If you had to recommend an off-the-shelf Arduino module with Wifi, no more than 2 or 3 GPIOs, battery-powered (with low power mode support) to be turned on every while for a few seconds by one of the GPIOs, ... Which one would you choose?
... and yes, cost is an issue. The cheaper, the better!
pylon:
ESP-01 is probably the smallest board and matches your specs. Why are you asking if you already know that it's an ESP8266?
Thanks pylon. I´m asking becauase there are so many sub-models of ESP8266 (ESP01, 03, 12, Wemos Mini, etc) and hopefully somebody will have first hand experience in a similar project.
An ESP8266 module, like the ESP-01, is usually used as a WiFi add-on for other boards,
because it has no supporting parts to power or program it.
It can be used stand-alone, with only a 3.3volt supply, after programming with another board.
Boards with an ESP-12 module, like a WeMos D1 mini, are meant to be used stand-alone,
because they have all the supporting parts for powering/programming.
All you need is a power supply, like a 5volt cellphone charger connected to the USB socket.
Leo..
tpbertu:
... and hopefully somebody will have first hand experience in a similar project.
Which is so far, a mystery.
I use many ESP boards in my projects. The ESP8266-01 is the smallest, but you must supply it with 3.3V, so is it really the smallest when you add a 3.3V regulator. My go-to board for most projects is the Wemos D1 Mini which has an on-board regulator and can be powered by any 5V phone charger.
I´ve read about a project with ESP-03 powered with a coin cell (adding a big cap to provide the current peak required), or with 2xAA batteries. I will give that a try!
The ESP-01, like most models, has an antenna, of the "zig zag" PCB variety.
If you are going to power it from a USB supply, it has an adaptor which includes the 3.3 V regulator and there is a programming version. What is convenient is that you can swap easily between the programming adapter and one built into your "target" system.
The ESP-01 has four available I/O. There is rarely a need to add it to some other MCU-based device as it is itself more powerful and there are straightforward expanders to add many I/O.
