Software Upload Error
I am builfing a spacemouse for CAD modelling with these instructions: Printables
Everything exept the software is done and this is my first time working with an arduino. Every upload I try it gives me other errors. The code can be found on the internet site. I am really struggeling with this software thing. Its a arduino micro, I downloaded the newest IDE and tried to upload the code...
Error message:
`Connecting to programmer: .
Found programmer: Id = "CATERIN"; type = S
Software Version = 1.0; No Hardware Version given.
Programmer supports auto addr increment.
Programmer supports buffered memory access with buffersize=128 bytes.
Programmer supports the following devices:
Device code: 0x44`
Full Code:
// This code is the combination of multiple works by others:
// 1. Original code for the Space Mushroom by Shiura on Thingiverse: https://www.thingiverse.com/thing:5739462
//    The next two from the comments on the instructables page: https://www.instructables.com/Space-Mushroom-Full-6-DOFs-Controller-for-CAD-Appl/
//    and the comments of Thingiverse: https://www.thingiverse.com/thing:5739462/comments
// 2. Code to emulate a 3DConnexion Space Mouse by jfedor: https://pastebin.com/gQxUrScV
// 3. This code was then remixed by BennyBWalker to include the above two sketches: https://pastebin.com/erhTgRBH
// 4. Four joystick remix code by fdmakara: https://www.thingiverse.com/thing:5817728
// My work invloves mixing all of these. The basis is fdmakara's four joystick movement logic, with jfedor/BennyBWalker's HID SpaceMouse emulation.
// The four joystick logic sketch was setup for the joystick library instead of HID, so elements of this were omitted where not needed.
// The outputs were jumbled no matter how I plugged them in, so I spent a lot of time adding debugging code to track exactly what was happening.
// On top of this, I have added more control of speed/direction and comments/links to informative resources to try and explain what is happening in each phase.
// Spacemouse emulation
// I followed the instructions here from nebhead: https://gist.github.com/nebhead/c92da8f1a8b476f7c36c032a0ac2592a
// with two key differences:
// 1. I changed the word 'DaemonBite' to 'Spacemouse' in all references.
// 2. I changed the VID and PID values as per jfedor's instructions: vid=0x256f, pid=0xc631 (SpaceMouse Pro Wireless (cabled))
// When compiling and uploading, I select Arduino AVR boards (in Sketchbook) > Spacemouse and then the serial port.
// You will also need to download and install the 3DConnexion software: https://3dconnexion.com/us/drivers-application/3dxware-10/
// If all goes well, the 3DConnexion software will show a SpaceMouse Pro wireless when the Arduino is connected.
// Include inbuilt Arduino HID library by NicoHood: https://github.com/NicoHood/HID
#include "HID.h"
// Debugging
// 0: Debugging off. Set to this once everything is working.
// 1: Output raw joystick values. 0-1023 raw ADC 10-bit values
// 2: Output centered joystick values. Values should be approx -500 to +500, jitter around 0 at idle.
// 3: Output centered joystick values. Filtered for deadzone. Approx -500 to +500, locked to zero at idle.
// 4: Output translation and rotation values. Approx -800 to 800 depending on the parameter.
// 5: Output debug 4 and 5 side by side for direct cause and effect reference.
int debug = 0;
// Direction
// Modify the direction of translation/rotation depending on preference. This can also be done per application in the 3DConnexion software.
// Switch between true/false as desired.
bool invX = false; // pan left/right
bool invY = false; // pan up/down
bool invZ = true; // zoom in/out
bool invRX = true; // Rotate around X axis (tilt front/back)
bool invRY = false; // Rotate around Y axis (tilt left/right)
bool invRZ = true; // Rotate around Z axis (twist left/right)
// Speed - Had to be removed when the V2 shorter range of motion. The logic reduced sensitivity on small movements. Use 3DConnexion slider instead for V2.
// Modify to change sensitibity/speed. Default and maximum 100. Works like a percentage ie. 50 is half as fast as default. This can also be done per application in the 3DConnexion software.
//int16_t speed = 100;
// Default Assembly when looking from above:
//    C           Y+
// B--+--D   X-...Z+...X+
//    A           Y-
// Wiring. Matches the first eight analogue pins of the Arduino Pro Micro (atmega32u4)
int PINLIST[8] = { // The positions of the reads
  A1, // X-axis A
  A0, // Y-axis A
  A3, // X-axis B
  A2, // Y-axis B
  A7, // X-axis C
  A6, // Y-axis C
  A9, // X-axis D
  A8  // Y-axis D
// Deadzone to filter out unintended movements. Increase if the mouse has small movements when it should be idle or the mouse is too senstive to subtle movements.
int DEADZONE = 3; // Recommended to have this as small as possible for V2 to allow smaller knob range of motion.
