Guten Morgen,
Im Anhang 3 sketches mein Anschlussschema des ESP8266-01, für softserial dann natürlich an den jeweils definierten pins.
sketch "hardserial_xy" funtioniert
-- hardserial --
This source code of graphical user interface
has been generated automatically by RemoteXY editor.
To compile this code using RemoteXY library 2.4.3 or later version
download by link http://remotexy.com/en/library/
To connect using RemoteXY mobile app by link http://remotexy.com/en/download/
- for ANDROID 4.3.1 or later version;
- for iOS 1.3.5 or later version;
This source code is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
// RemoteXY include library //
// RemoteXY select connection mode and include library
#define REMOTEXY_MODE__ESP8266_HARDSERIAL
#include <RemoteXY.h>
// RemoteXY connection settings
#define REMOTEXY_SERIAL Serial
#define REMOTEXY_SERIAL_SPEED 9600
#define REMOTEXY_WIFI_SSID "YOUR_SSID"
#define REMOTEXY_WIFI_PASSWORD "YOUR_PASS"
#define REMOTEXY_SERVER_PORT 6377
// RemoteXY configurate
#pragma pack(push, 1)
uint8_t RemoteXY_CONF[] =
{ 255,1,0,0,0,13,0,8,13,0,
1,0,46,24,12,12,2,31,88,0 };
// this structure defines all the variables of your control interface
struct {
// input variable
uint8_t button_1; // =1 if button pressed, else =0
// other variable
uint8_t connect_flag; // =1 if wire connected, else =0
} RemoteXY;
#pragma pack(pop)
// END RemoteXY include //
#define PIN_BUTTON_1 13
RemoteXY_Init ();
pinMode (PIN_BUTTON_1, OUTPUT);
// TODO you setup code
RemoteXY_Handler ();
digitalWrite(PIN_BUTTON_1, (RemoteXY.button_1==0)?LOW:HIGH);
// TODO you loop code
// use the RemoteXY structure for data transfer
sketch "softserial_ok" funtioniert
#include "SoftwareSerial.h"
SoftwareSerial esp8266(A5, A4); // RX, TX
Serial.begin(9600); // serial port used for debugging
esp8266.begin(9600); // your ESP's baud rate might be different
if(esp8266.available()) // check if the ESP is sending a message
while(esp8266.available())
char c = esp8266.read(); // read the next character.
Serial.print(c); // writes data to the serial monitor
if(Serial.available())
delay(10); // wait to let all the input command in the serial buffer
// read the input command in a string
String cmd = "";
while(Serial.available())
cmd += (char)Serial.read();
// send to the esp8266
esp8266.println(cmd);
sketch "softserial_xy" kommt keine Antwort vom ESP am Monitor
-- softserial --
#define REMOTEXY_MODE__ESP8266_SOFTSERIAL
#include <SoftwareSerial.h>
#define REMOTEXY_SERIAL_RX 2
#define REMOTEXY_SERIAL_TX 3
struct {
// input variable
// other variable
} RemoteXY;
#pragma pack(pop)
RemoteXY_Init ();
Hab leider nicht herausgefunden wie ich die Anhänge hier direkt posten kann, sorry!
Hoffnungsvoller Gruß,
Peter
hardserial_xy.ino (2.15 KB)
Softserial_ok.ino (2.09 KB)
