Hi all,
I want to make smart a smoke alarm (of course I will have non-modified ones just in case). I have read the datasheet, I just wanted someone more experienced to cast their eye over it.
Does this look like it will work hardware wise?
Here is the circuit layout I am proposing, a basic voltage divider to sense the state of pin 7. With my voltmeter it reads 8.6V when sounding, and 0V normally. As the datasheet state there is a built in 280K resistor I am thinking I will be fine with a voltage divider in the 160K/100K ratio.
I chose D5/GPIO14 as it does not get pulled low or high at boot, so will not trigger an alarm on the bi-directional pin 7 IO.
The datasheet say this about the IO pin 7:
3.5 Interconnect
The bidirectional I/O pin allows the interconnection of
multiple detectors. In a local alarm condition, this pin is
driven high immediately through a constant current
source. Shorting this output to ground will not cause
excessive current. The I/O is ignored as an input during
a local alarm.
The I/O pin has a 280k nominal pull-down resistor, so
the pin may be left unconnected.
The I/O pin also has an NMOS discharge device that is
active for 1 second after the conclusion of any type of
local alarm. This device helps to quickly discharge any
capacitance associated with the interconnect line.
If a remote active high signal is detected, the device
goes into remote alarm and the horn will be active.
Internal protection circuitry allows for the signaling unit
to have a higher supply voltage than the signaled unit,
without excessive current draw.
The interconnect input has a digital filter that ensures
filtering out pulses of up to 300 ms. Filter pulses will be
ignored and not affect internal timing of the part. This
allows for interconnection to other types of alarms
(carbon monoxide for example) that may have a pulsed
interconnect signal.
The remote alarm delay (370 ms to 1.27s) specifies the
time from the interconnect going active to sounding the
piezo horn alarm.
Thanks for any advice, and for reading!