// This portion sets up the communication with the 3DConnexion software. The communication protocol is created here.
// hidReportDescriptor webpage can be found here: https://eleccelerator.com/tutorial-about-usb-hid-report-descriptors/
static const uint8_t _hidReportDescriptor[] PROGMEM = {
  0x05, 0x01,           //  Usage Page (Generic Desktop)
  0x09, 0x08,           //  0x08: Usage (Multi-Axis)
  0xa1, 0x01,           //  Collection (Application)
  0xa1, 0x00,           // Collection (Physical)
  0x85, 0x01,           //  Report ID
  0x16, 0x00, 0x80,     //logical minimum (-500)
  0x26, 0xff, 0x7f,     //logical maximum (500)
  0x36, 0x00, 0x80,     //Physical Minimum (-32768)
  0x46, 0xff, 0x7f,     //Physical Maximum (32767)
  0x09, 0x30,           //    Usage (X)
  0x09, 0x31,           //    Usage (Y)
  0x09, 0x32,           //    Usage (Z)
  0x75, 0x10,           //    Report Size (16)
  0x95, 0x03,           //    Report Count (3)
  0x81, 0x02,           //    Input (variable,absolute)
  0xC0,                 //  End Collection
  0x85, 0x02,           //  Report ID
  0x09, 0x33,           //    Usage (RX)
  0x09, 0x34,           //    Usage (RY)
  0x09, 0x35,           //    Usage (RZ)
  0x85, 0x03,           //  Report ID
  0x15, 0x00,           //   Logical Minimum (0)
  0x25, 0x01,           //    Logical Maximum (1)
  0x75, 0x01,           //    Report Size (1)
  0x95, 32,             //    Report Count (24)
  0x05, 0x09,           //    Usage Page (Button)
  0x19, 1,              //    Usage Minimum (Button #1)
  0x29, 32,             //    Usage Maximum (Button #24)
  0xC0,
  0xC0
// Axes are matched to pin order.
#define AX 0
#define AY 1
#define BX 2
#define BY 3
#define CX 4
#define CY 5
#define DX 6
#define DY 7
// Centerpoint variable to be populated during setup routine.
int centerPoints[8];
// Function to read and store analogue voltages for each joystick axis.
void readAllFromJoystick(int *rawReads){
  for(int i=0; i<8; i++){
    rawReads[i] = analogRead(PINLIST[i]);
  // HID protocol is set.
  static HIDSubDescriptor node(_hidReportDescriptor, sizeof(_hidReportDescriptor));
  HID().AppendDescriptor(&node);
  // Begin Seral for debugging
  Serial.begin(250000);
  delay(100);
  // Read idle/centre positions for joysticks.
  readAllFromJoystick(centerPoints);
// Function to send translation and rotation data to the 3DConnexion software using the HID protocol outlined earlier. Two sets of data are sent: translation and then rotation.
// For each, a 16bit integer is split into two using bit shifting. The first is mangitude and the second is direction.
void send_command(int16_t rx, int16_t ry, int16_t rz, int16_t x, int16_t y, int16_t z) {
  uint8_t trans[6] = { x & 0xFF, x >> 8, y & 0xFF, y >> 8, z & 0xFF, z >> 8 };
  HID().SendReport(1, trans, 6);
  uint8_t rot[6] = { rx & 0xFF, rx >> 8, ry & 0xFF, ry >> 8, rz & 0xFF, rz >> 8 };
  HID().SendReport(2, rot, 6);
  int rawReads[8], centered[8];
  // Joystick values are read. 0-1023
  readAllFromJoystick(rawReads);
  // Report back 0-1023 raw ADC 10-bit values if enabled
  if(debug == 1){
    Serial.print("AX:");
    Serial.print(rawReads[0]);
    Serial.print(",");
    Serial.print("AY:");
    Serial.print(rawReads[1]);
    Serial.print(",");
    Serial.print("BX:");
    Serial.print(rawReads[2]);
    Serial.print(",");
    Serial.print("BY:");
    Serial.print(rawReads[3]);
    Serial.print(",");
    Serial.print("CX:");
    Serial.print(rawReads[4]);
    Serial.print(",");
    Serial.print("CY:");
    Serial.print(rawReads[5]);
    Serial.print(",");
    Serial.print("DX:");
    Serial.print(rawReads[6]);
    Serial.print(",");
    Serial.print("DY:");
    Serial.println(rawReads[7]);
  // Subtract centre position from measured position to determine movement.
