smoothing out potentiometer values.
I have a potentiometer attached to arduino and I mapped the values from 0 to 270, the problem that the values are always changing by 1. for example
180
181
181
181
180
181
180
180
181
how should i go about fixing this?
int rightShoulderX;
int rightShoulderY;
int rightElbowX;
int rightElbowY;
int rightShoulderXt;
int rightShoulderYt;
int rightElbowXt;
int rightElbowYt;
  rightShoulderXt=analogRead(0);
rightShoulderYt=analogRead(1);
rightElbowXt=analogRead(2);
rightElbowYt=analogRead(3);
rightShoulderXt=map(rightShoulderXt,0,1028,0,270);
rightShoulderYt=map(rightShoulderYt,0,1028,0,270);
rightElbowXt=map(rightElbowXt,0,1028,0,270);
rightElbowYt=map(rightElbowYt,0,1028,0,270);
delay(8);
rightShoulderX=analogRead(0);
rightShoulderY=analogRead(1);
rightElbowX=analogRead(2);
rightElbowY=analogRead(3);
rightShoulderX=map(rightShoulderX,0,1028,0,270);
rightShoulderY=map(rightShoulderY,0,1028,0,270);
rightElbowX=map(rightElbowX,0,1028,0,270);
rightElbowY=map(rightElbowY,0,1028,0,270);
if(rightShoulderX-rightShoulderXt==2||rightShoulderX-rightShoulderXt==-2);
  rightShoulderX=rightShoulderXt;
if(rightShoulderY-rightShoulderYt==2||rightShoulderY-rightShoulderYt==-2);
  rightShoulderY=rightShoulderYt;
if(rightElbowX-rightElbowXt==2||rightElbowX-rightElbowXt==-2);
  rightElbowX=rightElbowXt;
if(rightElbowY-rightElbowYt==2||rightElbowY-rightElbowYt==-2);
  rightElbowY=rightElbowYt;
Serial.print("<");
Serial.print(rightShoulderX);
Serial.print(",");
Serial.print(rightShoulderY);
Serial.print(",");
Serial.print(rightElbowX);
Serial.print(",");
Serial.print(rightElbowY);
Serial.println(">");
delay(20);
nvm i figured it out
You cant. Slight electrical noise on the signal will result in a different value read from the ADC. A change of just 1 is very reasonable.
Take a bunch of samples (32 or 64 is normally enough - this are nice round numbers for easy division by bit shift) and take the average.
So common, the newer AVR processors even have that option built into their hardware!
Without a schematic etc knowing how the pot is connected and the lead dress I would say you are doing great. The reference for the A/D is the output of the 5V regulator. Any load on that can can change the A/D reference voltage. Nick Gammon posted a great tutorial on the A/D it is at: Gammon Forum : Electronics : Microprocessors : ADC conversion on the Arduino (analogRead)
daudhtm:
180
181
181
181
180
181
180
180
181
Inevitable nature of analog to digital conversion, you accept its going to always happen
and code defensively. [ google "hysteresis" perhaps? ]
Yes ... if your input value was equivalent to say 180.5, then maybe sometimes you’ll see 180 , sometimes 181 .
Also in mapping the values you have further reduced the resolution, your values only now go from 0-270 and not 0-1023, and the values don’t map across as whole numbers so you’ll get some rounding .
Not even going to 270 as the high limit of the map input is 1028 not 1023 which is the highest an analog reading can ever be...
