Sketch NOT working when arduino is powered by an external power supply.
HI! guys!!!! I have a problem. When my arduino is plugged in the PC USB port the sketch works and executes perfectly, but whenever I power the arduino with an external power supply(from a step-up converter it is at 7.5vDC) the sketch wont run. Any ideas what causes this and on how to fix it?
I tried to troubleshoot it and did a bit of research on it. So here is what I did
1.) tried uploading the blink sketch (to check if the problem is on the software side) and ran the sketch with the arduino connected to PC USB and it worked, but when I connected the arduino to an external power supply thesame problem occurred and the LED did not blink.
2.) I also connected a 10k ohm resistor in between RX pin and TX pin. Still it did not solve my problem. BTW I am using an arduino nano.
Please help me out guys. :frowning: I really need to finish this project for school. :frowning: ... below is my source code.
   Typical pin layout used: RFID
               MFRC522      Arduino       Arduino   Arduino    Arduino          Arduino
               Reader/PCD   Uno           Mega      Nano v3    Leonardo/Micro   Pro Micro
   Signal      Pin          Pin           Pin       Pin        Pin              Pin
   RST/Reset   RST          9             5         D9         RESET/ICSP-5     RST
   SPI SS      SDA(SS)      10            53        D10        10               10
   SPI MOSI    MOSI         11 / ICSP-4   51        D11        ICSP-4           16
   SPI MISO    MISO         12 / ICSP-1   50        D12        ICSP-1           14
   SPI SCK     SCK 0         13 / ICSP-3   52        D13        ICSP-3           15
#include <DFRobot_sim808.h>
#include <SoftwareSerial.h>
#include <MFRC522.h>
#include <TinyGPS.h>
#define SS_PIN_RFID 10
#define RST_PIN_RFID 9
#define ph_num "09271806021" //ari ibutang phone number
#define PIN_TX_808    7   //sim808_tx_in module tx is to tx(idk why haha)
#define PIN_RX_808    8 //sim808_rx_in module rx is to rx (idk why haha)
#define buzz_pin 5
#define EP 4 //vibration sensor pin
MFRC522 rfid(SS_PIN_RFID, RST_PIN_RFID);  // Create MFRC522 instance
SoftwareSerial gps2(PIN_TX_808, PIN_RX_808);
DFRobot_SIM808 sim808(&gps2); //Connect RX,TX,PWR,
TinyGPS GPS;
int pass_string[4] = {240, 190, 103, 77}; //UID of the RFID card
//String pass_string2 = "82,192,48,91";
String googlePrefix = "http://maps.google.com/maps?q=";
const long interval = 20000;
unsigned long prevMillis = 0;
float lat, longi;
float speedo;
//this is for alarm periphirals
bool disarmNotif = false;
bool armNotif = false ;
bool alarmTriped = false;
bool posGPS = false;
bool posGPS2 = false;
  //Serial.begin(9600);
  gps2.begin(9600);
  pinMode(buzz_pin, OUTPUT);
  pinMode(EP, INPUT);
  SPI.begin();      // Init SPI bus
  rfid.PCD_Init();    // Init MFRC522
  while (!sim808.init()) {
    Serial.print("Sim808 init error\r\n");
  //************* Turn on the GPS power************
  while ( !sim808.attachGPS()) {
    digitalWrite(buzz_pin, HIGH);
    delay(200);
    digitalWrite(buzz_pin, LOW);
    delay(50);
    delay(200);
    delay(50);
    delay(200);
  Serial.println("Open the GPS power ok");
//////////////////////////////////////////CUSTOM FUNCTIONS///////////////////////////////////////
long vibra_out() {
  long measurement = pulseIn (EP, HIGH); //wait for the pin to get HIGH and returns measurement
  return measurement;
bool verify_rfid() {
  int i = 0;
  boolean match = true;
  while (i < rfid.uid.size)
    if (!(rfid.uid.uidByte[i] == pass_string[i]))
      match = false;
    i++;
  if (match) {
    if (!disarmNotif) {
      disarmNotif = true;
      delay(200);
      delay(50);
      delay(200);
      //resets evertyhing
      armNotif = false;
      posGPS2  = false;
      return true;
  else {
    Serial.print("Invalid RFID!\n");
    return false;
/////////////////////////////////////////////////////END OF CUSTOM FUNCTIONS/////////////////////////////
  // Look for new cards
  if ( ! rfid.PICC_IsNewCardPresent()) {
    long vibra_read = 0;
    if (!armNotif) {
      armNotif = true;
      delay(750);
      //arms alarm
      posGPS = false;
    if (!alarmTriped) {
      vibra_read = vibra_out();
      Serial.print("Vibra Reading: "); // displays the reading of the sensor
      Serial.println(vibra_read);
      if (vibra_read >= 1000) { //if the reading from the motion sensor exceeds 30k it triggers the system to send the user a notification through text message.
