I have a project like here:
I used the SK6812, becouse, they have a warm white led too. I used three additional libraries, fastled, arduinoha and wifinina
All components, Arduino 33 Nano IOT, SK6812, an additional sensor (not in picture above) are powered from the same power supply, Mean Well 5V, 12A (100-5).
The light is coded with a fixed brightness, and the dimming is relalised with the color code: CRGBW 0,0,0,0 -> low, CRGBW 0,0,0,255 -> bright.
If i test it with connected USB cable, all works like a charm. Dimming up and down is no problem. No flickering, nothing.
If I unplug the USB cable, the strip instantly begins to flicker. Not repeadly, but lets say about every 10-20 seconds a flicker, not following a specific pattern.
If I dim the light to 50% without the connected USB cable, the flickering ends. if I raise the brightness above 50%, the flickering starts. And if I put the USB cable back in, the flickering immediatly ends.
My theory was, that the light strip pull down the voltate below 3,3V and so, the arduino have not enough power to produce a clear signal. the signal is misinterpreted and so the led stripe starts to flicker. That matches with the cases lower brightness -> no flickering. But I thought, if I use a powersupply with nearly three time more amps, than I need, the voltage will not drop, because there are enough resevers. but that is not the case.
Have you any idea, what can I to to "stabilize" the voltage for the arduino? Or is it in the end a problem I do not realized yet?
Thank you in advance ![]()
