Soldering station LCD change help
Hi, i am building a new soldering station (from this link - DIY Soldering Station with Hakko FX-888 Iron – Part 2 – Arduino++) , the hardware is all put together and im just trying to get the code working.
The only thing is that the original article used a 16 X 2 LCD with SR piggyback, however im using a display with I2C.
However when i try to include the hd44780 library i get the following error message back...
In file included from C:\Users\joshh\Downloads\FX888-Controller\FX888-Controller.ino:10:0:
C:\Users\joshh\Documents\Arduino\libraries\FX888-Controller-master/Bargraph.h:3:10: fatal error: LiquidCrystal_SR.h: No such file or directory
#include <LiquidCrystal_SR.h>
compilation terminated.
exit status 1
Compilation error: exit status 1
What i dont understand is that there is no longer any mention of <LiquidCrystal_SR.h> anywhere in the code :confused:
sorry forgot to add the code....
#include <hd44780.h>
#include <Arduino.h>
#include <EEPROM.h>
#include <MD_KeySwitch.h>
#include <MD_REncoder.h>
#include <ResponsiveAnalogRead.h>
#include "Debug.h"
#include "Hardware.h"
#include "ConfigData.h"
#include "Bargraph.h"
#include "LCD_Display.h"
// version 1.0 August 2016
// First implementation from hardware and software design at
// https://create.arduino.cc/projecthub/sfrwmaker/soldering-iron-controller-for-hakko-907-8c5866
// External library dependencies
// LiquidCrystal_SR     https://bitbucket.org/fmalpartida/new-liquidcrystal/overview
// MD_REncoder          https://github.com/MajicDesigns/MD_REncoder
// MD_KeySwitch         https://github.com/MajicDesigns/MD_KeySwitch
// ResponsiveAnalogRead https://github.com/dxinteractive/ResponsiveAnalogRead
// Miscellaneous
void(*resetHW) (void) = 0; //declare reset function @ address 0
// Soldering IRON ----------------------------------------
// Main control class for the soldering iron.
// Within this class, all temperature measurements are in internal units.
// Control is carried out using the PID algorithm
// Un = Kp*(Xs - Xn) + Ki*sum{j=0; j<=n}(Xs - Xj) + Kd(Xn-1 - Xn)
// We use the iterative formulae:
// Un = Un-1 + Kp*(Xn-1 - Xn) + Ki*(Xs - Xn) + Kd*(2*Xn-1 - Xn - Xn-2)
// With the first step:
// U0 = Kp*(Xs - X0) + Ki*(Xs - X0); Xn-1 = Xn;
class IRON
private:
  const uint16_t PID_RUN_PERIOD = 600;      // time in milliseconds for running PID
  const uint16_t TEMP_READ_PERIOD = 200;    // update the curent value every PERIOD ms
  // heating safety check parameters
  const uint16_t  SAFETY_CHECK_TIME = 10000; // iron heating up safety check time, in ms
  const uint16_t  SAFETY_DELTA_T = 1;        // minimum temp difference at SAFETY_CHECK_TIME
  // PID tuning parameters
  const uint8_t DENOMINATOR_p = 10; // common coefficient denominator power of 2 (ie, 10 means 2^10 = 1024)
  const int32_t PID_Kp = 5120;  // Kp multiplied by denominator
  const int32_t PID_Ki = 512;   // Ki multiplied by denominator
  const int32_t PID_Kd = 768;   // Kd multiplied by denominator
  const int16_t PID_SWITCH_DELTA_T = 15;  // temp difference that triggers switch from initial to iterate PID function
  void applyPower(void);  // sety power after PID and apply power to the heater
