Hi All,
I'm using an Arduino Mega 2560 R3 and an Adafruit Data Logging Shield to record data from 2 LIS3DH accelerometers. Currently, the fastest updates I can get is around 120Hz. I need to be able to record around 800 - 1200Hz. The sensors should support that. I'm thinking there is something in my sketch that is preventing faster reading/writing. Writing to the SD card could also be another problem, but I'm recording several records before writing so if that were the only problem I'd expect to see timestamps at faster intervals with periodic long intervals when writing. I've included the sketch and a fritzing for your review. Also, the SD card is a 16gb ADATA 4c.
// based on https://learn.adafruit.com/adafruit-data-logger-shield/using-the-real-time-clock-3
#include <Adafruit_LIS3DH.h>
#include <Adafruit_Sensor.h>
#include <SPI.h>
#include <SD.h>
#include <Wire.h>
#include <RTClib.h>
// A simple data logger for the Arduino LIS3DH
// how many milliseconds between grabbing data and logging it. 1000 ms is once a second
#define LOG_INTERVAL 2.5 // mills between entries (reduce to take more/faster data)
// how many milliseconds before writing the logged data permanently to disk
#define SYNC_INTERVAL 1000 // mills between calls to flush() - to write data to the card
uint32_t syncTime = 0; // time of last sync()
#define WAIT_TO_START 0 // Wait for serial input in setup()
// the digital pins that connect to the LEDs
#define redLEDpin 2
#define greenLEDpin 3
// Used for software SPI
#define LIS3DH_CLK 13
#define LIS3DH_MISO 12
#define LIS3DH_MOSI 11
// Used for hardware & software SPI
#define LIS3DH1_CS 10
#define LIS3DH2_CS 8
Adafruit_LIS3DH accel_1 = Adafruit_LIS3DH(LIS3DH1_CS, LIS3DH_MOSI, LIS3DH_MISO, LIS3DH_CLK);
Adafruit_LIS3DH accel_2 = Adafruit_LIS3DH(LIS3DH2_CS, LIS3DH_MOSI, LIS3DH_MISO, LIS3DH_CLK);
const int s1 = 10;
const int s2 = 8;
RTC_PCF8523 RTC; // define the Real Time Clock object
// for the data logging shield, we use digital pin 10 for the SD cs line
const int chipSelect = 53;
// the logging file
File logfile;
void error(char *str)
Serial.print("error: ");
Serial.println(str);
// red LED indicates error
digitalWrite(redLEDpin, HIGH);
while (1);
void setup(void)
Serial.println("Accelerometer Write Test"); Serial.println("");
digitalWrite(s1, HIGH);
digitalWrite(s2, HIGH);
/* Initialise the sensor */
if (!accel_1.begin() | !accel_2.begin() )
/* There was a problem detecting LIS3DH ... check your connections */
Serial.println("Ooops, LIS3DH not detected ... Check your wiring!");
while (1);
/* Set the range to whatever is appropriate for your project */
char g_range = LIS3DH_RANGE_16_G;
accel_1.setRange(g_range);
accel_2.setRange(g_range);
char freq = LIS3DH_DATARATE_LOWPOWER_5KHZ; //Changing this doesn't seem to have any effect
accel_1.setDataRate(freq);
accel_2.setDataRate(freq);
// use debugging LEDs
pinMode(redLEDpin, OUTPUT);
pinMode(greenLEDpin, OUTPUT);
#if WAIT_TO_START
Serial.println("Type any character to start");
while (!Serial.available());
#endif //WAIT_TO_START
// initialize the SD card
Serial.print("Initializing SD card...");
// make sure that the default chip select pin is set to
// output, even if you don't use it:
pinMode(53, OUTPUT);
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
error("Card failed, or not present");
Serial.println("card initialized.");
// create a new file
char filename[] = "LOGGER00.CSV";
for (uint8_t i = 0; i < 100; i++) {
filename[6] = i / 10 + '0';
filename[7] = i % 10 + '0';
if (! SD.exists(filename)) {
// only open a new file if it doesn't exist
logfile = SD.open(filename, FILE_WRITE);
break; // leave the loop!
if (! logfile) {
error("couldnt create file");
Serial.print("Logging to: ");
Serial.println(filename);
// connect to RTC
Wire.begin();
if (!RTC.begin()) {
logfile.println("RTC failed");
#if ECHO_TO_SERIAL
Serial.println("RTC failed");
#endif //ECHO_TO_SERIAL
logfile.println("millis,accel_1x, accel_1y, accel_1z,accel_2x,accel_2y,accel_2z");
void loop(void)
DateTime now;
// delay for the amount of time we want between readings
delay(LOG_INTERVAL);
digitalWrite(greenLEDpin, HIGH);
// log milliseconds since starting
uint32_t m = millis();
logfile.print(m); // milliseconds since start
logfile.print(", ");
accel_1.read(); // get X Y and Z data at once
accel_2.read();
logfile.print(accel_1.x);
logfile.print(accel_1.y);
logfile.print(accel_1.z);
logfile.print(accel_2.x);
logfile.print(accel_2.y);
logfile.print(accel_2.z);
logfile.print("\n");
digitalWrite(greenLEDpin, LOW);
// Now we write data to disk! Don't sync too often - requires 2048 bytes of I/O to SD card
// which uses a bunch of power and takes time
if ((millis() - syncTime) < SYNC_INTERVAL) return;
syncTime = millis();
// blink LED to show we are syncing data to the card & updating FAT!
logfile.flush();
digitalWrite(redLEDpin, LOW);
I'm willing to consider all alternatives including alternative platforms like Raspberry Pi etc. Thank you for any help!
