Windows PowerShell
Copyright (C) Microsoft Corporation. All rights reserved.
Install the latest PowerShell for new features and improvements! https://aka.ms/PSWindows
PS C:\Program Files\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.3.7
Checking for frontend application configuration customizations. Module path: C:\Program Files\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Program Files\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.7" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.3.1" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2025-12-17T16:05:25.389Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{},"showWindowEarly":true,"splashScreenOptions":{},"uriScheme":"arduino-ide"},"defaultLocale":"","validatePreferencesSchema":false,"reloadOnReconnect":true,"uriScheme":"theia","preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.7","cliVersion":"1.3.1","buildDate":"2025-12-17T16:05:25.389Z"}
Starting backend process. PID: 92984
Showing main window early
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/wdots/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2025-12-27T22:55:52.179Z root INFO Backend u.initialize: 40.3 ms [Finished 0.832 s after backend start]
2025-12-27T22:55:52.181Z root INFO Backend Object.initialize: 35.2 ms [Finished 0.832 s after backend start]
2025-12-27T22:55:52.181Z root INFO Backend a.initialize: 2.0 ms [Finished 0.832 s after backend start]
2025-12-27T22:55:52.181Z root INFO Backend a.initialize: 1.8 ms [Finished 0.832 s after backend start]
2025-12-27T22:55:52.181Z root INFO Backend u.initialize: 2.6 ms [Finished 0.833 s after backend start]
2025-12-27T22:55:52.185Z root INFO Backend l.initialize: 37.9 ms [Finished 0.835 s after backend start]
2025-12-27T22:55:52.191Z root INFO configured all backend app contributions
2025-12-27T22:55:52.192Z root INFO Backend l.onStart: 1.0 ms [Finished 0.848 s after backend start]
2025-12-27T22:55:52.192Z root INFO Backend d.onStart: 0.1 ms [Finished 0.848 s after backend start]
2025-12-27T22:55:52.193Z root INFO Backend a.onStart: 0.3 ms [Finished 0.848 s after backend start]
2025-12-27T22:55:52.193Z config INFO >>> Initializing CLI configuration...
2025-12-27T22:55:52.193Z root INFO Backend x.onStart: 0.4 ms [Finished 0.849 s after backend start]
2025-12-27T22:55:52.193Z config INFO Loading CLI configuration from c:\Users\wdots\.arduinoIDE\arduino-cli.yaml...
2025-12-27T22:55:52.193Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-12-27T22:55:52.193Z root INFO Backend w.onStart: 0.3 ms [Finished 0.849 s after backend start]
2025-12-27T22:55:52.193Z discovery-log INFO start
2025-12-27T22:55:52.193Z discovery-log INFO start new deferred
2025-12-27T22:55:52.193Z root INFO Backend v.onStart: 0.2 ms [Finished 0.849 s after backend start]
2025-12-27T22:55:52.193Z root INFO Backend a.onStart: 0.1 ms [Finished 0.850 s after backend start]
2025-12-27T22:55:52.197Z root INFO Theia app listening on http://127.0.0.1:47070.
2025-12-27T22:55:52.197Z root INFO Finished starting backend application: 4.2 ms [Finished 0.854 s after backend start]
2025-12-27T22:55:52.198Z root WARN The local plugin referenced by local-dir:/c%3A/Users/wdots/.arduinoIDE/plugins does not exist.
2025-12-27T22:55:52.198Z root WARN The local plugin referenced by local-dir:/c%3A/Users/wdots/.arduinoIDE/deployedPlugins does not exist.
2025-12-27T22:55:52.198Z root WARN The local plugin referenced by local-dir:C:\Users\wdots\.arduinoIDE\plugins does not exist.
2025-12-27T22:55:52.360Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]}}
2025-12-27T22:55:52.360Z config INFO Loading fallback CLI configuration to get 'directories.data' and 'directories.user'
2025-12-27T22:55:52.448Z root INFO Resolve plugins list: 252.7 ms [Finished 1.104 s after backend start]
2025-12-27T22:55:52.692Z daemon INFO time="2025-12-27T17:55:52-05:00" level=info msg="arduino-cli version 1.3.1"
2025-12-27T22:55:52.707Z daemon INFO time="2025-12-27T17:55:52-05:00" level=info msg="Using config file: c:\\Users\\wdots\\.arduinoIDE\\arduino-cli.yaml"
2025-12-27T22:55:52.708Z daemon INFO time="2025-12-27T17:55:52-05:00" level=info msg="Executing `arduino-cli daemon`"
2025-12-27T22:55:52.728Z daemon INFO Daemon is now listening on 127.0.0.1:47071
{"IP":"127.0.0.1","Port":"47071"}
2025-12-27T22:55:52.728Z daemon INFO Daemon is running.
2025-12-27T22:55:52.828Z config INFO Loaded fallback CLI configuration: {"directories":{"user":"\\\\elise\\tb2\\williedocuments\\Arduino","data":"C:\\Users\\wdots\\AppData\\Local\\Arduino15"}}
2025-12-27T22:55:52.828Z config INFO Merged CLI configuration with the fallback: {"directories":{"user":"\\\\elise\\tb2\\williedocuments\\Arduino","data":"C:\\Users\\wdots\\AppData\\Local\\Arduino15"},"board_manager":{"additional_urls":[]}}
2025-12-27T22:55:52.828Z config INFO Loaded the CLI configuration.
2025-12-27T22:55:52.856Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/wdots/AppData/Local/Arduino15","sketchDirUri":"file://elise/tb2/williedocuments/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2025-12-27T22:55:52.856Z config INFO Validating the CLI configuration...
2025-12-27T22:55:52.869Z config INFO The CLI config is valid.
2025-12-27T22:55:52.869Z config INFO <<< Initialized the CLI configuration.
