Solved Arduino in windows device manager
When i connect arduino nano to my computer it appears as a modem and i can communicate with it through anu software that uses AT commands like vb6
But uni arduino does not. Appear as a modem and I cannot access it the same way
Is that normal or did i do something wrong
Arduino USB typically emulates a dumb COM port, not a full modem. If you want it to act like a modem you can do so in software, by trapping "AT" and the following command on the Serial port. But only very few AT commands can be emulated due to missing phone hardware - which commands would you like to send?
All i want is to communicate with it through vb6 comm port
Receive data and send data
Vb6 does not see it as a comm port
Thank you
So here is a link to PLX-DAQ version 2 - now with 64 bit support! (and further new features) - Interfacing w/ Software on the Computer - Arduino Forum, where the fellow has created a way for the Arduino to send data to an Excel spread sheet. You can view his code, in Excel, to see how he does the thing and then use the thing in your VB thing.
Thank you problem solved
From the device manager advanced settings
I changed the port number the arduino used from 18 to 2
And thus the short sighted vb saw it
Thank you
The COM port number can change after every reconnect or reboot. You may have to program a COM port scanner, in order to find the right port number. When multiple Arduinos are connected, each one gets its individual (random) port number.
I'm using VB5 to send record selection pulses into my Jukebox through an Uno:
Main Form (in part):
Private Sub txtCom_Change()
  On Error GoTo ErrSub
  myErr = "ComChange1"
  If frmCom.Com1.PortOpen = True Then
    frmCom.Com1.PortOpen = False
    myPortOpen = "no"
  End If
  myErr = "ComChange2"
  myComPort = Val(txtCom.Text)
  frmCom.Com1.CommPort = myComPort
  frmCom.Com1.Settings = "9600,N,8,1"
  frmCom.Com1.InputLen = 1
  frmCom.Com1.RThreshold = 1
  frmCom.Com1.SThreshold = 1
  frmCom.Com1.RTSEnable = True
  myErr = "ComChange3"
  myPortOpen = "yes"
Exit Sub
ErrSub:
  ErrCode = Err
  ErrDesc = Err.Description
  Call frmError.Error_Handler
  'Resume Next
End Sub
Output Form (in part):
Public Sub Form_activate()
  myErr = "Com_Activate"
  lstInput.Clear
  Text1.Text = ""
  If myPortOpen <> "yes" Then
    Com1.InputLen = 1
    Com1.RThreshold = 1
    Com1.SThreshold = 1
    myPortOpen = "yes"
  End If
Various Similar Output Sub Rotines:
Public Sub Output1()                    'send 'Init'
  myErr = "ComOut1-1"
  Text1.Text = ""
  'start 8 second abort timer?
  Timer1.Interval = 8000                'Time in 'millisecs
  Timer1.Enabled = True                 'start timer
  myErr = "ComOut1-2"
  mySub = 1
  xfer1 = "<1, 0, 0, 0>"
  lstInput.AddItem xfer1
  Com1.Output = xfer1
Exit Sub
I've often taken VB6 code and modified it to run in my VB5 so I guess you should be able to get this working in your VB6?
Peter
