smart room
Hi there,
i have a project that could control light intensity as well as temperature in a room using Pir sensor, an LDR and a DHT11.
however even if the light intensity is enough, my LED switches on.
help please.
I am using the following as my code :
#include "DHT.h"
#define DHTPIN 2     // what pin we're connected to
#define DHTTYPE DHT11   // DHT 11  (AM2302)
#define fan 4
#define photocellPin 0  // photocell attach to A0
#define pirPin 36  //PIR attach to pin 36
#define lightPin 13 // attach light to pin 13
int lightState = 0;
int maxHum = 45;
int maxTemp = 35;
int Threshold = 900;
int isLightOn = LOW;
int isFanOn = LOW;
int val = 0;  // variable for reading the pin status
int sensorValue = 0;
#define uint8 unsigned char
DHT dht(DHTPIN, DHTTYPE);
uint8 pirValue = 0;  //store the PIR state
  pinMode(fan, OUTPUT);
   pinMode(pirPin, INPUT);
   pinMode(photocellPin,INPUT);
     pinMode(lightPin,OUTPUT);
  dht.begin();
  // Wait a few seconds between measurements.
        sensorValue = analogRead(photocellPin);  // Read the sensor pin
        val = digitalRead(pirPin);  // read input value
  if (val == HIGH) {            // check if motion
      if (isLightOn == false) {
 Serial.print(sensorValue);
       if (sensorValue > Threshold)  // If light level is low is detected
        digitalWrite(lightPin, HIGH); //switch light on
         isLightOn = true;
  // Reading temperature or humidity takes about 250 milliseconds!
  // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
  float h = dht.readHumidity();
  // Read temperature as Celsius
  float t = dht.readTemperature();
  // Check if any reads failed and exit early (to try again).
  if (isnan(h) || isnan(t)) {
    Serial.println("Failed to read from DHT sensor!");
    return;
  if(h > maxHum || t > maxTemp) {
      digitalWrite(fan, HIGH);
       isFanOn = true;
     if (val == LOW)
     if(isLightOn == true) {
      digitalWrite(lightPin, LOW);  //switch off light
        isLightOn = false;
      if (isFanOn == HIGH) {
     digitalWrite(fan, LOW);
     isFanOn = false;
  Serial.print("Humidity: ");
  Serial.print(h);
  Serial.print(" %\t");
  Serial.print("Temperature: ");
  Serial.print(t);
  Serial.println(" *C ");
   pirValue = digitalRead(pirPin);
    Serial.println("Pir State: ");
    Serial.println(pirValue);
    digitalWrite(lightPin, pirValue);
        Serial.print("Photocell Value: ");
    Serial.println(analogRead(photocellPin));