2025-12-27T22:55:52.894Z daemon INFO time="2025-12-27T17:55:52-05:00" level=info msg="Checking signature" index="C:\\Users\\wdots\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\wdots\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2025-12-27T22:55:52.895Z daemon INFO time="2025-12-27T17:55:52-05:00" level=info msg="Loading hardware from: C:\\Users\\wdots\\AppData\\Local\\Arduino15\\packages"
2025-12-27T22:55:52.897Z daemon INFO time="2025-12-27T17:55:52-05:00" level=info msg="Loading package arduino from: C:\\Users\\wdots\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware"
2025-12-27T22:55:52.914Z daemon INFO time="2025-12-27T17:55:52-05:00" level=info msg="Missing signature file" index="C:\\Users\\wdots\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json"
2025-12-27T22:55:52.941Z daemon INFO time="2025-12-27T17:55:52-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2025-12-27T17:55:52-05:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
2025-12-27T22:55:52.957Z daemon INFO time="2025-12-27T17:55:52-05:00" level=info msg="Missing signature file" index="C:\\Users\\wdots\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.5.1\\installed.json"
2025-12-27T22:55:52.987Z daemon INFO time="2025-12-27T17:55:52-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2025-12-27T17:55:52-05:00" level=info msg="Loaded platform" platform="arduino:renesas_uno@1.5.1"
2025-12-27T22:55:52.987Z daemon INFO time="2025-12-27T17:55:52-05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\wdots\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2025-12-27T17:55:52-05:00" level=info msg="Loading tools from dir: C:\\Users\\wdots\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
2025-12-27T22:55:52.987Z daemon INFO time="2025-12-27T17:55:52-05:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
2025-12-27T22:55:52.988Z daemon INFO time="2025-12-27T17:55:52-05:00" level=info msg="Loaded tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
2025-12-27T22:55:52.988Z daemon INFO time="2025-12-27T17:55:52-05:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2025-12-27T22:55:52.988Z daemon INFO time="2025-12-27T17:55:52-05:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
2025-12-27T22:55:52.988Z daemon INFO time="2025-12-27T17:55:52-05:00" level=info msg="Loaded tool" tool="arduino:bossac@1.9.1-arduino5"
2025-12-27T22:55:52.989Z daemon INFO time="2025-12-27T17:55:52-05:00" level=info msg="Loaded tool" tool="arduino:dfu-util@0.11.0-arduino5"
2025-12-27T22:55:52.989Z daemon INFO time="2025-12-27T17:55:52-05:00" level=info msg="Loaded tool" tool="arduino:openocd@0.11.0-arduino2"
2025-12-27T22:55:52.989Z daemon INFO time="2025-12-27T17:55:52-05:00" level=info msg="Loading package builtin from: C:\\Users\\wdots\\AppData\\Local\\Arduino15\\packages\\builtin"
2025-12-27T22:55:52.990Z daemon INFO time="2025-12-27T17:55:52-05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\wdots\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2025-12-27T17:55:52-05:00" level=info msg="Loading tools from dir: C:\\Users\\wdots\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
2025-12-27T22:55:52.990Z daemon INFO time="2025-12-27T17:55:52-05:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
2025-12-27T22:55:52.990Z daemon INFO time="2025-12-27T17:55:52-05:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
2025-12-27T22:55:52.991Z daemon INFO time="2025-12-27T17:55:52-05:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.12"
2025-12-27T22:55:52.991Z daemon INFO time="2025-12-27T17:55:52-05:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.3"
2025-12-27T22:55:52.991Z daemon INFO time="2025-12-27T17:55:52-05:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.15.0"
2025-12-27T22:55:53.006Z daemon INFO time="2025-12-27T17:55:53-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\wdots\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.5.1\\libraries" isSingleLibrary=false location=platform
2025-12-27T22:55:53.010Z daemon INFO time="2025-12-27T17:55:53-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\wdots\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" isSingleLibrary=false location=platform
2025-12-27T22:55:53.010Z daemon INFO time="2025-12-27T17:55:53-05:00" level=info msg="Loading libraries index file" index="C:\\Users\\wdots\\AppData\\Local\\Arduino15\\library_index.json"
2025-12-27T22:55:53.236Z daemon INFO time="2025-12-27T17:55:53-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\wdots\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
2025-12-27T22:55:53.238Z daemon INFO time="2025-12-27T17:55:53-05:00" level=info msg="Adding libraries dir" dir="\\\\elise\\tb2\\williedocuments\\Arduino\\libraries" isSingleLibrary=false location=user
2025-12-27T22:55:53.705Z root INFO creating connection for 1
2025-12-27T22:55:54.069Z discovery-log INFO start resolved watching
2025-12-27T22:55:54.721Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM1","label":"COM1","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2025-12-27T22:55:54.733Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 213.8 ms [Finished 2.282 s after frontend start]
2025-12-27T22:55:54.759Z root WARN A command editor.action.toggleStickyScroll is already registered.
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2025-12-27T22:55:54.902Z root WARN Frontend keybindings.onStart took longer than the expected maximum 100 milliseconds: 140.4 ms [Finished 2.447 s after frontend start]
2025-12-27T22:55:54.966Z root INFO Start frontend contributions: 507.5 ms [Finished 2.506 s after frontend start]
2025-12-27T22:55:54.966Z root INFO Changed application state from 'init' to 'started_contributions'.
2025-12-27T22:55:54.973Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2025-12-27T22:55:54.973Z root INFO >>> Restoring the layout state...
2025-12-27T22:55:55.389Z root INFO <<< Nothing to restore.
2025-12-27T22:55:55.419Z root INFO Initialize the workbench layout: 436.5 ms [Finished 2.965 s after frontend start]
2025-12-27T22:55:55.420Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2025-12-27T22:55:56.193Z root INFO Deploy plugins list: 3998.6 ms [Finished 4.849 s after backend start]
2025-12-27T22:55:56.197Z root INFO [757ec327-5c73-4c27-b817-e4309f2034da] Waiting for backend deployment: 1247.4 ms [Finished 3.750 s after frontend start]
Checking for update
2025-12-27T22:55:57.055Z root INFO Replace loading indicator with ready workbench UI (animation): 828.0 ms [Finished 3.803 s after frontend start]
2025-12-27T22:55:57.055Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2025-12-27T22:55:57.055Z root WARN Linked preference "workbench.colorCustomizations" not found.
