I'm trying to build a device similar to a very expensive tool ( you can see the tool in their own website TIGERSTOP.COM ) here is a link to YouTube for you to understand what I'm looking for
The function of this tool is simple, you type a measurement on the NUMERICAL KEYPAD which is showed in a LCD DISPLAY and THE CONTROLLER BOARD makes a stepper motor to move a stop block to the desired measure and then you are able to make several cuts with perfect accuracy, then you can go back to home ( zero ) or not, just set a new measurement and start over. The stop block slides in two supported linear rail and it will be moved trough a ball screw.
Something very important for this project is that I need no computer hooked up at all the time (i know that initial programming Is needed )
Could you help me out picking what I need to get started, what controller board, LCD display, numerical keypad do I need to make this project possible.
