I am using the software servo library for the first time in order to free up the usual timer for the virtual wire library
however, my servos seem to be going to the wrong position alternating between two points very close to one another
is there a problem with the code i am using ?
i would appreciate any help
#include <SoftwareServo.h>
SoftwareServo myservo;Â // create servo object to control a servo
 myservo.attach(3); // attaches the servo on pin 2 to the servo object
 myservo.write(0);Â
SoftwareServo::refresh();Â // sets the servo position according to the scaled value
 delay(1000);             // waits for the servo to get there
myservo.write(180);Â Â Â
SoftwareServo::refresh();// sets the servo position according to the scaled value
Using the regular servo library produces this error in my code
Servo/Servo.cpp.o: In function __vector_11': /Applications/Arduino.app/Contents/Resources/Java/libraries/Servo/Servo.cpp:103: multiple definition of __vector_11'
VirtualWire/VirtualWire.cpp.o:/Applications/Arduino.app/Contents/Resources/Java/libraries/VirtualWire/VirtualWire.cpp:418: first defined here
from what i have read this means that the virtual wire library is already using the timer which the regular servo library relies upon.
The software servo library does not use this timer, or so i have read, and should work if i can get the code right
SoftwareServo can't keep sending signals to the servo during a delay() call. You WILL have to get rid of the delay.
