void setup(){
//start serial connection
//configure pin2 as an input and enable the internal pull-up resistor
pinMode(0, INPUT_PULLUP);
pinMode(2, INPUT_PULLUP);
pinMode(7, OUTPUT);
void loop(){
//read the pushbutton value into a variable
int switchVal = digitalRead(2);
int sensorVal = digitalRead(0);
//print out the value of the pushbutton
Serial.println("Sensor" + sensorVal);
Serial.println("Switch" + switchVal);
// Keep in mind the pullup means the pushbutton's
// logic is inverted. It goes HIGH when it's open,
// and LOW when it's pressed. Turn on pin 13 when the
// button's pressed, and off when it's not:
if (sensorVal == HIGH && switchVal == LOW) {
tone(7, 3000, time4);
delay(time4);
tone(7, 2800, time4);
delay(time4);
else {
void setup(){
pinMode(7, OUTPUT);
void loop(){
delay(time4);
delay(time4);
else {
turns out it even gets stuck loading on the "bare minimum" example. helppp?
[solved]
not exactly sure how i solved it.
from what i remember doing, i rebooted my computer and uploading the bare-minimum example into the computer.
bare-minimum example (found on arduino's example guides)
I have experienced this recently, the problem came from board setting was set to another board for unknown reason. After choosing a correct board, it could be uploaded.
I had this happen to me on an UNO R3. I solved the issue by disabling Bluetooth on my laptop. It was causing a conflict on COM5.
I had ruled out the board, cable, and IDE. Finally noticed in Device Manager that COM5 had entries (one being the Arduino and the other being Bluetooth). This was on Windows 10 Pro.
Hope that helps someone else that might have this issue in the future.
