I'm having a problem with Softwareserial function, I am using code that come with Arduino's IDE 1.6.9
on Arduino UNO with wire jumper connect pin 0 (UNO's Rx) to pin 11, pin 1 (UNO's Tx) to piin 10. the code are of following
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
Serial.begin(57600);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.println("Goodnight moon!");
// set the data rate for the SoftwareSerial port
mySerial.begin(9600);
mySerial.println("Hello, world?");
void loop() { // run over and over
if (mySerial.available()) {
Serial.write(mySerial.read());
if (Serial.available()) {
mySerial.write(Serial.read());
when connected I expect the serial monitor to show Goodnight moon! on 57600 baud rate window and
Hello, world? on 9600 baud rate window after reset
what I had on 57600 is
Goodnight moon!
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
and on 9600
I tried swaping pins, changing pin but none seem to work except I use only softwareserial or hardware serial
Yes. Use SoftwareSerial the way it is intended to be used. That is, it is to be used to read data from an EXTERNAL device that sends serial data. It is NOT intended to be used to read from the hardware serial port.
It may be possible to use SoftwareSerial to read or write data to the HardwareSerial port (though I can't imagine why you would want to). But it would be ESSENTIAL that they both use the same baud rate.
And start with 9600 baud because SoftwareSerial is a poor perfromer.
It is perfectly ok to try a simple echo program, where you wire the HardwareSerial port to a software serial port. However:
They both have to be at the same baud rate. Sending at 57600 cannot be read by a receiver at 9600.
The absolute best alternative to HardwareSerial is AltSoftSerial, but it only works on certain pins (8 & 9 on an UNO).
SoftwareSerial disables interrupts for very long periods of time. This can cause the HardwareSerial port to lose data, but not in your particular example.
NeoSWSerial is much more efficient than SoftwareSerial. Unless you need a baud rate other than 9600, 19200 or 38400, there is no reason to shoot yourself in the foot with SoftwareSerial.
Cheers,
/dev
like other has said, for an example declaration below
you need to have an external device that has output TX, RX respectively connected to (10, 11) or RX, TX for this
sample program to output "Hello, world?" just try you will see. do not worry about the actual signals from external device TX, RX. the example will always give hard coded value "Hello, world?"
mySerial.begin(19200); // the GPRS baud rate
sendData("AT+CMGF=1",2000,DEBUG);//Because we want to send the SMS in text mode
delay(100);
sendData("AT+CMGS="+2348134627229"",2000,DEBUG);//send sms message, be careful need to add a country code before the cellphone number
delay(100);
sendData("Hello,Elecrow!",2000,DEBUG);//the content of the message
delay(100);
mySerial.println((char)26);//the ASCII code of the ctrl+z is 26
delay(100);
void sendData(String command, const int timeout, boolean debug)
String response = "";
mySerial.println(command);
long int time = millis();
while( (time+timeout) > millis())
while(mySerial.available())
char c = mySerial.read();
response+=c;
if(debug)
Serial.print(response);
return response;
You need to have two arduino boards
a. Board 1 - just load the code
b. Board 2 - delete the write command for both serial and myserial before loading
c. Connect Board 1 and board 2: pins 0 to 1 and 1 to 0 as well as pins 10 to 11 and 11 to 10. Don't forget to connect the GRND of both boards... this will make sure the wave form of tx/rx is pulled down to 0V when sending 0 bit.
c. Board 2 stays connected to computer with serial monitor turned on.
d. Board 1 to be powered on by external power/adaptor
e. Once board 1 is powered up, it will run the write commands to both serial and my serial.
f. Board 2 will then receive both messages and write them down in the serial monitor.
If in case the message is jumbled up:
a. Change the code in Board 1:
Insert delay(1000) between serial and myserial write commands.
You can also enhance the code in Board 2:
a. Change if clause to while clause
b. add delay(5) after the write commands. Board 1 might have some delay transmitting the message which might cut the while loop in board 2 prematurely.
If you want to use SINGLE ARDUINO BOARD ONLY:
a. in the code change serial baud rate to 9600
b. apply all the code changes stated above that are applied to board 1.
c. connect pins 0 to 11 and 1 to 10
c. run the code
