Sketch hangs while initialyzing
Hi
I tried to add a hit feedback function to an existing code for laser tag (infrared) gaming. I use HC-12 modules (SoftwareSerial HC12) to send back the received playerID when a player gets hit. The player making a hit gets the feedback by audio (mp3-module).
The code worked fine. But with my additional code, the UNO gets stuck while initialyzing the DFPlayer mini here:
Serial.println(F("1.Please recheck the connection!"));
Serial.println(F("2.Please insert the SD card!"));
The SD card is fine. When I upload the old code the DFPlayer and everything works fine.
Here is the first half of the code:
#include "DFRobotDFPlayerMini.h"
#include "SoftwareSerial.h"
SoftwareSerial mySoftwareSerial(8, 11);
SoftwareSerial HC12(4, 10);
DFRobotDFPlayerMini myDFPlayer;
void printDetail(uint8_t type, int value);
// Digital IO's
int triggerPin             = 3;      // Push button for primary fire. Low = pressed
int trigger2Pin            = 13;     // Push button for secondary fire. Low = pressed
int speakerPin             = 14;      // Direct output to piezo sounder/speaker
int HitVibration           = 9;      // Audio Trigger. Can be used to set off sounds recorded in the kind of electronics you can get in greetings card that play a custom message.
int lifePin                = 6;      // An analogue output (PWM) level corresponds to remaining life. Use PWM pin: 3,5,6,9,10 or 11. Can be used to drive LED bar graphs. eg LM3914N
int ammoPin                = 5;      // An analogue output (PWM) level corresponds to remaining ammunition. Use PWM pin: 3,5,6,9,10 or 11.
int hitPin                 = 7;      // LED output pin used to indicate when the player has been hit.
int IRtransmitPin          = 2;      // Primary fire mode IR transmitter pin: Use pins 2,4,7,8,12 or 13. DO NOT USE PWM pins!! More info: http://j44industries.blogspot.com/2009/09/arduino-frequency-generation.html#more
//int IRtransmit2Pin         = 8;      // Secondary fire mode IR transmitter pin:  Use pins 2,4,7,8,12 or 13. DO NOT USE PWM pins!!
int IRreceivePin           = 12;     // The pin that incoming IR signals are read from
int IRreceive2Pin          = 15;     // Allows for checking external sensors are attached as well as distinguishing between sensor locations (eg spotting head shots)
//Minimum gun requirements: trigger, receiver, IR led, hit LED.
// Player and Game details
int myTeamID               = 1;      // 1-7 (0 = system message)
int myPlayerID             = 1;     // Player ID
int myGameID               = 1;      // Interprited by configureGane subroutine; allows for quick change of game types.
int myWeaponID             = 0;      // Deffined by gameType and configureGame subroutine.
int myWeaponHP             = 0;      // Deffined by gameType and configureGame subroutine.
int maxAmmo                = 0;      // Deffined by gameType and configureGame subroutine.
int maxLife                = 0;      // Deffined by gameType and configureGame subroutine.
int automatic              = 0;      // Deffined by gameType and configureGame subroutine. Automatic fire 0 = Semi Auto, 1 = Fully Auto.
int automatic2             = 0;      // Deffined by gameType and configureGame subroutine. Secondary fire auto?
//Incoming signal Details
int received[18];                    // Received data: received[0] = which sensor, received[1] - [17] byte1 byte2 parity (Miles Tag structure)
int check                  = 0;      // Variable used in parity checking
// Stats
int ammo                   = 0;      // Current ammunition
int life                   = 0;      // Current life
// Code Variables
int timeOut                = 0;      // Deffined in frequencyCalculations (IRpulse + 50)
int FIRE                   = 0;      // 0 = don't fire, 1 = Primary Fire, 2 = Secondary Fire
int TR                     = 0;      // Trigger Reading
int LTR                    = 0;      // Last Trigger Reading
int T2R                    = 0;      // Trigger 2 Reading (For secondary fire)
int LT2R                   = 0;      // Last Trigger 2 Reading (For secondary fire)
// Signal Properties
int IRpulse                = 600;    // Basic pulse duration of 600uS MilesTag standard 4*IRpulse for header bit, 2*IRpulse for 1, 1*IRpulse for 0.
int IRfrequency            = 36;     // Frequency in kHz Standard values are: 38kHz, 40kHz. Choose dependant on your receiver characteristics
int IRt                    = 0;      // LED on time to give correct transmission frequency, calculated in setup.
int IRpulses               = 0;      // Number of oscillations needed to make a full IRpulse, calculated in setup.
int header                 = 4;      // Header lenght in pulses. 4 = Miles tag standard
int maxSPS                 = 10;     // Maximum Shots Per Seconds. Not yet used.
int TBS                    = 0;      // Time between shots. Not yet used.
// Transmission data
int byte1[8];                        // String for storing byte1 of the data which gets transmitted when the player fires.
int byte2[8];                        // String for storing byte1 of the data which gets transmitted when the player fires.
int myParity               = 0;      // String for storing parity of the data which gets transmitted when the player fires.
