But they're also described as "amphibious" - so who knows what on earth they mean?!
This is the trouble with buying stuff like this from places like Amazon - you're not going to get decent specs, and there's no tech support.
This is one of the key reasons they're cheap!
In order to pull water against gravity, the pump MUST be able to pump air in order to make a vacuum so air pressure can force the water up to the pump. None of these are that type of pump. You either have to prime the pump and maintain a water level so it can pump water, or get a pump that can work for you. Th=at would be a peristaltic or a piston pump or similar.
Well I guess that I will just place the pump in the water.
I think I will get some different sizes of tubing and try it out.
Because these pumps seem to be generic so I though somebody would know what tubing they use.
It doesn't necessarily need to be in the water - just to have a head of water at its inlet.
Another trouble with these kinds of things: there's no guarantee that what you get will be exactly the same - especially where there's no specification at all of the inlet & outlet sizes.
Did some research and allot of people use 6mm tubes. Maybe I could use 1/4 inch to(have some from drip irrigation and it is sturdy for outside).
Thanks.
Or run the pump long enough to keep an overhead tank from emptying if not to keep a sump hole from overflowing when the washer is draining and the water heater springs a leak. At 5000 liters/3600 second hour, how many seconds to top an overhead tank up?