  void resetPID(void);    // reset PID algorithm
  uint32_t _timeLastCVUpdate;       // time the temperature was last read
  int32_t  _timeLastSafetyCheck;    // time last safety check was held in ms
  int32_t  _timeLastPIDRun;         // time the last PID was run
  uint8_t _pinHeater, _pinSensor;   // the heater PWM and the sensor analog pin numbers
  bool _iteratePID;       // true when switch to PID iterative formula
  bool _isOn;             // true when the iron is on
  bool _isFixPowerMode;   // true when conttrol mode is for direct power
  bool _isUsed;           // iron has been on at some stage
  int16_t _powerSP;       // current soldering station power curent value
  ResponsiveAnalogRead *_sensor;
  uint8_t _error;         // current error code
                          // 0 - no error
                          // 1 - heating rate out of spec shutdown
                          // 2 - temperature range out of spec
  int16_t  _tempSP;       // temperature set point
  int16_t  _tempPrev;     // temperature when the iron was last safety checked
  uint16_t _tempMin;      // minimum temperature of control range
  uint16_t _tempMax;      // maximum temperature of control range
  int16_t  _tempHist[2];  // temperature history
public:
  IRON(uint8_t pinHeater, uint8_t pinSensor) :
    _pinHeater(pinHeater), _pinSensor(pinSensor),
    _isOn(false), _isFixPowerMode(false), _isUsed(false),
    _error(0)
    _sensor = new ResponsiveAnalogRead(pinSensor, true, 0.001);
  ~IRON()
    delete _sensor;
  void begin(uint16_t t_max, uint16_t t_min);
  // Status values requests
  inline bool isCold(void)    { return(getTempCV() < TEMP_COLD); }
  inline bool isOn(void)      { return(_isOn); }
  inline bool isWorking(void) { return(_error == 0); }
  inline bool isUsed(void)    { return(_isUsed); }
  inline void clearError(void)  { _error = 0; }
  inline uint8_t getError(void) { return(_error); }
  void switchPower(bool On);    // switch power on or off
  bool fixPower(uint8_t Power); // fixed power setting
  void setTempSP(uint16_t t);       // set the temperature control setpoint
  inline uint16_t getTempSP(void);  // set the current temperature setpoint
  uint16_t getTempCV(void);               // current value for the temperature
  inline uint16_t getTempCVDegrees(void); // get the current temperature in degrees
  void setTempSPDegrees(int t);                 // set the temperature in degrees (celsius or farenheit)
  inline uint16_t getTempSPDegrees(void);       // get the temperature settpoint in degrees
  inline uint16_t temp2degrees(uint16_t temp);  // convert internal temp to degrees
  inline uint8_t getPowerSP(void);    // power that is applied to the soldering iron [MIN_POWER - MAX_POWER]
  inline uint8_t getPowerSPPct(void); // power applied to the iron as a percentage of full range [0-100%]
  inline uint8_t getPowerAvg(void);   // average applied power
  inline uint8_t getHotPercent(void); // how hot the iron is, as a % of full temperature setpoint range
  void controlTemp(void); // run the PID control
void IRON::begin(uint16_t t_max, uint16_t t_min)
  // initialise the hardware
  pinMode(_pinHeater, OUTPUT);
  // initialise variables