2025-12-27T22:55:57.059Z root INFO Frontend application start: 1978.0 ms [Finished 5.357 s after backend start]
2025-12-27T22:55:57.059Z root INFO [hosted-plugin: 102548] PLUGIN_HOST(102548) starting instance
[Object: null prototype] {}
2025-12-27T22:55:57.387Z root ERROR ---- !!!SLOW!!! DURATION: search took 332.313 ms. Args: [{"type":"Updatable"}] ----
Update for version 2.3.7 is not available (latest version: 2.3.7, downgrade is allowed).
2025-12-27T22:55:57.605Z root INFO [757ec327-5c73-4c27-b817-e4309f2034da] Sync of 23 plugins: 1346.2 ms [Finished 5.096 s after frontend start]
2025-12-27T22:55:57.605Z root INFO [757ec327-5c73-4c27-b817-e4309f2034da] Loading plugin contributions
2025-12-27T22:55:57.605Z root INFO [757ec327-5c73-4c27-b817-e4309f2034da] Load contributions of 23 plugins: 62.6 ms [Finished 5.159 s after frontend start]
2025-12-27T22:55:57.627Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2025-12-27T22:55:57.627Z root WARN a registered grammar configuration for 'cpp' language is overridden
2025-12-27T22:55:57.687Z root INFO core-client-provider [library-index] Downloading index: library_index.tar.bz2
2025-12-27T22:55:57.688Z root INFO core-client-provider [platform-index] Downloading index: package_index.tar.bz2
2025-12-27T22:55:57.688Z daemon INFO time="2025-12-27T17:55:57-05:00" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
time="2025-12-27T17:55:57-05:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
time="2025-12-27T17:55:57-05:00" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2025-12-27T22:55:57.851Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <\\elise\tb2\williedocuments\Arduino\sketch_nov8a>, response: <\\elise\tb2\WillieDocuments\Arduino\sketch_nov8a>.
2025-12-27T22:55:57.853Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <\\elise\tb2\williedocuments\Arduino\blink3>, response: <\\elise\tb2\WillieDocuments\Arduino\blink3>.
2025-12-27T22:55:57.853Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <\\elise\tb2\williedocuments\Arduino\blink3col>, response: <\\elise\tb2\WillieDocuments\Arduino\blink3col>.
2025-12-27T22:55:57.854Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <\\elise\tb2\williedocuments\Arduino\sketch_dec27d>, response: <\\elise\tb2\WillieDocuments\Arduino\sketch_dec27d>.
2025-12-27T22:55:57.855Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <\\elise\tb2\williedocuments\Arduino\sketch_dec26a>, response: <\\elise\tb2\WillieDocuments\Arduino\sketch_dec26a>.
2025-12-27T22:55:57.970Z root ERROR [hosted-plugin: 102548] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.linux as cortex-debug.armToolchainPath is null
2025-12-27T22:55:57.970Z root ERROR [hosted-plugin: 102548] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.osx as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.windows as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.linux as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.osx as cortex-debug.JLinkGDBServerPath is null
2025-12-27T22:55:57.970Z root ERROR [hosted-plugin: 102548] Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.windows as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.linux as cortex-debug.openocdPath is null
2025-12-27T22:55:57.970Z root ERROR [hosted-plugin: 102548] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.osx as cortex-debug.openocdPath is null
2025-12-27T22:55:57.970Z root ERROR [hosted-plugin: 102548] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.windows as cortex-debug.openocdPath is null
2025-12-27T22:55:57.970Z root ERROR [hosted-plugin: 102548] Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.linux as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.osx as cortex-debug.pyocdPath is null
2025-12-27T22:55:57.970Z root ERROR [hosted-plugin: 102548] Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.windows as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.linux as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.osx as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.windows as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.linux as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.osx as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.windows as cortex-debug.stutilPath is null
2025-12-27T22:55:57.970Z root ERROR [hosted-plugin: 102548] Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.linux as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.osx as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.windows as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.linux as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.osx as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.windows as cortex-debug.stm32cubeprogrammer is null
2025-12-27T22:55:58.000Z root INFO [hosted-plugin: 102548] PLUGIN_HOST(102548): PluginManagerExtImpl/init()
2025-12-27T22:55:58.002Z root INFO [hosted-plugin: 102548] PLUGIN_HOST(102548): initializing(vscode-arduino-api@0.1.2 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:55:58.159Z root INFO [hosted-plugin: 102548] PLUGIN_HOST(102548): initializing(json-language-features@1.88.1 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:55:58.167Z root INFO [hosted-plugin: 102548] PLUGIN_HOST(102548): initializing(cortex-debug@1.5.1 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:55:58.168Z root INFO [hosted-plugin: 102548] Debugger contribution has been registered: cortex-debug