  for(int i=0; i<8; i++) centered[i] = rawReads[i] - centerPoints[i]; //
  // Report centered joystick values if enabled. Values should be approx -500 to +500, jitter around 0 at idle.
  if(debug == 2){
    Serial.print(centered[0]);
    Serial.print(",");
    Serial.print(centered[1]);
    Serial.print(",");
    Serial.print(centered[2]);
    Serial.print(",");
    Serial.print(centered[3]);
    Serial.print(",");
    Serial.print(centered[4]);
    Serial.print(",");
    Serial.print(centered[5]);
    Serial.print(",");
    Serial.print(centered[6]);
    Serial.print(",");
    Serial.println(centered[7]);
  // Filter movement values. Set to zero if movement is below deadzone threshold.
    if(centered[i]<DEADZONE && centered[i]>-DEADZONE) centered[i] = 0;
  // Report centered joystick values. Filtered for deadzone. Approx -500 to +500, locked to zero at idle
  if(debug == 3){
    Serial.print(",");
    Serial.print(",");
    Serial.print(",");
    Serial.print(",");
    Serial.print(",");
    Serial.print(",");
    Serial.print(",");
  // Doing all through arithmetic contribution by fdmakara
  // Integer has been changed to 16 bit int16_t to match what the HID protocol expects.
  int16_t transX, transY, transZ, rotX, rotY, rotZ; // Declare movement variables at 16 bit integers
  // Original fdmakara calculations
  //transX = (-centered[AX] +centered[CX])/1;
  //transY = (-centered[BX] +centered[DX])/1;
  //transZ = (-centered[AY] -centered[BY] -centered[CY] -centered[DY])/2;
  //rotX = (-centered[AY] +centered[CY])/2;
  //rotY = (+centered[BY] -centered[DY])/2;
  //rotZ = (+centered[AX] +centered[BX] +centered[CX] +centered[DX])/4;
  // My altered calculations based on debug output. Final divisor can be changed to alter sensitivity for each axis.
  transX = -(-centered[CY] +centered[AY])/1;
  transY = (-centered[BY]+centered[DY])/1;
  if((abs(centered[AX])>DEADZONE)&&(abs(centered[BX])>DEADZONE)&&(abs(centered[CX])>DEADZONE)&&(abs(centered[DX])>DEADZONE)){
    transZ = (-centered[AX] -centered[BX] -centered[CX] -centered[DX])/1;
    transX = 0;
    transY = 0;
    transZ = 0;
  rotX = (-centered[AX] +centered[CX])/1;
  rotY = (+centered[BX] -centered[DX])/1;
  if((abs(centered[AY])>DEADZONE)&&(abs(centered[BY])>DEADZONE)&&(abs(centered[CY])>DEADZONE)&&(abs(centered[DY])>DEADZONE)){
    rotZ = (+centered[AY] +centered[BY] +centered[CY] +centered[DY])/2;
    rotX = 0;
    rotY = 0;
    rotZ = 0;
// Alter speed to suit user preference - Use 3DConnexion slider instead for V2.
  //transX = transX/100*speed;
  //transY = transY/100*speed;
  //transZ = transZ/100*speed;
  //rotX = rotX/100*speed;
  //rotY = rotY/100*speed;
  //rotZ = rotZ/100*speed;
// Invert directions if needed
  if(invX == true){ transX = transX*-1;};
  if(invY == true){ transY = transY*-1;};
  if(invZ == true){ transZ = transZ*-1;};
  if(invRX == true){ rotX = rotX*-1;};
  if(invRY == true){ rotY = rotY*-1;};
  if(invRZ == true){ rotZ = rotZ*-1;};
// Report translation and rotation values if enabled. Approx -800 to 800 depending on the parameter.
  if(debug == 4){
    Serial.print("TX:");
    Serial.print(transX);
    Serial.print(",");
    Serial.print("TY:");
    Serial.print(transY);
    Serial.print(",");
    Serial.print("TZ:");
    Serial.print(transZ);
    Serial.print(",");
    Serial.print("RX:");
    Serial.print(rotX);
    Serial.print(",");
    Serial.print("RY:");
    Serial.print(rotY);
    Serial.print(",");
    Serial.print("RZ:");
    Serial.println(rotZ);
// Report debug 4 and 5 info side by side for direct reference if enabled. Very useful if you need to alter which inputs are used in the arithmatic above.
  if(debug == 5){
    Serial.print(",");
    Serial.print(",");
    Serial.print(",");
    Serial.print(",");
    Serial.print(",");
    Serial.print(",");
    Serial.print(",");
    Serial.print(centered[7]);
    Serial.print("||");
    Serial.print(",");
    Serial.print(",");
    Serial.print(",");
    Serial.print(rotX);
    Serial.print(",");
    Serial.print(rotY);
    Serial.print(",");
// Send data to the 3DConnexion software.
