Soldering to Pin Headers
Hi guys! Can I solder a wire to this pin header? Maybe this question seems strange but I'm actually interested in it
Screenshot_1
Sure you can.
Finish it up with heat shrink tubing.
Thanks Larry!
I do it quite a bit. Tin the header pin (melt a small blob of solder onto the pin) and tin the wire first. Then hold the wire to the tinned header and heat till they fuse together. Should happen quickly.
Thank you! I appreciate it
But you do not want the end of your flexible (multi-strand) wire looking like that. You twist teh strands together into a neat bundle before soldering.