2025-12-27T22:55:58.172Z root INFO [hosted-plugin: 102548] PLUGIN_HOST(102548): initializing(vscode-arduino-tools@0.1.3 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:55:58.179Z root INFO [hosted-plugin: 102548] PLUGIN_HOST(102548): initializing(cpp@1.88.1 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:55:58.181Z root INFO [hosted-plugin: 102548] PLUGIN_HOST(102548): initializing(json@1.88.1 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:55:58.183Z root INFO [hosted-plugin: 102548] PLUGIN_HOST(102548): initializing(vscode-language-pack-bg@1.48.3 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:55:58.185Z root INFO [hosted-plugin: 102548] PLUGIN_HOST(102548): initializing(vscode-language-pack-cs@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:55:58.186Z root INFO [hosted-plugin: 102548] PLUGIN_HOST(102548): initializing(vscode-language-pack-de@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:55:58.187Z root INFO [hosted-plugin: 102548] PLUGIN_HOST(102548): initializing(vscode-language-pack-es@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:55:58.188Z root INFO [hosted-plugin: 102548] PLUGIN_HOST(102548): initializing(vscode-language-pack-fr@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:55:58.188Z root INFO [hosted-plugin: 102548] PLUGIN_HOST(102548): initializing(vscode-language-pack-hu@1.48.3 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:55:58.189Z root INFO [hosted-plugin: 102548] PLUGIN_HOST(102548): initializing(vscode-language-pack-it@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:55:58.189Z root INFO [hosted-plugin: 102548] PLUGIN_HOST(102548): initializing(vscode-language-pack-ja@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:55:58.190Z root INFO [hosted-plugin: 102548] PLUGIN_HOST(102548): initializing(vscode-language-pack-ko@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:55:58.191Z root INFO [hosted-plugin: 102548] PLUGIN_HOST(102548): initializing(vscode-language-pack-nl@1.48.3 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:55:58.191Z root INFO [hosted-plugin: 102548] PLUGIN_HOST(102548): initializing(vscode-language-pack-pl@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:55:58.192Z root INFO [hosted-plugin: 102548] PLUGIN_HOST(102548): initializing(vscode-language-pack-pt-BR@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:55:58.192Z root INFO [hosted-plugin: 102548] PLUGIN_HOST(102548): initializing(vscode-language-pack-ru@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:55:58.193Z root INFO [hosted-plugin: 102548] PLUGIN_HOST(102548): initializing(vscode-language-pack-tr@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:55:58.193Z root INFO [hosted-plugin: 102548] PLUGIN_HOST(102548): initializing(vscode-language-pack-uk@1.48.3 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:55:58.194Z root INFO [hosted-plugin: 102548] PLUGIN_HOST(102548): initializing(vscode-language-pack-zh-hans@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:55:58.194Z root INFO [hosted-plugin: 102548] PLUGIN_HOST(102548): initializing(vscode-language-pack-zh-hant@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:55:58.197Z root INFO [hosted-plugin: 102548] PLUGIN_HOST(102548): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\node\jsonClientMain)
2025-12-27T22:55:58.367Z root INFO [hosted-plugin: 102548] PLUGIN_HOST(102548): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\extension.js)
2025-12-27T22:55:58.460Z root INFO [hosted-plugin: 102548] PLUGIN_HOST(102548): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\vscode-arduino-api\extension\dist\extension.js)
2025-12-27T22:55:58.494Z root INFO [hosted-plugin: 102548] calling activation function on VS Code Arduino Tools
calling activation function on Arduino IDE API for VS Code extensions
2025-12-27T22:55:58.497Z root INFO [757ec327-5c73-4c27-b817-e4309f2034da] Starting plugins.
2025-12-27T22:55:58.518Z root INFO [hosted-plugin: 102548] PLUGIN_HOST(102548): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js)
2025-12-27T22:55:58.660Z root INFO [hosted-plugin: 102548] Debug configuration provider has been registered: cortex-debug, trigger: 1
2025-12-27T22:55:58.660Z root INFO [hosted-plugin: 102548] calling activation function on Cortex-Debug
2025-12-27T22:55:58.664Z root INFO [hosted-plugin: 102548] GDB server console created
2025-12-27T22:55:58.766Z root INFO [757ec327-5c73-4c27-b817-e4309f2034da] Start of 23 plugins: 1148.8 ms [Finished 6.319 s after frontend start]
2025-12-27T22:55:58.774Z root INFO [757ec327-5c73-4c27-b817-e4309f2034da] Waiting for backend deployment: 7.0 ms [Finished 6.328 s after frontend start]
2025-12-27T22:55:58.774Z root INFO [757ec327-5c73-4c27-b817-e4309f2034da] Loading plugin contributions
2025-12-27T22:55:59.092Z root INFO [hosted-plugin: 102548] calling activation function on JSON Language Features (built-in)
2025-12-27T22:56:00.169Z daemon INFO time="2025-12-27T17:56:00-05:00" level=info msg="Checking signature" index="C:\\Users\\wdots\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\wdots\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2025-12-27T22:56:00.171Z daemon INFO time="2025-12-27T17:56:00-05:00" level=info msg="Loading hardware from: C:\\Users\\wdots\\AppData\\Local\\Arduino15\\packages"
2025-12-27T22:56:00.172Z daemon INFO time="2025-12-27T17:56:00-05:00" level=info msg="Loading package arduino from: C:\\Users\\wdots\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware"
2025-12-27T22:56:00.174Z daemon INFO time="2025-12-27T17:56:00-05:00" level=info msg="Missing signature file" index="C:\\Users\\wdots\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json"
2025-12-27T22:56:00.175Z daemon INFO time="2025-12-27T17:56:00-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
2025-12-27T22:56:00.175Z daemon INFO time="2025-12-27T17:56:00-05:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
2025-12-27T22:56:00.176Z daemon INFO time="2025-12-27T17:56:00-05:00" level=info msg="Missing signature file" index="C:\\Users\\wdots\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.5.1\\installed.json"
2025-12-27T22:56:00.177Z daemon INFO time="2025-12-27T17:56:00-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2025-12-27T17:56:00-05:00" level=info msg="Loaded platform" platform="arduino:renesas_uno@1.5.1"
2025-12-27T22:56:00.177Z daemon INFO time="2025-12-27T17:56:00-05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\wdots\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2025-12-27T17:56:00-05:00" level=info msg="Loading tools from dir: C:\\Users\\wdots\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