// The correct order for me was determined after trial and error
  send_command(rotX, rotZ, rotY, transX, transZ, transY);
Welcome to the forum
Please post the full error message copied from the IDE using the button provided for the purpose and post the sketch here, using code tags when you do
In my experience the easiest way to tidy up the code and add the code tags is as follows
Start by tidying up your code by using Tools/Auto Format in the IDE to make it easier to read. Then use Edit/Copy for Forum and paste what was copied in a new reply. Code tags will have been added to the code to make it easy to read in the forum thus making it easier to provide help.
The fact that it is displayed in red does in this case not necessarily indicate that it's an error.
In IDE 1.x, the bar above the output window will be orange and contain a button "Copy error messages"; in IDE 2.x there will be a popup in the right bottom indicating success or error.
Okay, I tried to upload it once more and thats the error message:
avrdude: ser_open(): can't open device "\.\COM6": access denied
Upload failed: Upload error: exit status 1
I also had this problem. The problem is, that the arduino pro micro has a very short time to get into the bootloader of 800 ms.
Therefore you need to connect the reset pin twice to gnd. Than you have 8s to initially set the com port and upload your sketch.
It is also quite a fast timing and needs some number of tries.
Make sure to select the proper 5V 16MHz (if you also have this board).
You can read the details for this reset here:
https://learn.sparkfun.com/tutorials/pro-micro--fio-v3-hookup-guide/troubleshooting-and-faq#ts-reset
I try to create an advanced software for the spacemouse based on teachingtechs input. You may want to check it:
I think im just stupid but I tried that and nothing really happened. Still one red Led is on.
Is that right?
It gave me the following message:
Property 'upload.tool.serial' is undefined
COM1 is hardly ever the Arduino; does it disappear when you disconnect the board?
What happens when you double-tap the reset button on the Micro? The L-LED should fade in and out for 8 seconds.
Search results for this error message: Search results for 'Property 'upload.tool.serial' is undefined #software:ide-2-x' - Arduino Forum. Pay attention to posts by @ptillisch.
This one is probably most applicable: Custom Bord not showing up in IDE - #3 by akut but needs some adjustment for your board package.
If you tell us the additional board url (in file/preferences) for the Spacemouse, we can look at the installation.
You are not the first to encounter this problem:
Some people (Instructions for Adding Custom Naming for Arduino USB Device · GitHub) need to change the board.txt:
spacemouse.upload.tool=avrdude to spacemouse.upload.tool.serial=avrdude to get no error when compiling
Does this help?
I just tried that, the arduino was recognized (COM7) and I tried to upload it and it gave me the "upload.tool.serial is undefined" again. I wanted to tried it again a few minutes later and since then the arduino is not recognized by the IDE at all. It is showing COM 1 again. I am about to quit that shit haha. im just to stupid for that:)
If someone wants to try it or guide me on my pc, I would really appretiate it haha (TeamViewer or Anydesk) My discord is: chione0910
Now you are mixing two problems: first of all, you need to solve the unresolved tool.serial issue. Are you sure, you updated the right board.txt in the correct folder and restarted the programms?
As this part is indeed annoying, we also have a plattformio program for the space mouse GitHub - AndunHH/spacemouse: Repository for the space mouse based on four joysticks and keys. But you should be able the change the board.txt, as other people already did it. :slight_smile: see the GitHub link above.
When this is fixed, you need to flash the board. This is only once tricky, to get over the bootloader:
If you have the problem, that the port can not be found, the bootloader of your board is probably not reachable. The problem is, that the arduino pro micro has a very short time to get into the bootloader of 800 ms. Therefore you need to connect the reset pin twice to gnd. Than you have 8 s to initially set the com port and upload your sketch. It is also quite a fast timing and needs some number of tries.
You can read the details for this reset here: Pro Micro & Fio V3 Hookup Guide - SparkFun Learn
