solenoid valve operating frequency 83 cycles per second ?
Is there a solenoid valve which can be operated at 83 cycles per second?
This valves controls the supply of air in a pipe nothing else just air only.
If there is one can you link me to it :wink:
12mS, 83 Hz
20 million cycles
20,000,000/83/60/60 = 66 hours?
CrossRoads:
http://www.automationdirect.com/static/specs/nitrapipelinesolenoiddvp2cdvp3c.pdf
12mS, 83 Hz
20 million cycles
Of course that speed of response can only apply to the DC variants, as 50 or 60Hz AC will
interfere with achieving 12ms action! To get rapid release you will definitely need to
think about the correct snubber circuit to allow rapid de-energising of the coil - a single
diode will prolong the flow of current noticably.