// Received data
int memory                 = 10;     // Number of signals to be recorded: Allows for the game data to be reviewed after the game, no provision for transmitting / accessing it yet though.
int hitNo                  = 0;      // Hit number
// Byte1
int player[10];                      // Array must be as large as memory
int team[10];                        // Array must be as large as memory
// Byte2
int weapon[10];                      // Array must be as large as memory
int hp[10];                          // Array must be as large as memory
int parity[10];                      // Array must be as large as memory
int HitPlayer               = 0;
  // Serial coms set up to help with debugging.
  mySoftwareSerial.begin(9600);
  HC12.begin(9600);
  Serial.println("Startup...");
  Serial.println(F("DFRobot DFPlayer Mini Demo"));
  Serial.println(F("Initializing DFPlayer ... (May take 3~5 seconds)"));
  if (!myDFPlayer.begin(mySoftwareSerial)) {  //Use softwareSerial to communicate with mp3.
    Serial.println(F("Unable to begin:"));
    while(true){
      delay(0); // Code to compatible with ESP8266 watch dog.
  Serial.println(F("DFPlayer Mini online."));
  myDFPlayer.volume(25);  //Set volume value. From 0 to 30
  // Pin declarations
  pinMode(triggerPin, INPUT);
  pinMode(trigger2Pin, INPUT);
  pinMode(speakerPin, OUTPUT);
  //pinMode(audioPin, OUTPUT);
  pinMode(lifePin, OUTPUT);
  pinMode(ammoPin, OUTPUT);
  pinMode(hitPin, OUTPUT);
  pinMode(IRtransmitPin, OUTPUT);
  //pinMode(IRtransmit2Pin, OUTPUT);
  pinMode(IRreceivePin, INPUT);
  pinMode(IRreceive2Pin, INPUT);
  pinMode(HitVibration, OUTPUT);
  frequencyCalculations();   // Calculates pulse lengths etc for desired frequency
  configureGame();           // Look up and configure game details
  tagCode();                 // Based on game details etc works out the data that will be transmitted when a shot is fired
  digitalWrite(triggerPin, HIGH);      // Not really needed if your circuit has the correct pull up resistors already but doesn't harm
  digitalWrite(trigger2Pin, HIGH);     // Not really needed if your circuit has the correct pull up resistors already but doesn't harm
  myDFPlayer.play(3);
  for (int i = 1;i < 254;i++) { // Loop plays start up noise
    analogWrite(ammoPin, i);
    playTone((3000-9*i), 2);
  // Next 4 lines initialise the display LEDs
  analogWrite(ammoPin, ((int) ammo));
  analogWrite(lifePin, ((int) life));
  lifeDisplay();
  ammoDisplay();
  Serial.println("Ready....");
// Main loop most of the code is in the sub routines
void loop(){
  receiveIR();
  if(FIRE != 0){
    shoot();
    ammoDisplay();
  triggers();
// SUB ROUTINES
void ammoDisplay() { // Updates Ammo LED output
  float ammoF;
  ammoF = (260/maxAmmo) * ammo;
  if(ammoF <= 0){ammoF = 0;}
  if(ammoF > 255){ammoF = 255;}
  analogWrite(ammoPin, ((int) ammoF));
void lifeDisplay() { // Updates Ammo LED output
  float lifeF;
  lifeF = (260/maxLife) * life;
  if(lifeF <= 0){lifeF = 0;}
  if(lifeF > 255){lifeF = 255;}
  analogWrite(lifePin, ((int) lifeF));
void receiveIR() { // Void checks for an incoming signal and decodes it if it sees one.
  int error = 0;
  if(digitalRead(IRreceivePin) == LOW){    // If the receive pin is low a signal is being received.
    digitalWrite(hitPin,HIGH);
    if(digitalRead(IRreceive2Pin) == LOW){ // Is the incoming signal being received by the head sensors?
      received[0] = 1;
    else{
      received[0] = 0;
    while(digitalRead(IRreceivePin) == LOW){
    for(int i = 1; i <= 17; i++) {                        // Repeats several times to make sure the whole signal has been received
      received[i] = pulseIn(IRreceivePin, LOW, 15000);  // pulseIn command waits for a pulse and then records its duration in microseconds.
    Serial.print("sensor: ");                            // Prints if it was a head shot or not.
