OK first off this will only work if this sensor repeats the code 3 times or more in a row, if it does, try making these changes in RC switch
RCSwitch.cpp
#if defined(ESP8266) || defined(ESP32)
static const RCSwitch::Protocol proto[] = {
#else
static const RCSwitch::Protocol PROGMEM proto[] = {
#endif
{ 350, { 1, 31 }, { 1, 3 }, { 3, 1 }, false }, // protocol 1
{ 650, { 1, 10 }, { 1, 2 }, { 2, 1 }, false }, // protocol 2
{ 100, { 30, 71 }, { 4, 11 }, { 9, 6 }, false }, // protocol 3
{ 380, { 1, 6 }, { 1, 3 }, { 3, 1 }, false }, // protocol 4
{ 500, { 6, 14 }, { 1, 2 }, { 2, 1 }, false }, // protocol 5
{ 450, { 23, 1 }, { 1, 2 }, { 2, 1 }, true }, // protocol 6 (HT6P20B)
{ 150, { 2, 62 }, { 1, 6 }, { 6, 1 }, false }, // protocol 7 (HS2303-PT, i. e. used in AUKEY)
{ 200, { 3, 130}, { 7, 16 }, { 3, 16}, false}, // protocol 8 Conrad RS-200 RX
{ 200, { 130, 7 }, { 16, 7 }, { 16, 3 }, true}, // protocol 9 Conrad RS-200 TX
{ 365, { 18, 1 }, { 3, 1 }, { 1, 3 }, true }, // protocol 10 (1ByOne Doorbell)
{ 270, { 36, 1 }, { 1, 2 }, { 2, 1 }, true }, // protocol 11 (HT12E)
{ 320, { 36, 1 }, { 1, 2 }, { 2, 1 }, true }, // protocol 12 (SM5212)
{ 108, { 5, 83 }, { 5, 38 }, { 5, 19 }, false }, // protocol 13 yours one of these may work
{ 108, { 83, 5 }, { 38, 5 }, { 19, 5 }, true } // protocol 14 yours
enum {
numProto = sizeof(proto) / sizeof(proto[0])
#if not defined( RCSwitchDisableReceiving )
volatile unsigned long RCSwitch::nReceivedValue = 0;
volatile unsigned int RCSwitch::nReceivedBitlength = 0;
volatile unsigned int RCSwitch::nReceivedDelay = 0;
volatile unsigned int RCSwitch::nReceivedProtocol = 0;
int RCSwitch::nReceiveTolerance = 90;
const unsigned int RCSwitch::nSeparationLimit = 7000;// was 4300;
// separationLimit: minimum microseconds between received codes, closer codes are ignored.
// according to discussion on issue #14 it might be more suitable to set the separation
// limit to the same time as the 'low' part of the sync signal for the current protocol.
unsigned int RCSwitch::timings[RCSWITCH_MAX_CHANGES];
#endif
And change this in RCSwitch.h
#define RCSWITCH_MAX_CHANGES 80
if it works i can try and explain the changes, let me know how it goes
Best of luck
