Hi!
I have this self-made led-matrix, controlled with pro mini (which I'll switch to teensy once I have this problem solved)
Arduino part of code processes serial data, works in wired serial as well as bluetooth. But, now when I try to add ESP-01 to control from browser, something odd is happening.
When I use any other serial method than ESP-01, it looks like this, smooth scrolling and showing letters, like It's supposed to be:
But, when I try to use ESP-01, text only "blinks" very quickly when shot from browser, and MDNS-part of code is shown on screen once, before sending any data. It looks like extra line feed is fed.
But, according to serial monitor, no extra LN is received on arduino part.
I have feeling esp-part of code is culprit, since bluetooth serial and wired serial works fine
First, ESP:code (program using arduino IDE)
Full article I found this code from and mangled bit:
I hope I didn't forgot any relevant information.
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
MDNSResponder mdns;
// Replace with your network credentials
const char* ssid = "KONIG_WS01";
const char* password = "admin";
ESP8266WebServer server(80);
String webPage = "";
void setup(void) {
webPage += "<h1>ESP8266 Web Server</h1>";
webPage += "<form action='msg'><p>Type your message <input type='text' name='msg' size=100 autofocus> <input type='submit' value='Submit'></form>";
WiFi.begin(ssid, password);
Serial.println("");
// Wait for connection
Serial.print(".");
Serial.println("");
Serial.print("Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
if (mdns.begin("esp8266", WiFi.localIP())) {
Serial.println("MDNS responder started");
server.on("/", []() {
server.send(200, "text/html", webPage);
server.on("/msg", []() {
String msg = server.arg("msg");
Serial.println(msg); delay(1000);
server.begin();
Serial.println("HTTP server started");
void loop(void) {
server.handleClient();
And then the pro-mini part
//this sketch allows to scroll text and data on 8x8 matrises. When changing matrix size, change matrises value and OCR1A in setup. However, OCR1A is initially se-up for bigger displays, and it works in smaller too so no need change unless screen doesn't update fast enought; increase value then.
SERIAL INPUT!
to display text = text("text here",x-pos,y-pos, rot(optional));
to display values in numbers= value(value, x-pos,y-pos, rot(optional));
to display pixels=pixel(x-pos,y-pos,mode); (useful for drawing lines and graphs, use for() loop to create lines better
BIG thanks for dr.doggy from ETO (electro tech online)
signed char/char= 1 byte(8 bits), -127->127
unsigned char/byte= 1 byte(8 bits), 0->255
int= 2 byte(16 bits), -32768->32767
unsigned int= 2 byte(16 bits), 0-> 65535
long = 4 byte(32 bits), -2,147,483,648->2,147,483,647
unsigned long= 4 byte (32 bits), 4,294,967,295
#include "FontMap.h" //font is in external file
#define matrises 4 //define number of matrises, 4-22
#define columns matrises*8 //calculate columns based how many matrises are in use
byte displayPointer = 0; //for interrupt use...
byte buffer1[columns]; // buffer for screen,4x8=32
const byte power[8] = {128, 64, 32, 16, 8, 4, 2, 1}; //for each column B10000000->B00000001
char string[40]; //array to store incoming data
char textFromPc[40]; //array to store actual text to show on matrix
char c;
byte index;
byte textlength; //for dynaminc scroll length
char * strtokIndx; // this is used by strtok() as an index
byte Yoffset = 0;
byte Rotation = 0;
void draw() //draw loop,DON'T TOUCH!
setcolumn(displayPointer); //column scanning
setdata(buffer1[displayPointer]); //bit banging shift registers
bitSet(PORTD, 3); //blit latch, high->low
bitClear(PORTD, 3);
if (++displayPointer == columns) //32 LED row sections in total
{ displayPointer = 0;
void setcolumn(byte col) //loop that takes care of column scanning DON'T TOUCH!
int pos;
for (pos = columns; pos > -1; pos--)
if (col == pos)
bitSet(PORTD, 2); //data high
bitClear(PORTD, 2); //data low
bitSet(PORTD, 4); //blit clock high->low
bitClear(PORTD, 4);
void setdata(byte dat)
byte pos;
for (pos = 0; pos < 8; pos++)
if (dat & 128)
dat -= 128;
dat = dat << 1; //dat <<1==dat *2;
bitClear(PORTD, 4);
void clr() //clear display buffer
byte addr;
for (addr = 0; addr < columns; addr++) // Empty display buffer
buffer1[addr] = 0;
void pixel(signed char x, signed char y, byte cond)
byte pix, msk;
if (x < 0 || y < 0)
return; // outside drawing limits negative
if (x > (columns - 1) || y > 7)
return; // outside drawing limits positive, x=32, y=8
pix = power[y];
msk = buffer1[x]; // get exsisting data
if (cond == 2)
pix ^= msk; //XOR data to screen
if (cond == 1)
pix = ~pix;
pix &= msk; // AND data to screen
if (cond == 0)
pix |= msk; // OR data to screen
buffer1[x] = pix; // apply changes
void value(char ch, signed char x, signed char y, byte rotation)
byte x1, y1;
byte disp, disp2;
for ( x1 = 0; x1 < 8; x1++) // eight rows
disp = font[x1 + (ch << 3)]; //look data from fontmap, (ch<<3)==(ch *8)
for (y1 = 0; y1 < 8; y1++) // eight pixels
disp2 = disp & power[y1];
if (disp2 > 0)
if (rotation == 0)
pixel(x + x1, y + y1, 0); //0 degrees
if (rotation == 1)
pixel(7 - (y + y1), (x + x1), 0); //90 degrees, flip to left
if (rotation == 2)
pixel(7 - (x + x1), 7 - (y + y1), 0);
if (rotation == 3)
pixel(y + y1, 7 - (x + x1), 0); //90 degrees, flip to right
void text(char* ch, signed char x, signed char y, byte rotation) //strput relies on charput
while (*ch )
value(*ch++, x, y, rotation); //write a string to the display buffer
x += 7;
void setup() //setup runs once
DDRD = DDRD | B11111100; //port registers used to set pin directions
void loop() //just sitting here
if (Serial.available() > 0)
c = Serial.read();
if ((c != '\r') && (c != '\n')) //Keep these out of our buffer
string[index++] = c; //Add whatever we receive to the buffer
textlength = index * 8 + 32; // *8, since matrises are 8-wide, and 32 to scroll whole screen.
string[index++] = '\0';//Converts the array into a string
index = 0; //next time we start from beginning index
parseData(); //time to parse data received
//showParsedData(); //for debugging!
clr();
text(textFromPc, 31 - millis() / 100 % textlength, Yoffset, Rotation);
draw();
void parseData() //function for splitting the array
strtokIndx = strtok(string, ","); // get the first part - the TEXT PART
strcpy(textFromPc, strtokIndx); // copy it to messageFromPC
strtokIndx = strtok(NULL, ",");
Yoffset = atoi(strtokIndx);
Rotation = atoi(strtokIndx);
void showParsedData()
Serial.print("text ");
Serial.println(textFromPc);
Serial.print("plane ");
Serial.println(Yoffset);
Serial.print("rotation ");
Serial.println(Rotation);