  _powerSP = 0;
  _timeLastCVUpdate = 0;
  _timeLastSafetyCheck = 0;
  _timeLastPIDRun = 0;
  _tempPrev = getTempCV();
  _tempMax = t_max;
  _tempMin = t_min;
  // set up the IRON class
  for (uint8_t i = 0; i < 10; i++)    // set up some history
    _sensor->update();
  switchPower(false);
  resetPID();
void IRON::setTempSP(uint16_t t)
// Set the temperature setpoint in internal units
  if (_isOn) resetPID();
  _tempSP = t;
  PRINT("\nIRON: Set temp SP=", t);
void IRON::setTempSPDegrees(int16_t t)
// set the temperature setpoint in degrees
  uint16_t temp;
  PRINT("\nIRON: Set ", t);
  if (t < (int16_t)TEMP_MIN_DEG) t = TEMP_MIN_DEG;
  if (t > (int16_t)TEMP_MAX_DEG) t = TEMP_MAX_DEG;
  PRINT(" deg, now ", t);
  PRINT(" map to (", _tempMin);
  PRINT(",", _tempMax);
  PRINTS(")");
  temp = map(t+1, TEMP_MIN_DEG, TEMP_MAX_DEG, _tempMin, _tempMax);
  setTempSP(temp);
uint16_t IRON::getTempSP(void)
  return(_tempSP);
uint16_t IRON::getTempSPDegrees(void)
  uint16_t temp = getTempSP();
  temp = temp2degrees(temp);
  return(temp);
uint16_t IRON::temp2degrees(uint16_t t)
// Convert the internal temperature into degree units
  int16_t  temp;
  //PRINT("\nT2DEG: Temp ", t);
  //PRINT(" range (", _tempMin);
  //PRINT(",", _tempMax);
  //PRINTS(") map to (");
  //PRINT("", TEMP_MIN_DEG);
  //PRINT(",", TEMP_MAX_DEG);
  temp = map(t, _tempMin, _tempMax, TEMP_MIN_DEG, TEMP_MAX_DEG);
  //PRINT(") return ", temp);
  return(temp);
uint16_t IRON::getTempCV(void)
  uint16_t r;
  if (millis() - _timeLastCVUpdate >= TEMP_READ_PERIOD)
    _sensor->update();
    _timeLastCVUpdate = millis();
    // check value in range
    r = _sensor->getValue();
    PRINT("\nIRON: Temp new CV read ", r);
    if (r < TEMP_CTL_MIN || r > TEMP_CTL_MAX)
      PRINTS("\nIRON: CV range error");
      _error = 2;
      switchPower(false);
  return(r);
uint16_t IRON::getTempCVDegrees(void)
  uint16_t temp = getTempCV();
  return(temp);
uint8_t IRON::getPowerSPPct(void)
// return the currently applied power as a percentage
  return(map(getPowerSP(), MIN_POWER, MAX_POWER, 0, 100));
uint8_t IRON::getPowerSP(void)
// Return the power setypoint value [MIN_POWER, MAX_POWER]
  return(_powerSP);
uint8_t IRON::getHotPercent(void)
// return the temperature percentage of the current setpoint
  uint8_t r = map(getTempCV(), TEMP_COLD, _tempSP, 0, 100);
  if (r < 0) r = 0;
  return(r);
void IRON::resetPID(void)
// reset the PID control
  PRINTS("\nIRON: Reset PID");
  _iteratePID = false;
  _tempHist[0] = _tempHist[1] = 0;
void IRON::controlTemp(void)
// Main method used to control the iron temperature using PID algorithm
// Does the following:
// 1. Update dampened CV. This is called every interation do that
//    the update every TEMP_READ_PERIOD can occur.
// 2. Perform a safety check every SAFETY_CHECK_PERIOD.
// 3. Perform a PID calculation every PID_RUN_PERIOD.
  uint16_t tempCurr = getTempCV();    // need to call this often for timed updates
  if (!_isOn && !_isFixPowerMode)
    // ensure iron is powered off
    switchPower(false);
    return;
  // Safety check - is the iron heating?
  if (millis() - _timeLastSafetyCheck >= SAFETY_CHECK_TIME)
    // check if not changing much ..