2025-12-27T22:56:00.178Z daemon INFO time="2025-12-27T17:56:00-05:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
2025-12-27T22:56:00.178Z daemon INFO time="2025-12-27T17:56:00-05:00" level=info msg="Loaded tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
2025-12-27T22:56:00.178Z daemon INFO time="2025-12-27T17:56:00-05:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2025-12-27T22:56:00.178Z daemon INFO time="2025-12-27T17:56:00-05:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
2025-12-27T22:56:00.178Z daemon INFO time="2025-12-27T17:56:00-05:00" level=info msg="Loaded tool" tool="arduino:bossac@1.9.1-arduino5"
2025-12-27T22:56:00.178Z daemon INFO time="2025-12-27T17:56:00-05:00" level=info msg="Loaded tool" tool="arduino:dfu-util@0.11.0-arduino5"
2025-12-27T22:56:00.179Z daemon INFO time="2025-12-27T17:56:00-05:00" level=info msg="Loaded tool" tool="arduino:openocd@0.11.0-arduino2"
2025-12-27T22:56:00.179Z daemon INFO time="2025-12-27T17:56:00-05:00" level=info msg="Loading package builtin from: C:\\Users\\wdots\\AppData\\Local\\Arduino15\\packages\\builtin"
2025-12-27T22:56:00.179Z daemon INFO time="2025-12-27T17:56:00-05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\wdots\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2025-12-27T17:56:00-05:00" level=info msg="Loading tools from dir: C:\\Users\\wdots\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
2025-12-27T22:56:00.180Z daemon INFO time="2025-12-27T17:56:00-05:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
2025-12-27T22:56:00.180Z daemon INFO time="2025-12-27T17:56:00-05:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
2025-12-27T22:56:00.180Z daemon INFO time="2025-12-27T17:56:00-05:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.12"
2025-12-27T22:56:00.180Z daemon INFO time="2025-12-27T17:56:00-05:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.3"
2025-12-27T22:56:00.180Z daemon INFO time="2025-12-27T17:56:00-05:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.15.0"
2025-12-27T22:56:00.193Z daemon INFO time="2025-12-27T17:56:00-05:00" level=info msg="Discovery event channel closed builtin:serial-discovery. Exiting goroutine."
2025-12-27T22:56:00.194Z discovery-log INFO {"eventType":"remove","port":{"matchingBoardsList":[],"port":{"address":"COM1","label":"COM1","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2025-12-27T22:56:00.365Z daemon INFO time="2025-12-27T17:56:00-05:00" level=error msg="Killing discovery process: Access is denied." discovery="builtin:serial-discovery"
2025-12-27T22:56:00.365Z daemon INFO time="2025-12-27T17:56:00-05:00" level=info msg="Closed and removed discovery builtin:serial-discovery"
time="2025-12-27T17:56:00-05:00" level=error msg="Stopped decode loop: EOF" discovery="builtin:serial-discovery"
time="2025-12-27T17:56:00-05:00" level=info msg="Discovery event channel closed builtin:mdns-discovery. Exiting goroutine."
2025-12-27T22:56:00.550Z daemon INFO time="2025-12-27T17:56:00-05:00" level=error msg="Killing discovery process: Access is denied." discovery="builtin:mdns-discovery"
time="2025-12-27T17:56:00-05:00" level=info msg="Closed and removed discovery builtin:mdns-discovery"
time="2025-12-27T17:56:00-05:00" level=error msg="Stopped decode loop: EOF" discovery="builtin:mdns-discovery"
2025-12-27T22:56:00.550Z daemon INFO time="2025-12-27T17:56:00-05:00" level=info msg="Discovery event channel closed builtin:dfu-discovery. Exiting goroutine."
2025-12-27T22:56:00.705Z daemon INFO time="2025-12-27T17:56:00-05:00" level=error msg="Killing discovery process: Access is denied." discovery="builtin:dfu-discovery"
2025-12-27T22:56:00.706Z daemon INFO time="2025-12-27T17:56:00-05:00" level=info msg="Closed and removed discovery builtin:dfu-discovery"
time="2025-12-27T17:56:00-05:00" level=error msg="Stopped decode loop: EOF" discovery="builtin:dfu-discovery"
2025-12-27T22:56:00.779Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM1","label":"COM1","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2025-12-27T22:56:00.805Z daemon INFO time="2025-12-27T17:56:00-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\wdots\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" isSingleLibrary=false location=platform
2025-12-27T22:56:00.808Z daemon INFO time="2025-12-27T17:56:00-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\wdots\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.5.1\\libraries" isSingleLibrary=false location=platform
time="2025-12-27T17:56:00-05:00" level=info msg="Loading libraries index file" index="C:\\Users\\wdots\\AppData\\Local\\Arduino15\\library_index.json"
2025-12-27T22:56:00.983Z daemon INFO time="2025-12-27T17:56:00-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\wdots\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
2025-12-27T22:56:00.984Z daemon INFO time="2025-12-27T17:56:00-05:00" level=info msg="Adding libraries dir" dir="\\\\elise\\tb2\\williedocuments\\Arduino\\libraries" isSingleLibrary=false location=user
2025-12-27T22:57:42.319Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <\\elise\tb2\williedocuments\Arduino\blink3col>, response: <\\elise\tb2\WillieDocuments\Arduino\blink3col>.
2025-12-27T22:57:42.323Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <\\elise\tb2\williedocuments\Arduino\sketch_nov8a>, response: <\\elise\tb2\WillieDocuments\Arduino\sketch_nov8a>.
2025-12-27T22:57:42.323Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <\\elise\tb2\williedocuments\Arduino\sketch_dec27d>, response: <\\elise\tb2\WillieDocuments\Arduino\sketch_dec27d>.
2025-12-27T22:57:42.325Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <\\elise\tb2\williedocuments\Arduino\blink3>, response: <\\elise\tb2\WillieDocuments\Arduino\blink3>.
2025-12-27T22:57:42.328Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <\\elise\tb2\williedocuments\Arduino\sketch_dec26a>, response: <\\elise\tb2\WillieDocuments\Arduino\sketch_dec26a>.
