Archiving built core (caching) in: C:\Users\User\AppData\Local\Temp\arduino_cache_896844\core\core_arduino_avr_uno_0c812875ac70eb4a9b385d8fb077f54c.a
Sketch uses 11208 bytes (34%) of program storage space. Maximum is 32256 bytes.
Global variables use 790 bytes (38%) of dynamic memory, leaving 1258 bytes for local variables. Maximum is 2048 bytes.
avrdude: ser_open(): can't open device "\.\COM1": The system cannot find the file specified.
option enabled in File -> Preferences.
When I try to run the sketch using the online editor, the sketch runs.
I have checked the device manager and the ports are correct, the board is correct under "tools".
This sketch ran before I had the rollback my Windows 10 system to the default settings. My files were restored.
I checked the Arduino driver and I have been told that it is the correct version.
Archiving built core (caching) in: C:\Users\User\AppData\Local\Temp\arduino_cache_972218\core\core_arduino_avr_uno_0c812875ac70eb4a9b385d8fb077f54c.a
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM1 -b115200 -D -Uflash:w:C:\Users\User\AppData\Local\Temp\arduino_build_904500/GPSvx_Test_GPS_2_Parts_Reader.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
An error occurred while uploading the sketch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM1
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude done. Thank you.
I see the reference to COM 1 - where did that come from?
