Is there any possibility to change configuration in the software serial library to 7 data bits, 2 stop bits and even parity? I have 2 sensors that have these communication parameters, I'm afraid that I have to do some changes in the library. Could anyone help me?
Have you looked at the SoftwareSerial code? A collection of bits is received by the recv() function, which contains this:
// Read each of the 8 bits
for (uint8_t i=0x1; i; i <<= 1)
tunedDelay(_rx_delay_intrabit);
DebugPulse(_DEBUG_PIN2, 1);
uint8_t noti = ~i;
if (rx_pin_read())
d |= i;
else // else clause added to ensure function timing is ~balanced
d &= noti;
// skip the stop bit
tunedDelay(_rx_delay_stopbit);
Doesn't look like it would be all that difficult to read 7 bits and skip two stop bits.
You can probably do that with hardware serial if you just tweak a couple of registers as per the datasheet. Why do you have to use software serial?
I have arduino uno with one hardware serial which communicate with the program on my computer via USB. I have 2 sensors with rs232 interface(7-E-2 configuration) and I have to get data from them. That's why I need two software serials.
// Read each of the 7 bits
for (uint8_t i=0x1; i<0x80; i <<= 1)
uint8_t noti = ~i;
if (rx_pin_read())
d |= i;
d &= noti;
// two stop bits
You are just reading? You don't need to skip the second stop bit for the simple reason that a stop bit is a "1", and it doesn't matter how many 1s there are before the next start bit. There could be 20 and it wouldn't matter.
And as for the even parity, if you have 7 data bits, the parity will effectively be the 8th bit. Simply ignore it. eg.
