[SOLVED] Arduino and NodeMCU Serial Communication
Hello guys,
I am making test program for my current project to send serial data from my ESP NodeMCU to Arduino Uno. I used Serial Communication to send 4 dummy variables which represent my sensor reading from MCU to arduino, but it didn't work. Can you help me?
Here are my codes:
Arduino Code
#include <ArduinoJson.h>
#include <SoftwareSerial.h>
SoftwareSerial s(5,6); //RX,TX
  s.begin(9600);
  while (!Serial) continue;
  DynamicJsonBuffer DataNode;
  JsonObject& root = DataNode.parseObject(s);
  if (root == JsonObject::invalid()){
    Serial.println("invalid");
    return;
  int SenseNode1 = root["node1"];
  int SenseNode2 = root["node2"];
  int SenseNode3 = root["node3"];
  int SenseNode4 = root["node4"];
  Serial.print("Node 1: " );
  Serial.print(SenseNode1);
  Serial.print("\n");
  Serial.print("Node 2: " );
  Serial.print(SenseNode2);
  Serial.print("\n");
  Serial.print("Node 3: " );
  Serial.print(SenseNode3);
  Serial.print("\n");
  Serial.print("Node 4: " );
  Serial.print(SenseNode4);
  Serial.print("\n");
  Serial.print("-------------------------------------------\n");
NodeMCU Code
SoftwareSerial s(12, 14); //D6, D5
JsonObject& root = DataNode.createObject();
int sensorValue0 = 100;
int sensorValue1 = 200;
int sensorValue2 = 300;
int sensorValue3 = 400;
  s.begin(9600);
  root["node1"] = sensorValue0;
  root["node2"] = sensorValue1;
  root["node3"] = sensorValue2;
  root["node4"] = sensorValue3;
  Serial.println(sensorValue0);
  Serial.println(sensorValue1);
  Serial.println(sensorValue2);
  Serial.println(sensorValue3);
  if(s.available()>0){
    root.printTo(s);
Here is my Serial Monitor Screenshot (COM6 for Arduino and COM7 for MCU)
I know nothing about ArduinoJson but I see no attempt in your Arduino program to read data from your SoftwareSerial instance.
Separately, please NEVER use single character variable names such as s because it is impossible to search a program to find all the instances of it.
Have a look at the examples in Serial Input Basics - simple reliable non-blocking ways to receive data. There is also a parse example to illustrate how to extract numbers from the received text.
The technique in the 3rd example will be the most reliable. It is what I use for Arduino to Arduino and Arduino to PC communication.
You can send data in a compatible format with code like this (or the equivalent in any other programming language)
Serial.print('<'); // start marker
Serial.print(value1);
Serial.print(','); // comma separator
Serial.print(value2);
Serial.println('>'); // end marker
The examples will work perfectly well with SoftwareSerial
...R
JSON is a terrible way to store and send data. Avoid it unless you have to interface with a device that requires a JSON format. A better way to store and send data would be to use a struct.
On top of that, it would be easier to use SerialTransfer.h to automatically packetize and parse your data for inter-Arduino communication without the headace. The library is installable through the Arduino IDE and includes many examples.
Here are the library's features:
This library:
  • can be downloaded via the Arduino IDE's Libraries Manager (search "SerialTransfer.h")
  • works with "software-serial" libraries
  • is non blocking
  • uses packet delimiters
  • uses consistent overhead byte stuffing
  • uses CRC-8 (Polynomial 0x9B with lookup table)
  • allows the use of dynamically sized packets (packets can have payload lengths anywhere from 1 to 254 bytes)
  • can transfer bytes, ints, floats, and even structs!!
Example TX Arduino Sketch:
#include "SerialTransfer.h"
SerialTransfer myTransfer;
struct STRUCT {
  char z;
  float y;
} testStruct;
  Serial1.begin(115200);
  myTransfer.begin(Serial1);
  testStruct.z = '|';
  testStruct.y = 4.5;
  myTransfer.txObj(testStruct, sizeof(testStruct));
  myTransfer.sendData(sizeof(testStruct));
  delay(100);
Example RX Arduino Sketch:
struct STRUCT {
  char z;
  float y;
} testStruct;
  if(myTransfer.available())
    myTransfer.rxObj(testStruct, sizeof(testStruct));
    Serial.print(testStruct.z);
    Serial.print(' ');
    Serial.println(testStruct.y);
  else if(myTransfer.status < 0)
    Serial.print("ERROR: ");
    if(myTransfer.status == -1)
      Serial.println(F("CRC_ERROR"));
    else if(myTransfer.status == -2)
      Serial.println(F("PAYLOAD_ERROR"));
    else if(myTransfer.status == -3)
      Serial.println(F("STOP_BYTE_ERROR"));
For theory behind robust serial communication, check out the tutorials Serial Input Basics and Serial Input Advanced.
[UPDATE]
Thank you for your advice Robin2 and Power_Broker! i've tried it and my program works fine now. I am currently using the SerialTransfer library since it is simpler for me to apply to my system.
