I am working on a project that uses SoftwareSerial but does not seem to be avalible any more
Arduino: 1.9.0-beta (Windows 10), Board: "Adafruit Feather M0"
C:\Users\walte_000\Favorites\Downloads\New folder\arduino-PR-beta1.9-BUILD-79\arduino-builder -dump-prefs -logger=machine -hardware C:\Users\walte_000\Favorites\Downloads\New folder\arduino-PR-beta1.9-BUILD-79\hardware -hardware C:\Users\walte_000\AppData\Local\Arduino15\packages -tools C:\Users\walte_000\Favorites\Downloads\New folder\arduino-PR-beta1.9-BUILD-79\tools-builder -tools C:\Users\walte_000\Favorites\Downloads\New folder\arduino-PR-beta1.9-BUILD-79\hardware\tools\avr -tools C:\Users\walte_000\AppData\Local\Arduino15\packages -built-in-libraries C:\Users\walte_000\Favorites\Downloads\New folder\arduino-PR-beta1.9-BUILD-79\libraries -libraries C:\Users\walte_000\Documents\Arduino\libraries -fqbn=adafruit:samd:adafruit_feather_m0 -vid-pid=0X239A_0X800C -ide-version=10900 -build-path C:\Users\WALTE_~1\AppData\Local\Temp\arduino_build_883073 -warnings=none -build-cache C:\Users\WALTE_~1\AppData\Local\Temp\arduino_cache_660752 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.bossac.path=C:\Users\walte_000\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.8.0-48-gb176eee -prefs=runtime.tools.bossac-1.8.0-48-gb176eee.path=C:\Users\walte_000\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.8.0-48-gb176eee -prefs=runtime.tools.openocd.path=C:\Users\walte_000\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.9.0-arduino -prefs=runtime.tools.openocd-0.9.0-arduino.path=C:\Users\walte_000\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.9.0-arduino -prefs=runtime.tools.CMSIS.path=C:\Users\walte_000\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.CMSIS-4.5.0.path=C:\Users\walte_000\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\walte_000\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.arm-none-eabi-gcc-4.8.3-2014q1.path=C:\Users\walte_000\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\walte_000\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.CMSIS-Atmel-1.2.0.path=C:\Users\walte_000\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -verbose -experimental C:\Users\walte_000\Documents\Arduino\Torque_code_working_BT\torque_code_bt_adalogger\torque_code_bt_adalogger.ino
C:\Users\walte_000\Favorites\Downloads\New folder\arduino-PR-beta1.9-BUILD-79\arduino-builder -compile -logger=machine -hardware C:\Users\walte_000\Favorites\Downloads\New folder\arduino-PR-beta1.9-BUILD-79\hardware -hardware C:\Users\walte_000\AppData\Local\Arduino15\packages -tools C:\Users\walte_000\Favorites\Downloads\New folder\arduino-PR-beta1.9-BUILD-79\tools-builder -tools C:\Users\walte_000\Favorites\Downloads\New folder\arduino-PR-beta1.9-BUILD-79\hardware\tools\avr -tools C:\Users\walte_000\AppData\Local\Arduino15\packages -built-in-libraries C:\Users\walte_000\Favorites\Downloads\New folder\arduino-PR-beta1.9-BUILD-79\libraries -libraries C:\Users\walte_000\Documents\Arduino\libraries -fqbn=adafruit:samd:adafruit_feather_m0 -vid-pid=0X239A_0X800C -ide-version=10900 -build-path C:\Users\WALTE_~1\AppData\Local\Temp\arduino_build_883073 -warnings=none -build-cache C:\Users\WALTE_~1\AppData\Local\Temp\arduino_cache_660752 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.bossac.path=C:\Users\walte_000\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.8.0-48-gb176eee -prefs=runtime.tools.bossac-1.8.0-48-gb176eee.path=C:\Users\walte_000\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.8.0-48-gb176eee -prefs=runtime.tools.openocd.path=C:\Users\walte_000\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.9.0-arduino -prefs=runtime.tools.openocd-0.9.0-arduino.path=C:\Users\walte_000\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.9.0-arduino -prefs=runtime.tools.CMSIS.path=C:\Users\walte_000\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.CMSIS-4.5.0.path=C:\Users\walte_000\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\walte_000\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.arm-none-eabi-gcc-4.8.3-2014q1.path=C:\Users\walte_000\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\walte_000\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.CMSIS-Atmel-1.2.0.path=C:\Users\walte_000\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -verbose -experimental C:\Users\walte_000\Documents\Arduino\Torque_code_working_BT\torque_code_bt_adalogger\torque_code_bt_adalogger.ino
Using board 'adafruit_feather_m0' from platform in folder: C:\Users\walte_000\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.2.2
Using core 'arduino' from platform in folder: C:\Users\walte_000\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.2.2
Detecting libraries used...
"C:\Users\walte_000\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10900 -DARDUINO_SAMD_FEATHER_M0 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -DARM_MATH_CM0PLUS -DADAFRUIT_FEATHER_M0 -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x800B -DUSBCON "-DUSB_MANUFACTURER="Adafruit"" "-DUSB_PRODUCT="Feather M0"" "-IC:\Users\walte_000\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\walte_000\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/" "-IC:\Users\walte_000\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.2.2\cores\arduino" "-IC:\Users\walte_000\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.2.2\variants\feather_m0" "C:\Users\WALTE_~1\AppData\Local\Temp\arduino_build_883073\sketch\torque_code_bt_adalogger.ino.cpp" -o nul
torque_code_bt_adalogger:1:28: error: SoftwareSerial.h: No such file or directory
#include <SoftwareSerial.h>
compilation terminated.
exit status 1
There is no bundled SoftwareSerial library for the Adafruit Feather M0. The reason is that board has plenty of hardware serial ports so there is almost certainly no need to use the less efficient software serial.
I used SoftwareSerial a day ago and it worked fine now it does not what's the deal
Modified from the examples of the Arduino LoRa library
More resources: https://randomnerdtutorials.com
#include <SPI.h>
#include <LoRa.h>
//#include <SoftwareSerial.h.>
//define the pins used by the transceiver module
#define ss 8
#define rst 4
#define dio0 3
int counter = 0;
//initialize Serial Monitor
while (!Serial);
Serial.println("LoRa Sender");
//setup LoRa transceiver module
LoRa.setPins(ss, rst, dio0);
//replace the LoRa.begin(---E-) argument with your location's frequency
//433E6 for Asia
//866E6 for Europe
//915E6 for North America
while (!LoRa.begin(915E6)) {
Serial.println(".");
// Change sync word (0xF3) to match the receiver
// The sync word assures you don't get LoRa messages from other LoRa transceivers
// ranges from 0-0xFF
LoRa.setSyncWord(0xF3);
Serial.println("LoRa Initializing OK!");
Serial.print("Sending packet: ");
Serial.println(counter);
//Send LoRa packet to receiver
LoRa.beginPacket();
LoRa.print("hello ");
LoRa.print(counter);
LoRa.endPacket();
counter++;
Did you have Tools > Board > Adafruit Feather M0 selected when it was working?