2025-12-27T22:57:42.358Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <\\elise\tb2\williedocuments\Arduino\blink3col>, response: <\\elise\tb2\WillieDocuments\Arduino\blink3col>.
2025-12-27T22:57:42.365Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <\\elise\tb2\williedocuments\Arduino\sketch_nov8a>, response: <\\elise\tb2\WillieDocuments\Arduino\sketch_nov8a>.
2025-12-27T22:57:42.365Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <\\elise\tb2\williedocuments\Arduino\sketch_dec27d>, response: <\\elise\tb2\WillieDocuments\Arduino\sketch_dec27d>.
2025-12-27T22:57:42.366Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <\\elise\tb2\williedocuments\Arduino\blink3>, response: <\\elise\tb2\WillieDocuments\Arduino\blink3>.
2025-12-27T22:57:42.366Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <\\elise\tb2\williedocuments\Arduino\sketch_dec26a>, response: <\\elise\tb2\WillieDocuments\Arduino\sketch_dec26a>.
2025-12-27T22:57:42.431Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <\\elise\tb2\williedocuments\Arduino\sketch_dec27a>, response: <\\elise\tb2\WillieDocuments\Arduino\sketch_dec27a>.
2025-12-27T22:57:42.454Z root INFO socked closed
2025-12-27T22:57:42.454Z root INFO closing connection for 1
2025-12-27T22:57:42.454Z root INFO Closing channel on service path '/localization-server'.
2025-12-27T22:57:42.454Z root INFO Closing channel on service path '/os'.
2025-12-27T22:57:42.454Z root INFO Closing channel on service path '/services/commands'.
2025-12-27T22:57:42.454Z root INFO Closing channel on service path '/services/keyboard'.
2025-12-27T22:57:42.454Z root INFO Closing channel on service path '/services/logger'.
2025-12-27T22:57:42.454Z root INFO Closing channel on service path '/services/messageService'.
2025-12-27T22:57:42.454Z root INFO Closing channel on service path '/services/ChannelCloseService'.
2025-12-27T22:57:42.454Z root INFO Closing channel on service path '/services/remote-filesystem'.
2025-12-27T22:57:42.454Z root INFO Closing channel on service path '/services/envs'.
2025-12-27T22:57:42.454Z root INFO Closing channel on service path '/services/authentication-service'.
2025-12-27T22:57:42.454Z root INFO Closing channel on service path '/services/sketches-service'.
2025-12-27T22:57:42.454Z root INFO Closing channel on service path '/services/config-service'.
2025-12-27T22:57:42.454Z root INFO Closing channel on service path '/services/workspace'.
2025-12-27T22:57:42.454Z root INFO Closing channel on service path '/services/notification-service'.
2025-12-27T22:57:42.454Z root INFO Closing channel on service path '/services/arduino-daemon'.
2025-12-27T22:57:42.454Z root INFO Closing channel on service path '/services/stopwatch'.
2025-12-27T22:57:42.454Z root INFO Closing channel on service path '/services/application'.
2025-12-27T22:57:42.454Z root INFO Closing channel on service path '/services/i18n'.
2025-12-27T22:57:42.454Z root INFO Closing channel on service path '/services/quickInput'.
2025-12-27T22:57:42.454Z root INFO Closing channel on service path '/services/debug'.
2025-12-27T22:57:42.454Z root INFO Closing channel on service path '/services/shell-terminal'.
2025-12-27T22:57:42.454Z root INFO Closing channel on service path '/services/quickPick'.
2025-12-27T22:57:42.454Z root INFO Closing channel on service path '/services/task'.
2025-12-27T22:57:42.455Z root INFO Closing channel on service path '/services/search'.
2025-12-27T22:57:42.455Z root INFO Closing channel on service path '/services/hostedPlugin'.
2025-12-27T22:57:42.455Z root INFO Closing channel on service path '/services/plugin-ext'.
2025-12-27T22:57:42.455Z root INFO Closing channel on service path '/services/plugin-paths'.
2025-12-27T22:57:42.455Z root INFO Closing channel on service path '/services/cli-preferences'.
2025-12-27T22:57:42.455Z root INFO Closing channel on service path '/services/boards-service'.
2025-12-27T22:57:42.455Z root INFO Closing channel on service path '/services/response-service'.
2025-12-27T22:57:42.455Z root INFO Closing channel on service path '/services/file-system-ext'.
2025-12-27T22:57:42.455Z root INFO Closing channel on service path '/services/core-service'.
2025-12-27T22:57:42.455Z root INFO Closing channel on service path '/services/example-service'.
2025-12-27T22:57:42.455Z root INFO Closing channel on service path '/services/library-service'.
2025-12-27T22:57:42.455Z root INFO Closing channel on service path '/services/executable-service'.
2025-12-27T22:57:42.455Z root INFO Closing channel on service path '/services/arduino-firmware-uploader'.
2025-12-27T22:57:42.455Z root INFO Closing channel on service path '/services/formatter'.
2025-12-27T22:57:42.455Z root INFO Closing channel on service path '/services/search-in-workspace'.
2025-12-27T22:57:42.455Z root INFO Closing channel on service path '/services/request-service'.
2025-12-27T22:57:42.455Z root INFO Closing channel on service path '/services/keyStore'.
2025-12-27T22:57:42.455Z root INFO Closing channel on service path '/services/languagePackService'.
Closing channel on service path '/services/electron-window'.
Closing channel on service path '/services/ide-updater'.
2025-12-27T22:57:43.516Z root INFO creating connection for 1
2025-12-27T22:57:44.537Z root WARN A command editor.action.toggleStickyScroll is already registered.
2025-12-27T22:57:44.770Z root INFO Start frontend contributions: 347.3 ms [Finished 2.238 s after frontend start]
2025-12-27T22:57:44.770Z root INFO Changed application state from 'init' to 'started_contributions'.