    bool b = (!_isFixPowerMode && !_iteratePID && abs(_tempPrev - tempCurr) < SAFETY_DELTA_T);
    PRINT(" Chk0 (", _iteratePID); PRINT(",", _tempPrev); PRINT(",", tempCurr); PRINT(") = ", b);
    // ... or we are exceeding the
    b = b || (tempCurr > TEMP_CTL_MAX);
    PRINT(" Chk1 (", tempCurr); PRINT(",", TEMP_CTL_MAX); PRINT(") = ", b);
    // reset checking values
    _timeLastSafetyCheck = millis();
    _tempPrev = tempCurr;
    // Prevent heater damage if not working
    if (b)
      _error = 1;
      switchPower(false);
      return;
  // now do the PID if it is time
  if (!_isFixPowerMode && (millis() - _timeLastPIDRun >= PID_RUN_PERIOD))
    _timeLastPIDRun = millis();
    PRINTS("\nIRON: PID Control - ")
      if (!_iteratePID) // use the direct PI formulae
        int32_t p = PID_Kp*(_tempSP - tempCurr);
        p += PID_Ki * (_tempSP - tempCurr);
        p += (1 << (DENOMINATOR_p - 1));
        p >>= DENOMINATOR_p;
        _tempHist[1] = tempCurr;
        if (abs(_tempSP - tempCurr) < PID_SWITCH_DELTA_T) // If the temperature is close, prepare PID iteration process
          _tempHist[0] = _tempHist[1]; // now ready to use iterate algorithm
          _iteratePID = true;
        _powerSP = p;
        PRINTS("Direct");
        int32_t delta_p = PID_Kp * (_tempHist[1] - tempCurr);
        delta_p += PID_Ki * (_tempSP - tempCurr);
        delta_p += PID_Kd * (2 * _tempHist[1] - _tempHist[0] - tempCurr);
        delta_p += (1 << (DENOMINATOR_p - 1));
        delta_p >>= DENOMINATOR_p;
        _powerSP += delta_p;
        PRINTS("Iterate");
    PID_TRACE(millis(), getTempSP(), getPowerSP(), getTempCV());
    applyPower();
void IRON::switchPower(bool setOn)
// Switch the iron on (true) or off (false)
// This should be the only place this happens so we can
// the different status values.
  _isOn = setOn;
  if (!_isOn)  // turn off
    //PRINTS("\nIRON: Switching off");
    digitalWrite(_pinHeater, LOW);
    _isFixPowerMode = false;
    _isUsed = true;
    PRINTS("\nIRON: Switching on");
    resetPID();
    _tempHist[1] = getTempCV();
    PID_TRACE_HEADER;
void IRON::applyPower(void)
// Apply some power to the heater based on current control values
// this is used to control using the PID control loop
  uint8_t p = getPowerSP();
  if (_tempHist[1] > (_tempSP + 1))
    PRINT("\nIRON: Hist[1]=", _tempHist[1]);
    PRINT(" tempSP=", _tempSP);
    p = 0;
  PRINT("\nIRON: Apply Power=", p);
  if (p == 0)
  else if (_isOn)
    analogWrite(_pinHeater, p);
bool IRON::fixPower(uint8_t setPower)
// Switch the iron power setting directly
// To switch off, set the power to 0
  PRINT("\nIRON: FixPower ", setPower);
  _isFixPowerMode = (setPower != 0);
  if (!_isFixPowerMode)
    PRINTS(" turning power off");
    switchPower(false);
  else     // definitely set the power to something!
    _isUsed = true;
    if (setPower > MAX_POWER) setPower = MAX_POWER;
    if (setPower < MIN_POWER) setPower = MIN_POWER;
    PRINT(" set to ", setPower);
    _powerSP = setPower;
    analogWrite(_pinHeater, _powerSP);
  return(true);
// cRunState ---------------------------------------------
// Base class for device running state (finite state machine)
class cRunState
protected:
  static const uint16_t UPDATE_INTERVAL = 1000;  // in ms
  bool _forceRedraw;        // we need to draw the display
  uint32_t    _timeLastUpdate; // last display time (millis())
  LCD_Display *_pD;         // pointer to the Display instance
  ConfigData  *_pCfg;       // pointer to the Configuration instance
  IRON        *_pIron;      // pointer to the Iron instance
public:
  cRunState *_next;   // pointer to the next cRunState
  cRunState *_nextL;  // pointer to the next cRunState
  cRunState *_setup;  // pointer to the setup cRunState
  cRunState()
    _next = _nextL = _setup = nullptr;
    _forceRedraw = true;
    _pCfg = nullptr;
    _pD = nullptr;
    _timeLastUpdate = 0;
  virtual void begin(void) { PRINTS("\nCRS: Base class begin()"); }
  virtual void handleEncoder(int8_t value) { PRINTS("\nCRS: Base class handleEncoder()"); }
  virtual void update(void) { PRINTS("\nCRS: Base class update()"); }
