I have recently salvaged a SM8958AC25PP 25MHz 32KB internal flash MCU from and old UPS system. I have a good understanding of the basics of arduino and its coding and was wondering if this chip could be programmed by the arduino IDE. I have both ftdi and Arduino as ISP available if needed.
Also, I found a board, connected to the board the mcu was on. I'm not sure how to use it, but it did connect to a pc for diagnostics and firmware updates. The pic is attached to this post.
So can you please let me know if this chip is a good one to play around with and use, or if its too complex and should be left alone.
Thanks.
The short answer is "no." It's an 8051-style CPU, which is not supported by the Arduino IDE...
You can find more my searching the forums for "8051" - they've come up a couple of times.
(Arduino-like IDEs and libraries are currently available for AVR, MSP430, PIC32, ESP8266, some x86, ARC, and assorted ARM chips. Which is a pretty good and somewhat diverse set. But AFAIK, there hasn't been any effort toward the 8051 architecture. Perhaps largely because there isn't any free C++ compiler for 8051...)
