 bytes.
Global variables use 469 bytes (5%) of dynamic memory, leaving 7723 bytes for local variables. Maximum is 8192 bytes.
This time, the sketch is compiled/Upload fine in my UNO; however, both LEDs are blinking indefenitely at their respective rates. Short intervaled LED should stop after making five blinks.
Configure it:
Code dump pileon... just using the Uno/Nano...
#define LED_BUILTIN 13 // for clarity
#define FIVETIM 5 // "blink" five times
#define FIVESEC 5000 // five seconds timer
#define HALFsec 500 // half second blink
long oldTimerHALFsec = 0; // HALF second timer
long oldTimerFIVEsec = 0; // FIVE seconds timer
pinMode(LED_BUILTIN, OUTPUT);
if (millis() - oldTimerHALFsec > HALFsec) {
oldTimerHALFsec = millis();
digitalWrite(LED_BUILTIN, !digitalRead(LED_BUILTIN));
if (digitalRead(LED_BUILTIN))
Serial.print("ON");
else Serial.println(" OFF");
if (millis() - oldTimerFIVEsec > FIVESEC) {
oldTimerFIVEsec = millis();
for (int i = 0; i < FIVETIM; i++) {
Serial.print(" blink_");
Serial.print(i + 1); // 1, 2, 3, 4, 5
delay(50);
If that's what we're doing... Which version does not drift? And how can that drift be avoided?
The one using cesium.