  virtual void show(void)
    // check if we should be doing an update
    if ((!_forceRedraw) && (millis() - _timeLastUpdate < UPDATE_INTERVAL))
      return;
    // update display and reset triggers
    //PRINT("\nUpdate forced=", _forceRedraw);
    //PRINT(" time=", millis() - _timeLastUpdate);
    update();
    _forceRedraw = false;
    _timeLastUpdate = millis();
  virtual cRunState *next(void)     { return((_next  != nullptr) ? _next  : this); }
  virtual cRunState *nextLong(void) { return((_nextL != nullptr) ? _nextL : this); }
  virtual cRunState *nextSetup(void){ return((_setup != nullptr) ? _setup : this); }
  void forceRedraw(void) { _forceRedraw = true; }
// idleRunState [soldering iron OFF] ---------------------
// Starting state for the device in off mode
class idleRunState : public cRunState
public:
  idleRunState(IRON *pIron, LCD_Display *pLCD_Display, ConfigData *pCfg)
    _pIron = pIron;
    _pD = pLCD_Display;
    _pCfg = pCfg;
    PRINTS("\nIDLE ======");
    // reset the iron the devices to the idle state
    _pIron->switchPower(false);
    // set up display static data and then force dynamic data update
    _pD->setMainDisplay();
    _pD->setCtlNone();
#if USE_CELCIUS
    _pD->setTempCel();
#else
    _pD->setTempFar();
#endif
    forceRedraw();
    if (_pIron->isUsed()) // the iron was used, should save new temp setpoint to EEPROM
      _pCfg->setTempSP(_pIron->getTempSP());
      _pCfg->save();
    _pD->setSP(_pIron->getTempSPDegrees());
    _pD->setCV(_pIron->getTempCVDegrees());
    _pD->setGaugePct(_pIron->getHotPercent());
    // set the message to what we think is going on
    if (_pIron->isUsed() && !_pIron->isCold())   // not yet cold
      _pD->setModeCooling();
      _pD->setModeReady();
    _pD->update();
    _pIron->setTempSPDegrees(_pIron->getTempSPDegrees() + value);
    _pD->setSP(value);
    forceRedraw();
// ctlTempRunState [soldering iron ON, Temp control] -----
// Normal run mode with device in temperature control mode
class ctlTempRunState : public cRunState
public:
  ctlTempRunState(IRON *pIron, LCD_Display *pLCD_Display)
	  _pIron = pIron;
	  _pD = pLCD_Display;
    PRINTS("\nTEMP ======");
    // start the control sequence
    _pIron->switchPower(true);
    _pD->setCtlTemp();
#if USE_CELCIUS
    _pD->setTempCel();
#else
    _pD->setTempFar();
#endif
    forceRedraw();
  void update(void)
    _pD->setCV(_pIron->temp2degrees(_pIron->getTempCV()));
    _pD->setGaugePct((uint8_t)_pIron->getPowerSPPct());
    if (abs(_pIron->getTempSP() - _pIron->getTempCV()) < 4)
    else if (_pIron->getTempCV() < _pIron->getTempSP())
      _pD->setModeHeating();
    _pD->update();
    _pD->setSP(value);
    forceRedraw();
// ctlPowerRunState [soldering iron ON, fixed power] -----
// Fixed power running mode
class ctlPowerRunState : public cRunState
public:
  ctlPowerRunState(IRON *pIron, LCD_Display *pLCD_Display)
    _pIron = pIron;
    _pD = pLCD_Display;
  void begin(void)
    PRINTS("\nPOWER =====");
    _pIron->fixPower(_pIron->getPowerSP());
    _pD->setCtlPower();
#if USE_CELCIUS
    _pD->setTempCel();
#else
    _pD->setTempFar();
#endif
    forceRedraw();
  void update(void)
    _pD->setSP(_pIron->getPowerSP());
    _pD->setGaugePct(_pIron->getPowerSPPct());
    _pD->update();
    int16_t p = _pIron->getPowerSP() + value;
    PRINT("\nTUNE: Encoder ", value);
    // make it fit into a uint8_t
    if (p < 0) p = 0;
    if (p > 255) p = 255;
    _pIron->fixPower(p);
    forceRedraw();
// tuneRunState ------------------------------------------
// Tuning parameter setup for the device
class tuneRunState : public cRunState
private:
  // parameter labels and values
  static const uint8_t MAX_PARAM = 2;
  static const uint8_t P_RANGE_HI = 0;
  static const uint8_t P_RANGE_LO = 1;
  static const uint8_t LABEL_SIZE = 11;
  uint8_t _curItem;
  char _label[LABEL_SIZE+1];
  uint16_t _param[MAX_PARAM];
public:
  tuneRunState(IRON *pIron, LCD_Display *pLCD_Display, ConfigData *pCfg)
    _pIron = pIron;
    _pD = pLCD_Display;
    _pCfg = pCfg;
  void begin(void)
    PRINTS("\nTUNE ======");
    // set all parameters to zero and then ...
