Using a dc water pump for my project
I want clarify that would it be possible for me use this dc pump with my project without using a stepper motor.
You can use this.
You will need to control this with a relay or a MOS FET
You will need an external power supply for the motor.
You will need a diode 1N4007 across the motor terminals, reversed biased.
DC 3v to 6v submersible pump
micro mini submercible water pump 3v to 6v
DC water pump for DIY
DC pump for HOBBY kit
It's already got a motor.
You will need a motor driver (a transistor or MOSFET) if you want to control it with the Arduino.
Operating : 3v to 6v DC Power consumption: 0.4W to 1.5W
"Wost case" with 2.5W @ 3V that works-out to 2.5/3 = 830mA. So your driver circuit should be able to handle at least ~1 Amp.
[u]This solenoid driver circuit[/u] should work.
An opto coupled relay would be the easiest. 10 amps are plentiful for Arduino projects.
I switch exactly the same pump with a FET (overkill IRF3708), driven like DVDdoug suggested (I have an additional pulldown on the Arduino side).
just to let you know that if you use 12VDC, i will REALLY put out some flow !
maybe only for a few minutes (seconds??) till it burns out however.
I was super impressed at the one I bought after connecting it to 12VC. and am VERY lucky it did not burn out in that first 5 second test.....
using the CORRECT voltage will not be as impressive.
at 5volts, it is a decent pump and if you are watering plants, it will do that very well.
