I wrote a smooth sine wave transition for servos between any two positions with some added features.
Recent edit: fixed cross contamination delay problem
Features:
-Multiple servos can run simultaneously, each with different start speed, end speed, start position, end position and delay time to start values.
-the option of different start and end speeds allows the on-the-fly FOR loop stretch of the sine wave to simulate a more natural movement
-all position computation is done at the (1700 unit) resolution of the servo so there is basically little to no twitch.
-you can declare the desired movement positions of the servo in microseconds (position value)
-servo variables and movement function is modular so more servos can be added (I usually run a similar code with 6 servos simultaneous movement)
Limitations:
-all servo movement function is only 1 direction for each sine wave movement of servo, code waits for all servos to complete their singular motion before being able to go to next programmed move function -I am working on a continuous multi-count wave based on arrays... I will update latter.
The code is attached, a sample of the code is shown here (due to word limit on posting)
//############### small sample of larger code included here, does not include void loop() nor variable establishment.
//start of primary move function that includes all servos and is called up and activated per each event
void movef(float ecycle,float w81,float spa1,float spb1,float yprev1,float ynext1,float w82,float spa2,float spb2,float yprev2,float ynext2)
delay(1); //master delay
count1 = 1; //reset of count#
speedtick1 = 1; //reset of speedtick#
b1=(2*pie/(sinsize*2)); //coefficient of sine math function
count2 = 1;
speedtick2 = 1;
b2=(2*pie/(sinsize*2));
if(ynext1 > yprev1) //sets sine wave coefficients depending on positions
a1= (ynext1-yprev1)/2; //coefficient of sine math function
c1= (1.5)*pie; //coefficient of sine math function
d1= yprev1+a1; //coefficient of sine math function
else //(ynext# < yprev#)
a1= (yprev1-ynext1)/2;
c1= (0.5)*pie;
d1= yprev1-a1;
if(ynext2 > yprev2)
a2= (ynext2-yprev2)/2;
c2= (1.5)*pie;
d2= yprev2+a2;
a2= (yprev2-ynext2)/2;
c2= (0.5)*pie;
d2= yprev2-a2;
//###coefficient establishment for all sine waves end ###
int per1=0; //reset of all trigger values in case there is carry over from a previous run
int per2=0;
//global loop for all servos cycles by each servo and sees if it has an tiny move.
for (float count = 0; count < ecycle; count +=1)
//traditional speed values start off as spa# and end up as spb# as count# ticks away on the fly as curve is being drawn.
// result is a sine curve that is compressed in the x axis on one end (spa#=large number) and stretched on other end (spb#=small number).
if (spa1 > spb1) {speed1=((count1+1)/sinsize)*(spa1-spb1) + spb1;} //start fast end slow
else {speed1= ((count1+1)/sinsize)*(spb1-spa1)+ spa1;} // start slow end fast
if (spa2 > spb2) {speed2=((count2+1)/sinsize)*(spa2-spb2) + spb2;} //start fast end slow
else {speed2= ((count2+1)/sinsize)*(spb2-spa2)+ spa2;} // start slow end fast
// servo #1 3 states or cases
if (count < w81) //case 1 servo not ready to move yet
servo1.writeMicroseconds(yprev1);
else if (count>w81 && count1 > sinsize) //case 3 motion is done and position is held
servo1.writeMicroseconds(ynext1);
per1=1; //declares this servo is finished with its movement
else if (count > w81) //case 2 sin wave function active with optional hold position while big loop asks other servos for their turn
if (count1 < sinsize && speedtick1 == 1) //new position of servo is written
yvar1= a1*sin((count1)*b1+c1)+d1; //the math function
servo1.writeMicroseconds(yvar1); //throws a command at the servo
speedtick1 += 1; // start of increment to count for possible pauses at this position to simulate slow
count1 += 1; //increments sine wave operator x in y=f(x)
else if (speedtick1 > 1 && speedtick1 < speed1) //sine wave is sustained at old value for 1 to speed# as counted by speedtick#
speedtick1 += 1; //increments speedtick1 to delay the servo at one position along its travel to simulate a speed
else //sine wave is now permitted to continue by having speedtick# reset
count1+=1; //lock out the sine function from going past sinsize by ever increasing count#
speedtick1 = 1; //reset for next fly through of sine function
} //end if statement for case 2
//servo #2
if (count < w82) //notes same as servo #1 above
servo2.writeMicroseconds(yprev2);
else if (count>w82 && count2 > sinsize)
servo2.writeMicroseconds(ynext2);
per2=1;
else if (count > w82)
if (count2 < sinsize && speedtick2 == 1)
yvar2= a2*sin((count2)*b2+c2)+d2;
servo2.writeMicroseconds(yvar2);
speedtick2 += 1;
count2 += 1;
else if (speedtick2 > 1 && speedtick2 < speed2)
speedtick2 += 1;
count2+=1;
speedtick2 = 1;
if(per1 == 1 && per2 == 1)//breaks FOR loop out of further un necessary cycles as all servos report their movement complete
} //end of for loop statement for all servo steps
} //end of void subroutine function for entire move function
SERVO_SHIMMY_V75.ino (10 KB)