    for (uint8_t i = 0; i < MAX_PARAM; i++)
      _param[i] = 0;
    // .. load pre-existing config data
    _pCfg->getCalibrationRange(_param[P_RANGE_HI], _param[P_RANGE_LO]);
    _curItem = 0;
    // turn on fixed power
    _pIron->fixPower((MAX_POWER + MIN_POWER) / 2);
    // set up the display
    _pD->setCfgDisplay();
    _pD->setTempRaw();
    forceRedraw();
  void saveParam(void)
    _param[_curItem] = _pIron->getTempCV();
  void update(void)
    uint16_t temp;
    temp = (_curItem == 0 ? TEMP_MAX_DEG : TEMP_MIN_DEG);
    sprintf(_label, "Set %03d deg", temp);
    _pD->setCV(_pIron->getPowerSP());
    _pD->setLabel(_label);
    _pD->setSP(_pIron->getTempCV());
    _pD->update();
    if (p < 0) p = 0;
    forceRedraw();
  // 'next display' is the same display with different item
    saveParam();
    _curItem++;
    if (_curItem < MAX_PARAM)
      forceRedraw();    // do the next parameter
      // // all parameters processed - turn the iron off ...
      _pIron->fixPower(0);    // turn it off!
      // ... save config, and ...
      _pCfg->setCalibrationRange(_param[P_RANGE_HI], _param[P_RANGE_LO]);
      _pCfg->save();
      // ... reset the hardware to reinitialise all
      resetHW();
    return(this);
// errorRunState ------------------------------------------
// Display an error message
class errorRunState : public cRunState
private:
  static const uint8_t LABEL_SIZE = 16;
  static const uint8_t MAX_ERROR = 4;     // includes heading
  static const PROGMEM char _labels[MAX_ERROR][LABEL_SIZE+1];
  char _label[2][LABEL_SIZE+1];
  char *getLabel(char *szBuf, uint8_t idx, uint8_t len)
    strncpy_P(szBuf, _labels[idx], len);
    szBuf[len] = '\0';
    return(szBuf);
public:
  errorRunState(IRON *pIron, LCD_Display *pLCD_Display)
    _pIron = pIron;
    _pD = pLCD_Display;
  void begin(void)
    PRINTS("\nERROR ======");
    // turn the iron off
    // set up the error message and heading
    if (_pIron->getError() < MAX_ERROR-1)
      getLabel(_label[1], _pIron->getError() + 1, LABEL_SIZE);  // error mesg, skip heading text
      sprintf(_label[1], getLabel(_label[0], 0, LABEL_SIZE), _pIron->getError()); // unknown, format mesg
    getLabel(_label[0], 1, LABEL_SIZE);   // heading
    _pD->setErrDisplay();
    forceRedraw();
    _pIron->clearError();
  void update(void)
    _pD->setError(_label[0], _label[1]);
    _pD->update();
const PROGMEM char errorRunState::_labels[MAX_ERROR][LABEL_SIZE+1] =
// 0123456789012345   <- character position
  "?Error %02d",      // Unknown error
  "Check iron",       // Display heading
  "Safety shutdown",  // Real error messages start here (err no + 1)
  "T sensor range",
// End of class declarations =============================
ConfigData    ironCfg;
LCD_Display   disp(LCD_DAT_PIN, LCD_CLK_PIN);
IRON          iron(heaterPIN, sensorPIN);
MD_REncoder   REncoder(RE_MAIN_PIN, RE_SECD_PIN);
MD_KeySwitch  RESwitch(RE_SWITCH_PIN);
// Run State Machine states
// Finite State Diagram
//   stTune <---- stIdle <--- stError
//                 +-> stCtlT -+ |
//                      +-> stCtlP -+
idleRunState      stIdle(&iron, &disp, &ironCfg); // main state at power on
ctlTempRunState   stCtlT(&iron, &disp);           // temperature control runing (main run mode)
ctlPowerRunState  stCtlP(&iron, &disp);           // fixed power running