2025-12-27T22:57:44.770Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2025-12-27T22:57:44.770Z root INFO >>> Restoring the layout state...
2025-12-27T22:57:44.911Z root INFO [8903240a-c4d9-4e8f-b78b-fa028839274f] Waiting for backend deployment: 229.3 ms [Finished 2.462 s after frontend start]
2025-12-27T22:57:45.508Z root INFO [hosted-plugin: 25224] PLUGIN_HOST(25224) starting instance
2025-12-27T22:57:46.193Z root INFO [8903240a-c4d9-4e8f-b78b-fa028839274f] Sync of 23 plugins: 1283.3 ms [Finished 3.745 s after frontend start]
2025-12-27T22:57:46.200Z root INFO <<< Nothing to restore.
2025-12-27T22:57:46.261Z root INFO Initialize the workbench layout: 1511.8 ms [Finished 3.772 s after frontend start]
2025-12-27T22:57:46.263Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2025-12-27T22:57:46.263Z root INFO [8903240a-c4d9-4e8f-b78b-fa028839274f] Loading plugin contributions
2025-12-27T22:57:46.263Z root INFO [8903240a-c4d9-4e8f-b78b-fa028839274f] Load contributions of 23 plugins: 33.8 ms [Finished 3.812 s after frontend start]
2025-12-27T22:57:46.306Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2025-12-27T22:57:46.306Z root WARN a registered grammar configuration for 'cpp' language is overridden
2025-12-27T22:57:46.591Z root ERROR [hosted-plugin: 25224] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.linux as cortex-debug.armToolchainPath is null
2025-12-27T22:57:46.591Z root ERROR [hosted-plugin: 25224] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.osx as cortex-debug.armToolchainPath is null
2025-12-27T22:57:46.591Z root ERROR [hosted-plugin: 25224] Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.linux as cortex-debug.JLinkGDBServerPath is null
2025-12-27T22:57:46.591Z root ERROR [hosted-plugin: 25224] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.linux as cortex-debug.openocdPath is null
2025-12-27T22:57:46.591Z root ERROR [hosted-plugin: 25224] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.osx as cortex-debug.openocdPath is null
2025-12-27T22:57:46.591Z root ERROR [hosted-plugin: 25224] Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.linux as cortex-debug.pyocdPath is null
2025-12-27T22:57:46.591Z root ERROR [hosted-plugin: 25224] Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.osx as cortex-debug.pyocdPath is null
2025-12-27T22:57:46.592Z root ERROR [hosted-plugin: 25224] Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.linux as cortex-debug.PEGDBServerPath is null
2025-12-27T22:57:46.592Z root ERROR [hosted-plugin: 25224] Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.windows as cortex-debug.PEGDBServerPath is null
2025-12-27T22:57:46.592Z root ERROR [hosted-plugin: 25224] Conflict in settings file Default: Ignoring cortex-debug.stutilPath.osx as cortex-debug.stutilPath is null
2025-12-27T22:57:46.592Z root ERROR [hosted-plugin: 25224] Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.linux as cortex-debug.stlinkPath is null
2025-12-27T22:57:46.592Z root ERROR [hosted-plugin: 25224] Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.linux as cortex-debug.stm32cubeprogrammer is null
2025-12-27T22:57:46.592Z root ERROR [hosted-plugin: 25224] Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.windows as cortex-debug.stm32cubeprogrammer is null
2025-12-27T22:57:46.651Z root INFO [hosted-plugin: 25224] PLUGIN_HOST(25224): PluginManagerExtImpl/init()
2025-12-27T22:57:46.654Z root INFO [hosted-plugin: 25224] PLUGIN_HOST(25224): initializing(vscode-arduino-api@0.1.2 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:57:46.728Z root INFO [hosted-plugin: 25224] PLUGIN_HOST(25224): initializing(json-language-features@1.88.1 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:57:46.732Z root INFO [hosted-plugin: 25224] PLUGIN_HOST(25224): initializing(cortex-debug@1.5.1 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:57:46.733Z root INFO [hosted-plugin: 25224] Debugger contribution has been registered: cortex-debug
2025-12-27T22:57:46.734Z root INFO [hosted-plugin: 25224] PLUGIN_HOST(25224): initializing(vscode-arduino-tools@0.1.3 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:57:46.736Z root INFO [hosted-plugin: 25224] PLUGIN_HOST(25224): initializing(cpp@1.88.1 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:57:46.738Z root INFO [hosted-plugin: 25224] PLUGIN_HOST(25224): initializing(json@1.88.1 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:57:46.743Z root INFO [hosted-plugin: 25224] PLUGIN_HOST(25224): initializing(vscode-language-pack-bg@1.48.3 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:57:46.744Z root INFO [hosted-plugin: 25224] PLUGIN_HOST(25224): initializing(vscode-language-pack-cs@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:57:46.745Z root INFO [hosted-plugin: 25224] PLUGIN_HOST(25224): initializing(vscode-language-pack-de@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:57:46.746Z root INFO [hosted-plugin: 25224] PLUGIN_HOST(25224): initializing(vscode-language-pack-es@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:57:46.747Z root INFO [hosted-plugin: 25224] PLUGIN_HOST(25224): initializing(vscode-language-pack-fr@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:57:46.748Z root INFO [hosted-plugin: 25224] PLUGIN_HOST(25224): initializing(vscode-language-pack-hu@1.48.3 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:57:46.748Z root INFO [hosted-plugin: 25224] PLUGIN_HOST(25224): initializing(vscode-language-pack-it@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:57:46.749Z root INFO [hosted-plugin: 25224] PLUGIN_HOST(25224): initializing(vscode-language-pack-ja@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:57:46.750Z root INFO [hosted-plugin: 25224] PLUGIN_HOST(25224): initializing(vscode-language-pack-ko@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:57:46.750Z root INFO [hosted-plugin: 25224] PLUGIN_HOST(25224): initializing(vscode-language-pack-nl@1.48.3 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:57:46.751Z root INFO [hosted-plugin: 25224] PLUGIN_HOST(25224): initializing(vscode-language-pack-pl@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:57:46.751Z root INFO [hosted-plugin: 25224] PLUGIN_HOST(25224): initializing(vscode-language-pack-pt-BR@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:57:46.752Z root INFO [hosted-plugin: 25224] PLUGIN_HOST(25224): initializing(vscode-language-pack-ru@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:57:46.752Z root INFO [hosted-plugin: 25224] PLUGIN_HOST(25224): initializing(vscode-language-pack-tr@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:57:46.753Z root INFO [hosted-plugin: 25224] PLUGIN_HOST(25224): initializing(vscode-language-pack-uk@1.48.3 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:57:46.753Z root INFO [hosted-plugin: 25224] PLUGIN_HOST(25224): initializing(vscode-language-pack-zh-hans@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:57:46.754Z root INFO [hosted-plugin: 25224] PLUGIN_HOST(25224): initializing(vscode-language-pack-zh-hant@1.96.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-12-27T22:57:46.818Z root INFO [hosted-plugin: 25224] PLUGIN_HOST(25224): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\node\jsonClientMain)
2025-12-27T22:57:46.876Z root INFO [hosted-plugin: 25224] PLUGIN_HOST(25224): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\vscode-arduino-api\extension\dist\extension.js)
2025-12-27T22:57:46.880Z root INFO [hosted-plugin: 25224] calling activation function on Arduino IDE API for VS Code extensions
2025-12-27T22:57:46.883Z root INFO [8903240a-c4d9-4e8f-b78b-fa028839274f] Starting plugins.