        alarmTriped = true;
    else {
      byte a;
      String message;
      while ( gps2.available() > 0 ) // if there is data coming from the GPS shield
        a = gps2.read(); // get the byte of data
        if (GPS.encode(a)) // if there is valid GPS data...
          GPS.f_get_position(&lat, &longi);
          // Serial.println("--------------------------------------------------------------");
          // Serial.print("Lat: ");
          //Serial.print(lat, 5);
          // Serial.print(" Long: ");
          //Serial.println(longi, 5);
          // Serial.print(GPS.f_speed_kmph());
          // Serial.println("km/h");
          speedo = GPS.f_speed_kmph();
      message = "Alert!\nYour bicycle has been stolen! It is currently at\nLocation: " + googlePrefix + String(lat, 5) + "," + String(longi, 5) + "\nSpeed: " + String(speedo) + " km/hr";
      if (currentMillis - prevMillis >= interval) {//this part is where it sends the message at a defined interval
        prevMillis = currentMillis;
        char charbuff[message.length()];
        message.toCharArray(charbuff, message.length() + 1);
        Serial.println(charbuff); // displays the converted String message to char on Serial monitor.
        if (sim808.sendSMS(ph_num, charbuff)) {
          Serial.println("sent message"); //displays confirmation that the message was sent.
        else {
          Serial.println("message sending failed");
    //Serial.print("Alarm armed: ");
    //Serial.println(alarmArmed);
    return;
  // Select one of the cards
  if ( ! rfid.PICC_ReadCardSerial()) {
    return;
  while (verify_rfid()) {
    // Stop encryption on PCD
    rfid.PCD_StopCrypto1();
  byte a;
  while ( gps2.available() > 0 ) {
    Serial.write(a);
      if (!posGPS) {
        posGPS = true ;
        delay(50);
        delay(50);
        delay(50);
      ///Serial.println("--------------------------------------------------------------");
      //Serial.print("Lat: ");
      //  Serial.print(lat, 5);
      //Serial.print(" Long: ");
      //Serial.println("km/h");
  // Serial.print("Alarm armed: ");
Replies would be very much appreciated.
Obviously you need more power so how is your step-up converter powered?
I tried powering the nano with a 7.5v 2A power supply (from an old Playstation 1 power supply) and it still didn't work. The step up converter is connected to a Li-po Battery on its input.
Where did you connect your 7.5V, you can only connect it to Vin and gnd.
However you need more than 8V at Vin because you are supplying a 5V linear regulator on the arduino PCB.
Less than 8V will not give a reliable and regulated 5V for the controller.
What model arduino is it?
You can either use a DC-DC converter that is more then 8V output.
Or use a DC-DC converter with 5V output and connect it to the 5V and gnd of the arduino.
Tom... :slight_smile:
I tried adjusting the output of the boost conv to 9v but it still did not work. Here is the schematic.
Can you measure the 5V pin on the arduino when using USB and then when using dc-dc converter please?
Thanks.. Tom.. :slight_smile:
Yes i did measure it with the external power supply on. It measures 5v and with the pc usb on it measures 5v also..... I'm starting to think that I have a busted nano board.