tuneRunState      stTune(&iron, &disp, &ironCfg); // temperatrure tuning
errorRunState     stError(&iron, &disp);          // error message displayed
cRunState *pCurrentRunState = &stIdle;
#if DEBUG || PID_PROFILE
  Serial.begin(57600);
  PRINTS("\n[Soldering Controller]");
#endif // DEBUG
  // Start the display
  disp.begin();
  // Initialize rotary encoder and its switch
  RESwitch.begin();
  RESwitch.enableRepeat(false);
  REncoder.begin();
  REncoder.setPeriod(500);
  // Load Configuration parameters and initialise the iron
  ironCfg.begin();
  ironCfg.load();
    uint16_t tempMin, tempMax;
    ironCfg.getCalibrationRange(tempMax, tempMin);
    iron.begin(tempMax, tempMin);
    iron.setTempSP(ironCfg.getTempSP());
  // Initialize cRunState hierarchy to reflect the
  // state machine transitions when the user moves between state
  // - next by a click
  // - nextL by a long press
  // - setup by a double click
  // cRunState  next      nextL     setup
  // stIdle     ctlTemp             stTune
  // stCtlT     stIdle      stCtlP
  // stCtlP     stIdle      stCtlT
  // stTune     <next cfg item, then reset>
  // stError    stIdle
  stIdle._next = &stCtlT;
  stIdle._setup = &stTune;
  stCtlT._next = &stIdle;
  stCtlT._nextL = &stCtlP;
  stCtlP._next = &stIdle;
  stCtlP._nextL = &stCtlT;
  stTune._setup = &stIdle;
  stError._next = &stIdle;
  pCurrentRunState->begin();
  PRINTS("\nsetup() completed");
  cRunState *nxt = nullptr;
  // process rotary encoder
  uint8_t pos = REncoder.read();
  if (pos != DIR_NONE)
    int8_t v = (REncoder.speed() < 5) ? 1 : 5;
    v *= (pos == DIR_CW ? 1 : -1);   // add in the sign
    PRINT("\n-> Encoder n=", v);
    pCurrentRunState->handleEncoder(v);
  // process key switch to navigate the states
  switch (RESwitch.read())
  case MD_KeySwitch::KS_PRESS:
    PRINTS("\n-> Press");
    nxt = pCurrentRunState->next();
  case MD_KeySwitch::KS_LONGPRESS:
    PRINTS("\n--> Long Press");
    nxt = pCurrentRunState->nextLong();
  case MD_KeySwitch::KS_DPRESS:
    PRINTS("\n=> DPress");
    nxt = pCurrentRunState->nextSetup();
  case MD_KeySwitch::KS_NULL:
    // do nothing
  // check if an error has occurred and override nxt if required
  if (!iron.isWorking())
    nxt = &stError;
  // if we changed run state, process the change
  if (nxt != nullptr && nxt != pCurrentRunState)
    pCurrentRunState = nxt;
  pCurrentRunState->show();
  // finally, run the iron control
  iron.controlTemp();
The error message tells you exactly where the file was referenced from. Right down to the line and column # in the file.
Oh yes there is !
Read the error message carefully and you will see that the Bargraph.h library #includes LiquidCrystal_SR.h
hi thankyou for your prompt responses but after having changed that, it then came up with all of these! - i will admit now that i am far from an expert, i took this project on as from what i read it should be fairly simple to change the relevent code to function with an I2C display, its really not turning out to be lol so i apologise but please help lol.
i am currently working my way through 'C programming' by mike mcgrath to teach myself at least the groundwork, if anyone knows of any others that might help me id be very much appreciative :slight_smile:
Changed what ?
