Single-axis solar tracker using LDRs
I have little Arduino IDE knowledge but I am interested in making a Single-axis solar tracker. The system conceptualized uses a stepper motor in a pulley mechanism to swivel the solar panel around. The equipment I have currently is a bunch of LDRs, an Arduino UNO, LM2596, and a stepper motor controller. The schematics are yet to be made. I need help in this project, thank you so so much!
There must be hundreds if not thousands of tutorials on thsr subject.
https://www.google.com/search?q=arduino+solar+tracker+LDR&oq=arduino+solar+tracker+LDR&gs_lcrp=EgZjaHJvbWUyBggAEEUYOTIGCAEQRRg8MgYIAhBFGDzSAQkyNTg5NmowajeoAg-wAgE&client=ms-android-verizon&sourceid=chrome-mobile&ie=UTF-8#ip=1
What, in particular, has you stuck?
Hello theias-actual
Use a local clock to turn the single-axis solar tracker.
LDRs on an overcast, sunny day will have a difficult time in the diffused light.
You should show a drawing of your idea. You can discover, as you are drawing, forgotten items or those not needed.
