Skip HTTP Header from GET request
I need help with my project.
I use Arduino Mega + ESP8266 for communication with Node.js in my local server.
Here is my code:
void ConexaoServer(){
    uint8_t buffer[1024] = {0};
    if (wifi.createTCP(HOST_NAME, HOST_PORT)) {
        Serial.print("Conexao com o Host OK!\r\n");
        Serial.print("Conexao com o Host com ERRO!\r\n");
    char *ComandoGET = "GET /teste HTTP/1.1\r\nHost: SmartHome\r\nConnection: close\r\n\r\n";
    wifi.send((const uint8_t*)ComandoGET, strlen(ComandoGET));
    uint32_t len = wifi.recv(buffer, sizeof(buffer), 10000);
    if (len > 0) {
        Serial.print("Received:[");
        for(uint32_t i = 0; i < len; i++) {
            Serial.print((char)buffer[i]);
        Serial.print("]\r\n\r\n");
And i receive from Node.js in Serial
Received:[HTTP/1.1 200 OK
X-Powered-By: Express
Content-Type: text/html; charset=utf-8
Content-Length: 4
ETag: W/"4-wArb1VtkpsN6In8g50pGNw"
Date: Wed, 31 Aug 2016 01:26:41 GMT
Connection: close
Luiz]
But i want to receive just "Received:[Luiz]". How i can do this?
Thanx!
You can't. You have NO control over what the server sends.
You could, of course, read and discard all the data, until the blank line arrives. When that happens, you could then store the data.
These are some functions I use to help me search for stuff int strings. you could use these to find the start and end of what you want and dump the rest
int strpos(String haystack, String needle,int offset)
  int foundpos = -1;
  for (offset; (offset <= haystack.length() - needle.length()); offset++) {
    if (haystack.substring(offset,needle.length()+offset) == needle) {
      foundpos = offset;
  return foundpos;
int strpos(char * haystack, char * needle,int offset)
  char * Pointer;
  Pointer = strstr(haystack+offset, needle)+offset;
  return(&Pointer[0] - &haystack[0]);
String str_replace(String Search, String Replace, String Subject){
  Subject.replace(Search, Replace);
  return(Subject);
PaulS:
Hmmm, i undertand, but how i can do this?
zhomeslice:
 int foundpos = -1;
     foundpos = offset;
 return foundpos;
 char * Pointer;
 return(Subject);
U can comment the code? Thanks!
Here is some examples as to how the functions work while searching for the start and end of what you are looking for in the returned strings
char *Haystack = "This is a test schetch and it dimonstrates the strpos() and str_replace() funcitons.";
char *Needle = "and";
String HaystackString = "I perfer using char * for strings but you can do it this way also";
String NeedleString = "you can do it";
int pos;
String NewString;
  Serial.begin(115200);                   // diagnostic channel
  Serial.println(Haystack);
  // using char *
  pos = strpos(Haystack,Needle,0); // Haystack is what you are looking in, Needle is what you are looking for, offset is to start looking at a point further into the string
  Serial.print("We found the first and at:");  Serial.println(pos);
  pos = strpos(Haystack,Needle,pos + 1); // Lets start looking for the second instance of and by offsetting the start by one character from the first instance of and
  Serial.print("We found the Second and at:");  Serial.println(pos);
  // using String
  pos = strpos(HaystackString,NeedleString,0); // Lets start looking for the second instance of and by offsetting the start by one character from the first instance of and
  Serial.print("We found the 'you can do it' at:");  Serial.println(pos);
  NewString = str_replace("this way also", "like this", HaystackString);
  Serial.print("OldString:");  Serial.println(HaystackString);
  Serial.print("NewString:");  Serial.println(NewString);
int strpos(String haystack, String needle, int offset)
  int foundpos = -1;
    if (haystack.substring(offset, needle.length() + offset) == needle) {
      foundpos = offset;
  return foundpos;
int strpos(char * haystack, char * needle, int offset)
  char * Pointer;
  Pointer = strstr(haystack + offset, needle) + offset;
  return (&Pointer[0] - &haystack[0]);
String str_replace(String Search, String Replace, String Subject) {
  return (Subject);
Once you get the String.x example running, and understand the logic... rewrite it without the String class (using C char handling).
Less memory, faster and far more flexible.
Since you only need to store at most 3 characters to determine if it is time to store the important data, that example, while interesting, is not necessary.
If you get a \n, save it. If not, discard it. If the next character is a \r (as it should be), you have received an end of record marker. If the next character is not a \n, the line is not blank, so you don't care about that data.
A brute force method to do this is:
Save each character read into the last element of a 4 element array, after shifting the existing last three characters up a position.
Compare the array to "\n\r\n\r". If they match, then the remaining data coming from the server is the data you want. If not, keep reading and checking.