If you have changed your sketch please post the revised sketch in a new reply here
If your LCD uses i2c, then you need to use the subclass hd44780_I2Clcd:
//#include <LiquidCrystal_SR.h>
#include <Wire.h>
#include <hd44780ioClass/hd44780_I2Clcd.h> // i2c LCD i/o class header
and you need to change LiquidCrstal_SR -> hd44780_I2Clcd throughout the code.
The code seems poorly laid out since there are many .h files, all containing the same #includes but they are included inthe main sketch so it is all unnecessary.
Hi, thanks so much for your advice, i have gone through and changed LiquidCrystal_SR to hd44780_I2Clcd as you said, aswell as adding the hd44780_I2Clcd.h library off of Github, no when i compile it comes up with the following errors
In file included from C:\Users\joshh\Documents\Arduino\soldering_station\soldering_station.ino:14:0:
C:\Users\joshh\Documents\Arduino\libraries\FX888-Controller-master/LCD_Display.h: In constructor 'LCD_Display::LCD_Display(uint8_t, uint8_t)':
C:\Users\joshh\Documents\Arduino\libraries\FX888-Controller-master/LCD_Display.h:79:66: error: no matching function for call to 'hd44780_I2Clcd::hd44780_I2Clcd(uint8_t&, uint8_t&)'
   LCD_Display(uint8_t DAT, uint8_t CLK) : hd44780_I2Clcd(DAT, CLK)
In file included from C:\Users\joshh\Documents\Arduino\soldering_station\soldering_station.ino:6:0:
C:\Users\joshh\Documents\Arduino\libraries\hd44780/hd44780ioClass/hd44780_I2Clcd.h:110:1: note: candidate: hd44780_I2Clcd::hd44780_I2Clcd(uint8_t)
 hd44780_I2Clcd(uint8_t i2c_addr=0) : _Addr(i2c_addr) {} // zero addres means auto locate
C:\Users\joshh\Documents\Arduino\libraries\hd44780/hd44780ioClass/hd44780_I2Clcd.h:110:1: note:   candidate expects 1 argument, 2 provided
C:\Users\joshh\Documents\Arduino\libraries\hd44780/hd44780ioClass/hd44780_I2Clcd.h:103:7: note: candidate: constexpr hd44780_I2Clcd::hd44780_I2Clcd(const hd44780_I2Clcd&)
 class hd44780_I2Clcd : public hd44780
C:\Users\joshh\Documents\Arduino\libraries\hd44780/hd44780ioClass/hd44780_I2Clcd.h:103:7: note:   candidate expects 1 argument, 2 provided
C:\Users\joshh\Documents\Arduino\libraries\hd44780/hd44780ioClass/hd44780_I2Clcd.h:103:7: note: candidate: constexpr hd44780_I2Clcd::hd44780_I2Clcd(hd44780_I2Clcd&&)
exit status 1
That error is due to the fact the the hd44780_I2Clcd class constructor does not take any arguments so you need to change that line to
LCD_Display(uint8_t DAT, uint8_t CLK) : hd44780_I2Clcd()
It will give you warnings about the unused variables DAT and CLK but that is okay.
Whey thankyou, having followed your advice the code compiled and uploaded fine so im a step closer :slight_smile: however i hooked everything up for a test and the screen backlight lights up but displays nothing :confused: im getting power everywhere that its required and have checked the wiring a few times now so pretty confident its hooked up ok.
having done some reading it seems the I2C piggy back im using has a PCF8574AT made by NXP and should have a default address of 0x3F, could this have something to do with why its not displaying?
You could always run the i2cscanner sketch to see what address is detected on the bus and pass that along to the class rather than have it figure it out on its own.
Maybe try some of the simple sketches that come with the library to see if the display is up and functional to make sure the wiring is correct and things are working before trying to debug a more complex sketch.