2025-12-27T22:57:46.963Z root INFO [hosted-plugin: 25224] PLUGIN_HOST(25224): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js)
2025-12-27T22:57:47.003Z root INFO [hosted-plugin: 25224] Debug configuration provider has been registered: cortex-debug, trigger: 1
2025-12-27T22:57:47.004Z root INFO [hosted-plugin: 25224] calling activation function on Cortex-Debug
2025-12-27T22:57:47.010Z root INFO [hosted-plugin: 25224] GDB server console created
2025-12-27T22:57:47.015Z root INFO [8903240a-c4d9-4e8f-b78b-fa028839274f] Start of 23 plugins: 678.8 ms [Finished 4.566 s after frontend start]
2025-12-27T22:57:47.144Z root INFO [hosted-plugin: 25224] calling activation function on JSON Language Features (built-in)
2025-12-27T22:57:47.262Z root INFO Frontend application start: 2776.6 ms [Finished 115.918 s after backend start]
2025-12-27T22:57:47.286Z root INFO Replace loading indicator with ready workbench UI (animation): 832.0 ms [Finished 4.647 s after frontend start]
2025-12-27T22:57:47.286Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2025-12-27T22:57:47.286Z root WARN Linked preference "workbench.colorCustomizations" not found.
2025-12-27T22:57:47.286Z root INFO Executing startup tasks:
2025-12-27T22:57:47.286Z root INFO - 'arduino-use-inherited-boards-config' , args: [{},{}]
2025-12-27T22:57:47.286Z root INFO - 'arduino-delete-sketch' , args: [{"toDelete":"file:///c%3A/Users/wdots/AppData/Local/Temp/.arduinoIDE-unsaved20251127-92984-11lxoj4.376w/sketch_dec27a"}]
Sketch file:///c%3A/Users/wdots/AppData/Local/Temp/.arduinoIDE-unsaved20251127-92984-11lxoj4.376w/sketch_dec27a was scheduled for deletion
Successfully deleted sketch c:\Users\wdots\AppData\Local\Temp\.arduinoIDE-unsaved20251127-92984-11lxoj4.376w\sketch_dec27a
Successfully completed the scheduled sketch deletion: c:\Users\wdots\AppData\Local\Temp\.arduinoIDE-unsaved20251127-92984-11lxoj4.376w\sketch_dec27a
2025-12-27T22:57:47.807Z root ERROR ---- !!!SLOW!!! DURATION: search took 520.500 ms. Args: [{"type":"Updatable"}] ----
2025-12-27T22:57:50.970Z root ERROR Uncaught Exception: TypeError: Cannot read properties of undefined (reading 'forEach')
2025-12-27T22:57:50.970Z root ERROR TypeError: Cannot read properties of undefined (reading 'forEach')
at Stream.<anonymous> (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:148402)
at Stream.emit (node:events:519:28)
at Stream.i (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1131936)
at Stream.emit (node:events:531:35)
at f (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:5818380)
at o.write (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:5818737)
at Stream.ondata (node:internal/streams/legacy:21:31)
at l (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:6839037)
at c.queue.c.push (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:6839254)
2025-12-27T22:57:55.746Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <\\elise\tb2\williedocuments\Arduino\sketch_dec26a>, response: <\\elise\tb2\WillieDocuments\Arduino\sketch_dec26a>.
2025-12-27T22:57:55.747Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <\\elise\tb2\williedocuments\Arduino\blink3>, response: <\\elise\tb2\WillieDocuments\Arduino\blink3>.
2025-12-27T22:57:55.748Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <\\elise\tb2\williedocuments\Arduino\sketch_dec27d>, response: <\\elise\tb2\WillieDocuments\Arduino\sketch_dec27d>.
2025-12-27T22:57:55.750Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <\\elise\tb2\williedocuments\Arduino\blink3col>, response: <\\elise\tb2\WillieDocuments\Arduino\blink3col>.
2025-12-27T22:57:55.752Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <\\elise\tb2\williedocuments\Arduino\sketch_nov8a>, response: <\\elise\tb2\WillieDocuments\Arduino\sketch_nov8a>.
2025-12-27T22:57:55.752Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <\\elise\tb2\williedocuments\Arduino\sketch_dec27a>, response: <\\elise\tb2\WillieDocuments\Arduino\sketch_dec27a>.
