I'm interested in building a solar powered outdoor light with an arduino as the main controller. I want to be able to output a lot more light than the normal ones you can buy but just for a few hours after the sun goes down to save the battery.
This is a schematic for what I'm thinking of doing. Is the idea reasonable?
The 5v boost is this device: http://www.aliexpress.com/item/1Pcs-Mini-DC-DC-USB-0-9V-5V-to-5V-Boost-Step-up-Power-Supply-Module/32383087922.html?spm=2114.13010608.0.56.NWoeGa
The solar cell I have in mind is Small Solar Panel 80x100mm 1W - Seeed Studio
For batteries, I plan to use 2 NiMH AA batteries.
The cell is rated at 5.5v 170mA. But when it's held across the batteries, will that pull down the voltage to a level so I don't hurt the 2.4v battery? I'm worried that 170mA is too high for this, but I believe that's a very optimistic rating from the manufacturer and I'll be lucky to see half that in bright light. They do also sell a solar cell that's half the size and current output.
The temperature has been pushing close to 40 celsius here lately, is that a problem for the batteries?
I plan to read the solar panel voltage directly on the Arduino A0 to know when it's dark out. I know I will need to keep the arduino at low power when it's in standby.
Will the solar panel lose power if I enclose this in a glass jar or plastic box?
Thanks for any input you can give me.