    Serial.print(received[0]);
    Serial.print("...");
    for(int i = 1; i <= 17; i++) {  // Looks at each one of the received pulses
      int receivedTemp[18];
      receivedTemp[i] = 2;
      if(received[i] > (IRpulse - 200) &&  received[i] < (IRpulse + 200)) {receivedTemp[i] = 0;}                      // Works out from the pulse length if it was a data 1 or 0 that was received writes result to receivedTemp string
      if(received[i] > (IRpulse + IRpulse - 200) &&  received[i] < (IRpulse + IRpulse + 200)) {receivedTemp[i] = 1;}  // Works out from the pulse length if it was a data 1 or 0 that was received
      received[i] = 3;                   // Wipes raw received data
      received[i] = receivedTemp[i];     // Inputs interpreted data
      Serial.print(" ");
      Serial.print(received[i]);         // Print interpreted data results
    Serial.println("");                  // New line to tidy up printed results
    // Parity Check. Was the data received a valid signal?
    check = 0;
    for(int i = 1; i <= 16; i++) {
      if(received[i] == 1){check = check + 1;}
      if(received[i] == 2){error = 1;}
    // Serial.println(check);
    check = check >> 0 & B1;
    if(check != received[17]){error = 1;}
    if(error == 0){Serial.println("Valid Signal");}
    else{Serial.println("ERROR");}
    if(error == 0){interpritReceived();}
    digitalWrite(hitPin,LOW);
void interpritReceived(){  // After a message has been received by the ReceiveIR subroutine this subroutine decidedes how it should react to the data
  if(hitNo == memory){hitNo = 0;} // hitNo sorts out where the data should be stored if statement means old data gets overwritten if too much is received
  team[hitNo] = 0;
  player[hitNo] = 0;
  weapon[hitNo] = 0;
  hp[hitNo] = 0;
  // Next few lines Effectivly converts the binary data into decimal
  // Im sure there must be a much more efficient way of doing this
  if(received[1] == 1){team[hitNo] = team[hitNo] + 4;}
  if(received[2] == 1){team[hitNo] = team[hitNo] + 2;}
  if(received[3] == 1){team[hitNo] = team[hitNo] + 1;}
  if(received[4] == 1){player[hitNo] = player[hitNo] + 16;}
  if(received[5] == 1){player[hitNo] = player[hitNo] + 8;}
  if(received[6] == 1){player[hitNo] = player[hitNo] + 4;}
  if(received[7] == 1){player[hitNo] = player[hitNo] + 2;}
  if(received[8] == 1){player[hitNo] = player[hitNo] + 1;}
  if(received[9] == 1){weapon[hitNo] = weapon[hitNo] + 4;}
  if(received[10] == 1){weapon[hitNo] = weapon[hitNo] + 2;}
  if(received[11] == 1){weapon[hitNo] = weapon[hitNo] + 1;}
  if(received[12] == 1){hp[hitNo] = hp[hitNo] + 16;}
  if(received[13] == 1){hp[hitNo] = hp[hitNo] + 8;}
  if(received[14] == 1){hp[hitNo] = hp[hitNo] + 4;}
  if(received[15] == 1){hp[hitNo] = hp[hitNo] + 2;}
  if(received[16] == 1){hp[hitNo] = hp[hitNo] + 1;}
  parity[hitNo] = received[17];
  Serial.print("Hit No: ");
  Serial.print(hitNo);
  Serial.print("  Player: ");
  Serial.print(player[hitNo]);
  Serial.print("  Team: ");
  Serial.print(team[hitNo]);
  Serial.print("  Weapon: ");
  Serial.print(weapon[hitNo]);
  Serial.print("  HP: ");
  Serial.print(hp[hitNo]);
  Serial.print("  Parity: ");
  Serial.println(parity[hitNo]);
  HC12.write(player[hitNo]);
  //This is probably where more code should be added to expand the game capabilities at the moment the code just checks that the received data was not a system message and deducts a life if it wasn't.
  if (player[hitNo] != 0){hit();}
  hitNo++ ;
void shoot() {
  if(FIRE == 1){ // Has the trigger been pressed?
    Serial.println("FIRE 1");
    sendPulse(IRtransmitPin, 4); // Transmit Header pulse, send pulse subroutine deals with the details
    delayMicroseconds(IRpulse);
    for(int i = 0; i < 8; i++) { // Transmit Byte1
      if(byte1[i] == 1){
        sendPulse(IRtransmitPin, 1);
        //Serial.print("1 ");
      //else{Serial.print("0 ");}
    for(int i = 0; i < 8; i++) { // Transmit Byte2
      if(byte2[i] == 1){
       // Serial.print("1 ");
    if(myParity == 1){ // Parity
    Serial.println("");
    Serial.println("DONE 1");
    myDFPlayer.play(1);
  if(FIRE == 2){ // Where a secondary fire mode would be added
    Serial.println("FIRE 2");
    sendPulse(IRtransmitPin, 4); // Header
    Serial.println("DONE 2");
FIRE = 0;
ammo = ammo - 1;
void HitFeedback () {
  while (HC12.available()) {
    HitPlayer = (HC12.read());
    if (HitPlayer = myPlayerID) {
    myDFPlayer.play(4);
did you get any answer in the German forum ?
(cross posting without any mention is not a great idea).
Yes I did get answers. But none of them could solve the problem.
I thought I could reach a larger group of experienced programmers here..
